Topic: add a test area (Read 998 times) previous topic - next topic
jerryb
adding a test area would allow someone to test adding code and images
thanks
like this
yeaa after 6 trys I got it!
now how to insert code?
Code: [Select]
#include <SoftwareSerial.h>
// if you myserial.print and get garbage tect try this.
// not all LCD's run at the expected speed use this to test yours
#define rxPin 4  // rxPin is immaterial - not used - just make this an unused Arduino pin number
#define txPin 12 // pin 12 is analog pin 0, on a BBB just use a servo cable :), see Reference pinMode
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
// mySerial is connected to the TX pin so mySerial.print commands are used
// one could just as well use the software mySerial library to communicate on another pin
int baud=300;// starting point
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  mySerial.begin(4800);      // maybe it is maybe it isn't
  delay(1000);               // pause to allow LCD EEPROM to program
   mySerial.print("?f");
   mySerial.print("LCD117");
   mySerial.print("it is about");
   mySerial.print("time");
 mySerial.begin(baud);      // test each speed
  delay(4000);               // pause to allow LCD EEPROM to program
   delay(4000);
   mySerial.print("baud= ");
   mySerial.print(baud);
   delay(4000);
   delay(200);
   baud = (baud*2); // increae baud until readable
ok that works
PaulS
You know there is a Preview button next to the Post button, right? That show what your post is going to look like when you press the Post button.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
