Topic: Arduino Serial Monitor (Ubuntu 10.04 64bit) (Read 21774 times) previous topic - next topic
IAmCorbin
Hello,
I am just getting started with Arduino development and am having a difficult time getting it  to interface with Java. I am using Eclipse and trying to read serial data. I just noticed that I am getting the same error in Eclipse that I am getting in arduino IDE
I had been using the serial monitor in the IDE without a problem, that is up until I executed this command:
stty -F /dev/ttyUSB0 cs8 9600 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts
as directed at:  arduino.cc/playground/Interfacing/LinuxTTY
and was then able to read the serial output of the arduino via the terminal with: tail -f /dev/ttyUSB0
but at this point I noticed that I was no longer able to use the serial monitor in the IDE. This whole time I had been using arduino-0018 installed via the ppa. I tried downloading arduino-0021 and am getting the same errors, I tried the 64 bit and the 32 bit and also tried copying RXTXcomm.jar and librxtxSerial.so from rxtx2.2pre2 release into arduino-00xx/lib/
Here is what I'm stuck on:
corbin@skillTop:/usr/local/share/arduino-0021$ ./arduino
Experimental:  JNI_OnLoad called.
WARNING:  RXTX Version mismatch
     Jar version = RXTX-2.2pre1
     native lib Version = RXTX-2.1-7
RXTX Warning:  Removing stale lock file. /var/lock/LCK..ttyUSB0
Binary sketch size: 2476 bytes (of a 30720 byte maximum)
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f77df047462, pid=2020, tid=140152811636496
# JRE version: 6.0_20-b20
# Java VM: OpenJDK 64-Bit Server VM (19.0-b09 mixed mode linux-amd64 )
# Derivative: IcedTea6 1.9.2
# Distribution: Ubuntu 10.04.1 LTS, package 6b20-1.9.2-0ubuntu1~10.04.1
# Problematic frame:
# C  [librxtxSerial.so+0x6462]  read_byte_array+0x52
# An error report file with more information is saved as:
# /usr/local/share/arduino-0021/hs_err_pid2020.log
The IDE crashes at this point right as I press the serial monitor button.
anyone have any ideas?
mrtaylor
#1
Jan 23, 2011, 10:47 am Last Edit: Jan 23, 2011, 10:54 am by mrtaylor Reason: 1
When I unplug the usb cable and then plug it back in my arduino switches to a different port.
Do a stty -F /dev/ttyUSB0 -a (change to correct port).  Here is a copy of what mine looks like.
speed 9600 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>; eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S;
susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V; flush = ^O; min = 1; time = 0;
-parenb -parodd cs8 hupcl -cstopb cread clocal -crtscts
-ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr icrnl ixon -ixoff -iuclc -ixany -imaxbel -iutf8
opost -olcuc -ocrnl onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
isig icanon iexten echo echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke
IAmCorbin
#2
Jan 23, 2011, 06:37 pm Last Edit: Jan 23, 2011, 06:38 pm by IAmCorbin Reason: 1
My Arduino always connects to /dev/ttyUSB0
Here is what I get:
corbin@skillTop:~$ stty -F /dev/ttyUSB0 -a
speed 57600 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^A; eol = <undef>; eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z;
-ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff -iuclc -ixany -imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
isig -icanon iexten -echo -echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke
could the 57600 baud be what is throwing me off, since in the code I am connected to serial at 9600?
pluggy
If you unplug and reconnect quickly it will tend to allocate it a different port number.  Leaving it for a minute or two generally means it will reconnect to the same port.
http://pluggy.is-a-geek.com/index.html
IAmCorbin
no matter how fast I disconnect-reconnect it just reattaches to ttyUSB0
[ 2412.040322] ftdi_sio 7-1:1.0: device disconnected
[ 2413.070028] usb 7-1: new full speed USB device using uhci_hcd and address 9
[ 2413.276512] usb 7-1: configuration #1 chosen from 1 choice
[ 2413.284433] ftdi_sio 7-1:1.0: FTDI USB Serial Device converter detected
[ 2413.284464] usb 7-1: Detected FT232RL
[ 2413.284467] usb 7-1: Number of endpoints 2
[ 2413.284470] usb 7-1: Endpoint 1 MaxPacketSize 64
[ 2413.284472] usb 7-1: Endpoint 2 MaxPacketSize 64
[ 2413.284474] usb 7-1: Setting MaxPacketSize 64
[ 2413.286120] usb 7-1: FTDI USB Serial Device converter now attached to ttyUSB0
mrtaylor
speed 57600 baud;
It would not hurt to try. You can always change it back.
mrtaylor
Your right about the port not switching, mine does not switch unless the first port is in use. ie I open the serial monitor and then do the unplug and re-plug thing.
mrtaylor
I just did a stty -F /dev/ttyUSB0 57600
and a stty -F /dev/ttyUSB0 -a
the result:
Then I upload a sketch with a:
did another stty -F /dev/ttyUSB0 -a
the result
so i believe changing the baud rate is not going to help.  Time to look at the other configuration options that you changed in your first post.
mrtaylor
my stty option -noflsh is different from your first post
mrtaylor
#9
Jan 24, 2011, 08:42 am Last Edit: Jan 24, 2011, 09:11 am by mrtaylor Reason: 1
[edit]try running arduino as root[/edit]
if that does not work:
Let try do something really simple first upload the code:
   Serial.println("looping");
second: without unpluging the usb cable, execute the command:
screen /dev/ttyUSB0 9600
third: let us know what happens
