Topic: Sketch keeps going (Read 409563 times) previous topic - next topic
Viper98
Okay so what i'm trying to do is make an LED dice based on the tutorial HERE http://www.instructables.com/id/Arduino-Led-Dice/ The "die" rolls and displays a number between 1&6I got the sketch he wrote up and it runs perfectly. But being the tinkerer i am i wasnt satisfied. Eventually i want to involve two die on one breadboard to play a "game" of sorts. When one player wins a sound plays (right now it is set to play a sound byte from SMB) using the tone library. Right now while im troubleshooting i have it to play the tone when a 4 is rolled. The problem im having is that it will randomly pick a number and then "print" it to the die (using the "disp" function) multiple times instead of just one. This makes no visible change but when a 4 is rolled the sound will play more then once. It seems almost random how many times is is sent into the disp function but its always between 1 and 3. I'm very new to arduino and would probably consider this my first real project and I've tried everything i can think of. Any help would be much appreciated
My code isn't commented at all because its nowhere near completed but if you have question about what any part of the code does please ask.
disp(int rand)  ---  Displays the random number on the die
blank() ---  Clears the die completly turning all LEDs off
play_rtttl(char *p) --- plays the sound when called
int pin1 = 4;
int pin2 = 6;
int pin3 = 7;
int pin4 = 5;
int buttonPin = 2;
int ran;
#include <Tone.h>
Tone tone1;
#define OCTAVE_OFFSET 0
int notes[] = {
 0,
 NOTE_C4, NOTE_CS4, NOTE_D4, NOTE_DS4, NOTE_E4, NOTE_F4, NOTE_FS4, NOTE_G4, NOTE_GS4, NOTE_A4, NOTE_AS4, NOTE_B4,
 NOTE_C5, NOTE_CS5, NOTE_D5, NOTE_DS5, NOTE_E5, NOTE_F5, NOTE_FS5, NOTE_G5, NOTE_GS5, NOTE_A5, NOTE_AS5, NOTE_B5,
 NOTE_C6, NOTE_CS6, NOTE_D6, NOTE_DS6, NOTE_E6, NOTE_F6, NOTE_FS6, NOTE_G6, NOTE_GS6, NOTE_A6, NOTE_AS6, NOTE_B6,
 NOTE_C7, NOTE_CS7, NOTE_D7, NOTE_DS7, NOTE_E7, NOTE_F7, NOTE_FS7, NOTE_G7, NOTE_GS7, NOTE_A7, NOTE_AS7, NOTE_B7
char *song = "smbdeath:d=4,o=5,b=90:8p,16b,16f6,16p,16f6,16f.6,16e.6,16d6,16c6,16p,16e,16p,16c";
void setup ()
 tone1.begin(3);
 pinMode (pin1, OUTPUT);
 pinMode (pin2, OUTPUT);
 pinMode (pin3, OUTPUT);
 pinMode (pin4, OUTPUT);
 pinMode (buttonPin, INPUT);
 randomSeed(analogRead(A1));
#define isdigit(n) (n >= '0' && n <= '9')
 while(digitalRead(buttonPin)==HIGH)
   ran = random(1,7);
   for(int x = 1;x<=3;x++){
     blank();
     if(x==1){
       digitalWrite(pin2,HIGH);
     if(x==2){
       digitalWrite(pin3,HIGH);
       digitalWrite(pin1,HIGH);
     if(x==3){
       digitalWrite(pin4,HIGH);
     delay(45);
     if(digitalRead(buttonPin)==LOW)
       blank();
       disp(ran);
void disp(int rand)
 switch(rand)
 case 1:
   digitalWrite (pin4, HIGH);
   break;
 case 2:
   digitalWrite (pin1, HIGH);
   break;
 case 3:
   digitalWrite (pin3, HIGH);
   break;
 case 4:
   break;
 case 5:
   break;
 case 6:
   digitalWrite (pin2, HIGH);
   break;
 if(rand == 4)
   play_rtttl(song);
void blank()
 digitalWrite(pin1,LOW);
 digitalWrite(pin2,LOW);
 digitalWrite(pin3,LOW);
 digitalWrite(pin4,LOW);
void play_rtttl(char *p)
 byte default_dur = 4;
 byte default_oct = 6;
 int bpm = 63;
 int num;
 long wholenote;
 long duration;
 byte note;
 byte scale;
 while(*p != ':') p++;
 p++;
 if(*p == 'd')
   p++;
   p++;              // skip "d="
   num = 0;
   while(isdigit(*p))
     num = (num * 10) + (*p++ - '0');
   if(num > 0) default_dur = num;
   p++;                   // skip comma
 if(*p == 'o')
   p++;
   p++;              // skip "o="
   num = *p++ - '0';
   if(num >= 3 && num <=7) default_oct = num;
   p++;                   // skip comma
 if(*p == 'b')
   p++;
   p++;              // skip "b="
   num = 0;
   while(isdigit(*p))
   bpm = num;
   p++;                   // skip colon
 wholenote = (60 * 1000L / bpm) * 4;
 while(*p)
   num = 0;
   while(isdigit(*p))
   if(num) duration = wholenote / num;
   else duration = wholenote / default_dur;  // we will need to check if we are a dotted note after
     // now get the note
   note = 0;
   switch(*p)
   case 'c':
     note = 1;
     break;
   case 'd':
     note = 3;
     break;
   case 'e':
     note = 5;
     break;
   case 'f':
     note = 6;
     break;
   case 'g':
     note = 8;
     break;
   case 'a':
     note = 10;
     break;
   case 'b':
     note = 12;
     break;
   case 'p':
   default:
     note = 0;
   p++;
   // now, get optional '#' sharp
   if(*p == '#')
     note++;
     p++;
   // now, get optional '.' dotted note
   if(*p == '.')
     duration += duration/2;
     p++;
   // now, get scale
   if(isdigit(*p))
     scale = *p - '0';
     p++;
     scale = default_oct;
   scale += OCTAVE_OFFSET;
   if(*p == ',')
     p++;       // skip comma for next note (or we may be at the end)
   // now play the note
   if(note)
     tone1.play(notes[(scale - 4) * 12 + note]);
     delay(duration);
     tone1.stop();
     delay(duration);
bubulindo
I'd say this has something to do with the way you read your keypad. Have you tried with longer presses on the input button and shorter ones?
Debouncing the key is another thing... I don't see any debounce code and that may well be what's happening to you.
This... is a hobby.
