Topic: Shield Pin Usage Table (Read 17915 times) previous topic - next topic
bld
Wouldn't be that difficult to make a system for that, problem is again just that it is not located on this site.
captain-slow.dk | non contagious!
mowcius
It could be linked to this site. I do feel that this site is in need of a major makeover though.
Mowcius
bld
#17
Jun 07, 2010, 08:26 pm Last Edit: Jun 07, 2010, 09:35 pm by bld Reason: 1
Trying to put something simple together...
System that shows the added shields
http://k8055.info/arduino/
Now to make the function that can check if there are multiple on the same pin.
And the system is almost done. The first shield will be reference for the following, and they will then be marked with red if they already are used, or marked with green if there are optional positions.
Some of the next will be to make the function where it is possible to select which shields you want to stack.
bld
And it is working, so far.
Haven't done anything to it regarding layout, only made the function.
mowcius
That seems to function well so far :)
I will watch this thread with interest...
Mowcius
bld
Adding the option to easy add new shields to it tomorrow. :)
bhagman
Nice job!  I like it.
Maybe if we talk real nicely to David C., maybe he'll put it up somewhere on the site?  The issues will be code/data maintenance, and spam prevention.
If not, maybe one of us will work out a site where it can stay permanent.
Can you have the source available somewhere too (when you're ready)? (e.g. Google Code)
b
http://wiring.org.co/ - Wiring - Where Arduino came from. (Wiring begat Arduino)
http://loftypremises.com/ - Everything you wanted to know about me.... and less
http://roguerobotics.com/ - #1 Canadian Arduino distributor
mowcius
Quote
Well I just saved the web page and have been having a bit of a personal play with it. Not got too far yet but it is nicely done.
Mowcius
bld
Dont know when my version of it will be avalible. Might first be when I add the add function, and change the code layout.
sasaa
#24
Jun 24, 2010, 06:31 pm Last Edit: Jun 24, 2010, 06:35 pm by sasaa Reason: 1
what do you code it in html or php? you could use mysql database with all the shields...
and use php to notify of pin useage.
+ a adding system would be a simple as a few <input> fields
i can try to come up with something and post it on my website.
i really want to have a new webpage project.
maybe go trough with the arduino sketchs/library upload site and add this to.
if it ok with you i'll use your code.
bld
#25
Jun 24, 2010, 08:15 pm Last Edit: Jun 24, 2010, 08:53 pm by bld Reason: 1
I am making it in asp, still learning php, and also using a mysql database with all the shields info in, just been a bit busy so i havent finished the add function yet
Just made a little fast page for adding shields http://k8055.info/arduino/add.asp no design on that either, but it should work :)
sasaa
functionality first layout later! :P
asp is not in my Vocabulary...
