Topic: BEGINNERS: Think of everything as a function() (Read 3831 times) previous topic - next topic
lastchancename
Aug 27, 2017, 12:42 am Last Edit: Aug 27, 2017, 12:45 am by lastchancename
When you start writing a sketch, a good starting point is to consider each part of you problem as a *separate* function()
For example, checking a switch/sensor/button to turn on an output for 2-seconds...
At the top of your sketch, before setup - declare all your 'global' variables to be shared across other functions.
void setup() will initialise all your variables to their starting values.
Within loop() make a call to determine the input state... e.g. getInputState()
That function should take care of *everything* associated with polarity, debounce (and anything else) related to detecting the input state.
With that input state *known*, you can make a confident, well informed decision whether to trigger the output pin(s).
If it's more than just on/off, you might implement another function setOutputState().
That will also isolate the requirements of output polarity and 'start time' if needed.
In loop(), calling another checkOutputState() may be use millis() to turn the outputs off/on relative to setOutputState()
In pseudo-code this looks like -
Code: [Select]
bool inputState;
unsigned long outputMillis;
  // set pin directions
  // set initial values
  getInputState();  // check the input pin(s)
  if (inputState != prevInputState) { // input has changed state
    setOutputState();  // set outputs and start millis() timer if needed
    prevInputState = inputState;  // keep a copy of previous input state
  checkOutputState();  // if millis() has elapsed - reset affected outputs
// you need to write the in/out functions to suit your project!
It's that easy!   And to isolate, fix or replace each function separately - do exactly that - without affecting the functionality of everything else.
e.g for debugging, if you think the code is faulty, simply comment out that line, and assign a temporary value to test the rest of the code.
Of course, there is more to the actual code required above (not much), but it was left out so you can see how to isolate your logic for faster debugging.
*Keep backups between edited versions!*
Experienced responders have a nose for laziness, (they were beginners once)... expecting the poster to contribute to the learning experience.
econjack
Pretty similar to the Five Program Steps. See #12 here.
Jiggy-Ninja
#2
Aug 27, 2017, 04:57 am Last Edit: Aug 27, 2017, 04:57 am by Jiggy-Ninja
Oh how I wish the person that created my team's most mission-critical piece of software was a believer of this philosophy. Based on Excel macros (a nightmare in and of itself with regards to exception handling), I saw one function with over 800 lines and 9 levels of Hell indentation.
And did I mention no comments? It is like staring into an abyss of madness.
Hackaday: https://hackaday.io/MarkRD
Advanced C++ Techniques: https://forum.arduino.cc/index.php?topic=493075.0
econjack
One time I did a consulting job and came across a 31-level deep cascading if statement; one for each day of the month. Each day there was a batch job using that code for about 7 million bank customers, each of which had to, on average, fall through 15 false conditions rather than use a switch/case. In a code walk-through programmers meeting, I pointed this out as one of the best examples of RDC (i.e., Really Dumb Code) I had ever seen. I noticed several programmers cringe when I said it. I was fired the next day. Evidently the person who hired me also wrote the code.
lastchancename
I had a friend working with a very large bank (in their Oracle team), and some of the code they were using was really poor quality first year stuff.
But the people that 'care' can't get a job!
kenwood120s
This and your other BEGINNER thread here are good stuff, and I'm wondering if there's not a better place / way to publish them? First they're not questions, but answers ;) but more importantly threads by the very nature of a forum rise and fall in the index with time.
Pinning might be an option, but then a) there are loads of (unread?) pins here already and b) you might be planning a series of dozens of BEGINNERS chats.
Sorry I don't have a suggestion, but can't help thinking this way isn't the best one.
[gumby]I've got my head stuck in the cupboard[/gumby]
westfw
"What's a function?"
I mean, it's fine advice, but functions are a relatively advanced concept in programming, especially for the arduino target audience - we regularly see questions like "how can I make another void, like loop?"
lastchancename
#7
Aug 27, 2017, 07:51 am Last Edit: Aug 27, 2017, 07:52 am by lastchancename
A valid question, but I was trying to keep the OP as short but complete as possible.
Feel free to post a new BEGINNERS: What is a function? thread that describes functions - calling, return values etc.
Maybe I'll do one if no-one else does! (9K posts - you have plenty of spare time...!  :))
kenwood120s
Functions are already adequately described on this very site, right here.
larryd
The function of a function is to do some function.
No technical PMs.
The last thing you did is where you should start looking.
Robin2
#10
Aug 27, 2017, 10:17 am Last Edit: Aug 27, 2017, 10:18 am by Robin2
I hope I have given some basic guidance on this in Planning and Implementing a Program which @econjack was kind enough to link to in Reply #1
IMHO adult education can be very challenging because the "teacher" cannot dictate a program of lessons that must be followed one after the other with a test at the end.
My approach is to provide a simple but not trivial example in the hope that it may expose the reader to some techniques that s/he may find useful - if only to cause them to say "what do you mean by that?"
A big problem for an adult beginner in any subject is not knowing the arcane jargon used by the experts. Computer science is no different from Law or Accounting in that respect. And I have often been amazed at how otherwise well-educated and (apparently) intelligent people are afraid to say "I don't understand"
...R
PS it is much worse when experts are not prepared to say "I don't know" when asked a question in their own field of knowledge :)
Two or three hours spent thinking and reading documentation solves most programming problems.
BulldogLowell
...functions are a relatively advanced concept in programming, especially for the arduino target audience ...
Hmmm...
they a basic part of every language; certainly not an advanced concept.
lastchancename
#12
Aug 27, 2017, 04:37 pm Last Edit: Aug 27, 2017, 04:38 pm by lastchancename
""functions are a relatively advanced concept in programming, especially for the arduino target audience""
And that's exactly why i didn't go in too deep!
Show simple functions in context, then encourage the newbies explore and discover.
If they aren't willing to do the work, then send 'em back to primary, with plywood, batteries, bulbs and spring terminals!
gpop1
+1
I have to agree. Sometimes the best advice is bad advice to new people.
make everything a global is a perfect example.
The people who want to learn code will learn. The people who just want to make a led flash are more interested In the end result and are already struggling learning the basics of electronics so why complicate things to the point that they want to quit.
I know some people especially the ones who have a back ground in c++ believe that you either write it correctly or you should quit.
 I believe this is a open forum so you have to realize that there's going to be some newbees that really need mentoring rather than a instructor. Telling them there code is jacked isn't assisting.
Had I found this forum when I started to learn I would probably have considered that it was to much of a hassle to learn and a lot of people on here are arse holes.
 I still wouldn't dare post my first 2000 line code that's been running a incubator for the last 2 years and hatched 100's of chicks.
Respect to the guys that can code especially the ones that can write a dumb code 100's of lines long that are designed to be read by a newbee when I know they could have just typed a few lines that would take a newbee a week to understand.
Robin2
#14
Aug 27, 2017, 06:14 pm Last Edit: Aug 27, 2017, 06:19 pm by Robin2
+1 for Reply #13
Most of my Arduino programs use global variables for most things.
There is a huge difference between one person writing programs on his/her own and working as part of a team of programmers.
And I am a firm believer in the value of using functions. The challenge is to get the concept across to a newbie without alienating him/her in the process. Rapping knuckles with a wooden ruler does not work to incentivize adults :)
...R
