Topic: Reading RPM Playground code error (Read 4176 times) previous topic - next topic
Newman180
I believe I found an error in the code for reading RPM on a cpu fan
http://www.arduino.cc/playground/Main/ReadingRPM
Code: [Select]
if (rpmcount >= 20) {
    //Update RPM every 20 counts, increase this for better RPM resolution,
    //decrease for faster update
    rpm = 30*1000/(millis() - timeold)*rpmcount;
    timeold = millis();
    rpmcount = 0;
    Serial.println(rpm,DEC);
The code
Code: [Select]
Should be
Code: [Select]
rpm = 30*1000/((millis() - timeold)/rpmcount);
OR
Code: [Select]
rpm = (30*1000/(millis() - timeold))*rpmcount;
The theory behind it...
The current code says that if it takes 100 millis between each pulse, and your counting 10 pulses :
30000/1000 = 30 RPM
Using the same code, if you double the counting pulses to 20 which would also double the time to 200 millis :
30000/4000 = 7.5 RPM
These values should match
Using the corrected code:  100 millis  10 pulses
30000(10)/100 = 3000 RPM
Using corrected code: 200 millis 20 pulses
30000(20)/200 = 3000 RPM
Now they match.
I'm new to this, so if I'm wrong, speak up!
Thanks,
Austin
