Pages: 1 [2]   Go Down
Author Topic: Very confused about timing.  (Read 1422 times)
Austin, TX
CMiYC
Aimed at how to simulate multitasking with millis(), but provides an extended explanation on how it works:
http://www.cmiyc.com/blog/2011/01/06/millis-tutorial/
millis() will work in this application, but you would be able to write much simpler code if you wired up a RTC (such as the ds1307).
www.cmiyc.com - A guide to being an Enginerd
Dallas
Shannon Member
The code does not work correctly as millis approaches the wrap-around.
Boston area, metrowest
Something basic like this would work, flesh out the definitions, pin assignments, other stuff.
Basically, you push the start button at 8:30.
It reads the current value of millis, then sits in a loop reading millis and comparing to the initial read until 8.5 hrs have gone by for interval1.
It then sets some flags and sits in the loop again until 15.5 hrs have gone by for interval2.
Then it repeats.
unsigned long  currentmillis = 0; // value from 0 to 4294967295 (hex FFFF FFFF, a 32 bit number)
unsigned long  elapsedmillis = 0;
unsigned long previousmillis = 0;
//unsigned long interval1 = 3060000; // = 8.5hrs x 60 min/hr * 60 sec/min * 1000ms/sec
//unsigned long interval2 = 55800000; // = (24-8.5)hrs x 60 min/hr * 60 sec/min * 1000ms/sec
unsigned long interval1 = 5000;  // for testing, replace with above
unsigned long interval2 = 5000; // for testing, replace with above
byte interval1_active = 0; // flag =1 to show interval1 in process
byte interval2_active = 0; // flag =1 to show interval2 in process
byte start_button = 2; // pin2 for start button
byte start_button_state = 1; // state of the active low (connect to ground) button
void setup(){
  Serial.begin (9600);
  pinMode (start_button, INPUT);
  digitalWrite (start_button, HIGH);  // internal pullup turned on
  start_button_state = digitalRead (start_button);  // read the active low (internal pullup) start button
  if (start_button_state == 0 && interval1_active == 0) // uses interval1 to ignore switch bounce once pushed
  {  // once pressed,
    Serial.println ("Started!"); // let the user know
    interval1_active = 1; // and set a flag for interval1
    currentmillis = millis();  // take a snapshot of current time
    previousmillis = currentmillis; // sets difference to 0
  if (interval1_active == 0 && interval2_active == 0)  // nothing going on yet
    Serial.println ("Waiting for 8:30"); //  let user know waiting for start time
    delay (1000);  // but not too often
  if (interval1_active == 1 && interval2_active == 0){
    currentmillis = millis();  // read the time.
    elapsedmillis = currentmillis - previousmillis; // compute how much has gone by
    if (elapsedmillis >= interval1) // 8.5 hrs have gone by
      Serial.println ("8.5 hrs elapsed");
      interval1_active = 0;  // turn off 1st flag
      interval2_active = 1; // turn on 2nd
      previousmillis = currentmillis; // reset the difference to 0
      elapsedmillis = 0;
  if (interval1_active == 0 & interval2_active == 1){
    if (elapsedmillis >= interval2) // (24-8.5) hrs have gone by
      Serial.println ("15.5 hrs elapsed");
      elapsedmillis = 0;
} // end void looop
Colorado
Arduino 0022 and Ubuntu 11.10 64bit.
Take a look at the Time library.  I am looking at a led display matrix. it syncs the time once a week via a ntp server.  Seems to keep to good time with or without the sync.
Right Here!
Well here's another fairly clean cut example. Might help.
#define ONEMINUTE 60000
unsigned long lastminute;
int minutes = 0; // either set these to starting values
int hours = 0; // or switch on at midnight!
bool running = false;
void setup(){
  // whatever else you want here
  lastminute = millis(); // should be last command in setup
void loop{
  if (millis() - lastminute >= ONEMINUTE){
    lastminute += ONEMINUTE;
    minutes += 1;
    if (minutes == 60){
      minutes = 0;
      hours += 1;
      if (hours == 24){
        hours == 0;
  if (not running and hours == 8 and minutes == 30){ // just examples
    running = true;
  else if (running and hours == 17 and minutes == 0){
    running = false;
  if (running){
  // some function here
// some other code here too
This will correctly handle millis()  wrap around zero and also step over any other code functions provided the overall loop time is less than 1 minute!
« Last Edit: January 18, 2011, 07:54:58 pm by zaphil » Logged
As long as the variables dealing with millis() are unsiged long, there is no wraparound problem.
Try some examples, convince yourself.
FFFF FFE0 - 0000 0010 correct yields 0000 0030
Right Here!
Only if you do a subtractive comparison. Do a direct foo > bar and the wraparound gives a false result.
Pages: 1 [2]   Go Up
