Topic: Flash cs4 analogue input (Read 897 times) previous topic - next topic
davewink
Hi I'm currently working of the the io example in the as3 glue folder.
At the moment the numbers in output channel change in Flash when I twist the potentiometer.
I am looking for some sort of Flash code that will trigger an onscreen action in Flash when the potentiometer is turned?
So that a contrast/alpha effect could be changed or even a movie clip can be played when the potentiometer is turned.
Any ideas?
Photo-Worx
First of all, This is not the proper place to post this.
Second, It is RUDE to post in multiple forum areas with the same question!
You will not get any answers by cross posting, only complaints.
davewink
No problem, which part of the forum do you recommend that I post my query on then?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
