Loading...
Pages: [1]   Go Down
Author Topic: Button deboncing in simon game  (Read 1808 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi. Im preety new to programming and microcontrolers world, and i want to make simon game, so i did it without copying any code. It is working, but the problem is that i made button debouncing but looks like i made some mistake and i dont know where, Also tryed to set debounce time to 50ms, but it didnt help.
Code:
#include <TrueRandom.h>
#include <EEPROM.h>
int randled;
int val;
int allow=1;
int leds[50];
int buttons[50];
int button1=2;
int button2=3;
int button3=4;
int button4=5;
int turn=0, stepp=1;
int bt1, bt2, bt3, bt4, exbt10, exbt20, exbt30, exbt40, bt10, bt20, bt30, bt40, milis1, milis2, milis3, milis4, debounce=50, test1=0, test2=0, test3=0, test4=0;
unsigned long time1, time2, time3, time4;
int play=1;
int glava=1,konec=0,rec;
void setup (){
pinMode(9,OUTPUT);
pinMode(8,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
pinMode(4,INPUT);
pinMode(5,INPUT);
void loop (){
if(glava==1){
if(allow==1){
  for(int i=0; i<49; i++){
    leds[i]=TrueRandom.random(8,12);
allow=0;
//RECORDING BUTTONS
bt10=digitalRead(button1);
if(bt10==HIGH && exbt10==LOW){
milis1=millis();
test1=1;
if(test1==1 && (millis()-milis1)>debounce){
bt1=digitalRead(button1);
if (bt1==HIGH){
  buttons[turn]=8;
//Serial.println(buttons[turn]);
digitalWrite(8,HIGH);
time1=millis();
turn++;
test1=0;
if(millis()-time1>200){
  digitalWrite(8,LOW);
bt20=digitalRead(button2);
if(bt20==HIGH && exbt20==LOW){
milis2=millis();
test2=1;
if(test2==1 && (millis()-milis2)>debounce){
bt2=digitalRead(button2);
if (bt2==HIGH){
  buttons[turn]=9;
digitalWrite(9,HIGH);
time2=millis();
turn++;
test2=0;
if(millis()-time2>200){
  digitalWrite(9,LOW);
bt30=digitalRead(button3);
if(bt30==HIGH && exbt30==LOW){
milis3=millis();
test3=1;
if(test3==1 && (millis()-milis3)>debounce){
bt3=digitalRead(button3);
if (bt3==HIGH){
  buttons[turn]=10;
digitalWrite(10,HIGH);
time3=millis();
turn++;
test3=0;
if(millis()-time3>200){
  digitalWrite(10,LOW);
bt40=digitalRead(button4);
if(bt40==HIGH && exbt40==LOW){
milis4=millis();
test4=1;
if(test4==1 && (millis()-milis4)>debounce){
bt4=digitalRead(button4);
if (bt4==HIGH){
  buttons[turn]=11;
digitalWrite(11,HIGH);
time4=millis();
turn++;
test4=0;
if(millis()-time4>200){
  digitalWrite(11,LOW);
if(play==1){
  for (int k=0;k<stepp; k++){
    digitalWrite(leds[k], HIGH);
    delay(300);
    digitalWrite(leds[k], LOW);
    delay(200);
  play=0;
        for(int j=0; j<turn;j++){
          if (buttons[j]!=leds[j]){
            val=(stepp-1);
            rec=EEPROM.read(0);
            if(rec>=val){
            Serial.print("Napaka, tvoj dosezek je: ");
            Serial.println(val);
            Serial.print("Rekord je: ");
            Serial.println(rec);
            if(rec<val){
            Serial.print("Dosegli ste nov rekord: ");
            Serial.println("CESTITAM!!!");
            EEPROM.write(0, val);
            glava=0;
            konec=1;
        if(turn==stepp && konec!=1){
          delay(200);
          stepp++;
          play=1;
          turn=0;
exbt10=bt10;
exbt10=bt10;
exbt20=bt20;
exbt30=bt30;
exbt40=bt40;
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I'm not sure I know where your problem lies, but can I recommend you use the Auto-format (ctrl-T) facility in the IDE before you post your code?
Code:
Mixing constant and variable declarations is a recipe for hair-loss.
« Last Edit: January 22, 2011, 08:54:43 am by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
oh sorry, and thanks for that tip. I also changed debounce time to 100ms so you have to hold button 100ms to count, but still sometimes one click counts as 2.. very rare but it does :s
Code:
#include <EEPROM.h>
int randled;
int val;
int allow=1;
int leds[50];
int buttons[50];
int button1=2;
int button2=3;
int button3=4;
int button4=5;
int bt1, bt2, bt3, bt4, exbt10, exbt20, exbt30, exbt40, bt10, bt20, bt30, bt40, milis1, milis2, milis3, milis4;
int debounce=100;
int test1=0;
int test2=0;
int test3=0;
int test4=0;
int play=1;
void setup (){
  pinMode(9,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  pinMode(4,INPUT);
  pinMode(5,INPUT);
void loop (){
  if(glava==1){
    if(allow==1){
      allow=0;
    //RECORDING BUTTONS
      milis1=millis();
      test1=1;
      if (bt1==HIGH){
        buttons[turn]=8;
        time1=millis();
        turn++;
        test1=0;
      milis2=millis();
      test2=1;
      if (bt2==HIGH){
        buttons[turn]=9;
        time2=millis();
        turn++;
        test2=0;
      milis3=millis();
      test3=1;
      if (bt3==HIGH){
        buttons[turn]=10;
        time3=millis();
        turn++;
        test3=0;
      milis4=millis();
      test4=1;
      if (bt4==HIGH){
        buttons[turn]=11;
        time4=millis();
        turn++;
        test4=0;
    if(play==1){
        delay(300);
        delay(200);
      play=0;
        val=(stepp-1);
        rec=EEPROM.read(0);
        if(rec>=val){
        if(rec<val){
        glava=0;
        konec=1;
      delay(200);
      stepp++;
      play=1;
      turn=0;
  exbt10=bt10;
  exbt10=bt10;
  exbt20=bt20;
  exbt30=bt30;
  exbt40=bt40;
Logged
Pages: [1]   Go Up
Print
Jump to:
