Topic: How do I gain privileges in the playground? (Read 5576 times) previous topic - next topic
lovius
I my be wrong about this:
http://www.arduino.cc/playground/ComponentLib/Servotimetimer1 should be updated.
It does not work for the Atmega168 because line '#include  <wiring.h>' needs moving from the *.h file into the *.cpp file
like
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1239820770/4#4
But I get this error when I try to add this fix to the Playground!
Insufficient privileges to perform action.
Any ideas?
PaulS
#1
Jul 17, 2010, 03:49 am Last Edit: Jul 17, 2010, 03:51 am by PaulS Reason: 1
You need a separate account to edit the playground.
On the left side of the playground pages, there is a section called Participate, with a link under that to create an account.
By the way, there are no .h or .cpp files on the page you linked to. Just a sketch. Which .h or .cpp files are you referring to? What changes do you propose to make to that page?
lovius
Well in order to use the ServoTimeTimer1 library you have to move the line #include <wiring.h> from ServoTimeTimer1.h and place it the line after the  #include <avr/interrupt.h> line in the ServoTimeTimer1.cpp
or you get the cryptic error:
/usr/lib/gcc/avr/4.3.4/../../../avr/include/stdlib.h:111: error: expected `)' before 'int'
PaulS
This appears, then, to be a bug in the ServoTimeTimer1 library, rather than a problem with the Wiki page.
While the workaround should be documented until the library is fixed, you should also create a thread in the Software Bugs and Suggestions section, and/or try to contact the library author to get the library fixed, so the workaround is not needed.
laxman098
