Author Topic: Report dead links from wiki pages.  (Read 1901 times)
The Netherlands
don't panic...
Well, the title says it all. Browsing the playground i encountered some dead links but i'm not comfortable editing wiki pages (yet).
What i can do at the moment is make a list with the dead links i found. Would anyone be interested?
regards,
Jeroen
« Last Edit: May 19, 2010, 05:48:11 am by Yot » Logged
North Yorkshire, UK
Yeah I have found some before but there are always issues if the intended page is not there anymore...
If you make a list then someone might go through and change them. A list will help anyway as it will be known that there are broken links.
This thread is now about broken playground links. If I find any I will stick them on here  smiley
Mowcius
The Netherlands
don't panic...
Nice idea. Bit like the routine on spam. Changed the title.
Jeroen
The Netherlands
don't panic...
on page http://www.arduino.cc/playground/CourseWare/DigitalIO
References & Examples
    * Basic digital output: blinking an LED (Hello World)
          o http://www.arduino.cc/en/Tutorial/BlinkingLED
[glow]          o http://www.arduino.cc/en/uploads/Booklet/Arduino_booklet02.pdf - pg23
          o Schematic: http://www.csulb.edu/~bevans2/schematics/hellowworld.jpg[/glow]
          o About the LED http://www.kpsec.freeuk.com/components/led.htm
    * Basic digital input: pushbutton or switch
          o http://www.arduino.cc/en/Tutorial/Pushbutton
[glow]          o http://www.arduino.cc/en/uploads/Booklet/Arduino_booklet02.pdf - pg30
          o Schematic: http://www.csulb.edu/~bevans2/schematics/digitalinput.jpg[/glow]
    * High current output: MOSFET (motor, light, multiple LEDs)
[glow]          o http://www.arduino.cc/en/uploads/Booklet/Arduino_booklet02.pdf - pg41
          o Schematic: http://www.csulb.edu/~bevans2/schematics/mosfet.jpg[/glow]
    * Relay (or preferably Solid State Relay)
[glow]          o Schematic: http://www.csulb.edu/~bevans2/schematics/relay.jpg[/glow]
highlighted are no longer available.
Don't know if just deleting the entries without replacing the information is a wise thing to do.
Jeroen
Norway@Oslo
loveArduino(true);
Maybe we could remove the anchor and mark the text with strikethrough?
anold.example.com/abused
That way they're easy to spot, and if someone have a fix, it is easy to fix as well.
« Last Edit: June 01, 2010, 03:28:39 pm by AlphaBeta » Logged
The Netherlands
don't panic...
The links mentioned in reply 3 are now in red text.
I've tried strikethrough but links to pictures (.gif, .jpg, or .png files) don't display at all with strikethrough.
So instead of adding text after those links it now looks like the page is not there as red wiki links to non existent pages are red.
Jeroen
