Loading...
Pages: [1]   Go Down
Author Topic: reading digital INPUT for 30 sec: at least one 1  (Read 2302 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi!
Problem: I have a digital input connected to a digital sensor, that of course sends 0/1.
I need to check that, in 30 seconds, there has been at least one 1.
How would you do that?
I have never used arduino's clock, timer...
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
You could just use the millis() function to track passage of time and along with proper standard code to accomplish that.
Lefty
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks!
I'm losing my mind... why does it enter in BOTH first and second "if" at the beginning, than it enters in BOTH second and third "if"?
 :o
Code:
long start;
void setup(){
  pinMode(12, OUTPUT);
void loop(){
  start = millis();
while (digitalRead(8)==LOW){
  if ((millis() - start) <= 15000){
    Serial.println("1");
    digitalWrite(12, HIGH);
    digitalWrite(12, LOW);
  if (15000 < (millis() - start) <= 30000){
    Serial.println("2);
  if ((millis() - start) > 30000){
    Serial.println("3);
    delay(150);
    delay(150);
« Last Edit: January 19, 2011, 03:27:22 pm by cioto » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Your second 'if' is legal C, but isn't sensible.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
You mean it cannot work with Arduino, right?
I've solved this way:
if ( (x>15000) && (x<30000) )
Thanks a lot ;-)
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
It depends on how short the pulses from the sensor are.  If it can send very short pulses and you don't want to miss any, polling the pin in software is not the right solution - monitoring the pin via an interrupt (pins 2 and 3 only) or using a counter is the right way.
If the pulses are long and you can guarantee to poll with digitalRead() often enough then this is a simpler solution.   pulseIn() works nicely if you don't have any other task to perform while waiting.
Another approach is to add some extra hardware to stretch or latch the pulses you are looking for, so the software doesn't have to work so hard.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
The pulses may be quite short, but I think at least 10 ms.
Thanks so much, I will check about interrupts and pulsein function.
As regards the hardware addition, I totally agree and had already thought about that: do you think a simple s-r flip flop could be ok? Which component could be used?
Thanks a lot!
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
I would run the input into an interrupt pin (if you can), then
Code:
volatile int seconds;
setup () {
   attachInterrupt(1, isr, RISING);
loop () {
   if ((millis() % 1000) == 0)
      seconds++;
   noInterrupts();
   if (seconds > 30) {
     interrupts();
     its_been_longer_than_30s();
     seconds = 0;
   interrupts();
isr () {
   seconds = 0;
______
Rob
« Last Edit: January 23, 2011, 07:33:38 am by graynomad » Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Pages: [1]   Go Up
Print
Jump to:
