Topic: XBee Shield + GPS Shield = Gibberish? (Read 8166 times) previous topic - next topic
strange quark
Hi all,
I'm relatively new to Arduino, and I am trying to get a project up and running using an Uno board, a (SparkFun) XBee and GPS shield. I'm using an XBee series 1 and an EM-406a. The XBee communicates to my computer using the SparkFun USB Explorer board over digital ports 1 and 2 (uart). My GPS is set to dline and I have it communicating over ports 2 and 3 using the newsoftserial library.
My program for the Arduino works fine if I connect to the board over USB or if I have the XBee shield stacked directly on top of the Uno. But, I'd like to put the XBee shield on top of the GPS shield so that I can easily switch the XBee off uart to program the Arduino. But, if I stack the shields like that, after the 3rd command I send to the Arduino from my computer, I get never ending gibberish in the terminal that vaguely resembles what it should output.
Anyone know what's going on here? It doesn't make sense that the order I stack the shields in should drastically alter the way my project works, does it? Thanks all!
jezuz
What does the 3rd command do? Also, you said you use 1+2 for xbee and 2 + 3 for gps. Do you mean 0+1 and 2+3?
strange quark
Oops, yes. I mean 0 and 1 (the default TX and RX ports).
And it's not always the third command (that's just an average, I guess). It could be before or after; I'm not sure what triggers the gibberish. But I can send it anything. My commands aren't definite. I'm sending it keystrokes through a Mac program I wrote. But again, if I plug in the USB cable and bypass the XBee or if I stack the boards Arduino -> XBee shield -> GPS shield it works fine. It's just when I put it Arduino -> GPS shield -> XBee shield that it gets messed up. Unfortunately, I need the XBee shield up top so that I can easily switch the shield from dline to uart when I need to reprogram the Arduino.
jezuz
I'm afraid I can't help much there, you'll have to wait for more people to show up on the new forum. I would suggest checking to see if anything shorts (perhaps a brought out pin header on your gps shield touching the bottom of the xbee shield?)
Also, this might be happening when you flip the xbee/dline switch - try reproducing this error with the arduino -->xbee --> gps setup, that way you can be sure it isn't electrical.
Or, maybe your gps is getting interference underneath the xbee.
zonedabone
Try disabling the communication with the xbee sheild for a bit. Now, put LEDs on the serial out to where the xbee shield would be connected. See if you get any blinking.
If you do, consider moving the connections to another port if you can.
OR...
Are you sure that the software serial ports 2 and 3 are connected to the serial ports on the xbee shield, or is it connected to the gps shield? Given that you have a somewhat matching signal, it probably isn't this.
strange quark
#5
Jan 26, 2011, 04:55 am Last Edit: Jan 26, 2011, 04:57 am by brian515 Reason: 1
Thanks for the suggestion. Unfortunately, I don't have any LEDs to play around with, although I suppose I could pick a couple up at Radioshack if necessary.
However, I can reproduce the error when I connect the XBee directly to the Arduino, but it takes a lot longer to get it. It seems like I get the random repeating gibberish when the XBee drops a packet, which for some reason it does a lot more when I have the GPS attached. Just to check, can someone check and make sure I'm reading the Serial port correctly?
From my loop function:
Code: [Select]
if(Serial.available() >0) {
   if(index < 19) // One less than the size of the array
     inChar = Serial.read(); // Read a character
     inData[index] = inChar; // Store it
     index++; // Increment where to write next
     inData[index] = '\0'; // Null terminate the string
The only other thought I have is that maybe there isn't enough power to run both the XBee and GPS and that's why it keeps dropping packets. I'm running the whole thing through a 9V battery hooked up to the bullet connector on the Arduino.
strange quark
Okay, I think I've solved it!   :)
I was placed a closing curly brace too late in my loop function so that when the serial input was 0, it would kick out of the if statement, but continue the loop function and mess with my variables. :smiley-red: Ugh, all that time wasted...
Thanks for the help anyways!
jezuz
PaulS
You should be reading the serial data using a while loop, not an if test. On every pass through loop() (or whatever function that snippet was culled from), you want to read all pending serial data, not just the next byte.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
