« Reply #15 on: February 01, 2011, 09:42:38 pm » |
I'm baffled by this one. I tried to compile GCC 4.5.2 on Ubuntu but just got too many errors. I also tried to install Arch Linux but Virtualbox was not cooperating, so gave up on that too.
Are either of you able to disassemble the object file and see what the compiler is doing to the delay function?
I wonder if the compiler is misconfigured or picking up a delay function from some other header somewhere... Does Arch set any environment variables that might interfere with GCC, like CFLAGS, CXXFLAGS, C_INCLUDE_PATH, CPLUS_INCLUDE_PATH and LIBRARY_PATH ?
Brisbane, Australia
B.E.E. / B.Inf.Tech.
« Reply #16 on: February 02, 2011, 04:21:45 am » |
Hi stimmer, None of those environment variables seem to be set: ┌─[igor]──[X201] └─[~]$ echo $PATH /usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/java/bin:/opt/java/db/bin:/opt/java/jre/bin:/usr/bin/core_perl:/usr/local/bin:/usr/local/bin ┌─[igor]──[X201] └─[~]$ echo $CFLAGS
┌─[igor]──[X201] └─[~]$ echo $C_INCLUDE_PATH
┌─[igor]──[X201] └─[~]$ echo $C_PLUS_INCLUDE_PATH
┌─[igor]──[X201] └─[~]$ echo $LIBRARY_PATH
I'll dive into the issue in more detail as soon as I get some free time. I just updated Arch linux and saw it pulled a new gcc in, so I will recompile the sketches and see if anything changes. If I can't figure anything out, I'll get in touch with the Arch linux arduino package maintainer and let him know about this issue, since it seems to be Arch specific. Cheers, -Igor
« Reply #17 on: February 02, 2011, 03:45:11 pm » |
Could you try doing a disassembly of the delay function? Load up the Blink sketch, then hold down shift as you click Verify, then look in the box at the bottom for the temporary directory it uses. In a terminal, type cd /tmp/buildnnnnnnnnnnn.tmp (where buildnnnnnnnnnnnn.tmp is the temporary directory as above) Then type avr-objdump -S Blink.cpp.elf Then find the <delay> symbol and cut and paste it from there up to the next symbol and post it here, it should look like this: 000004c4 <delay>:
void delay(unsigned long ms) { 4c4: ef 92 push r14 4c6: ff 92 push r15 4c8: 0f 93 push r16 4ca: 1f 93 push r17 4cc: cf 93 push r28 4ce: df 93 push r29 4d0: 7b 01 movw r14, r22 4d2: 8c 01 movw r16, r24 uint16_t start = (uint16_t)micros(); 4d4: 0e 94 3c 02 call 0x478 ; 0x478 <micros> 4d8: eb 01 movw r28, r22 4da: 0e c0 rjmp .+28 ; 0x4f8 <delay+0x34>
while (ms > 0) { if (((uint16_t)micros() - start) >= 1000) { 4dc: 0e 94 3c 02 call 0x478 ; 0x478 <micros> 4e0: 6c 1b sub r22, r28 4e2: 7d 0b sbc r23, r29 4e4: 68 5e subi r22, 0xE8 ; 232 4e6: 73 40 sbci r23, 0x03 ; 3 4e8: c8 f3 brcs .-14 ; 0x4dc <delay+0x18> ms--; 4ea: 08 94 sec 4ec: e1 08 sbc r14, r1 4ee: f1 08 sbc r15, r1 4f0: 01 09 sbc r16, r1 4f2: 11 09 sbc r17, r1 start += 1000; 4f4: c8 51 subi r28, 0x18 ; 24 4f6: dc 4f sbci r29, 0xFC ; 252
void delay(unsigned long ms) { uint16_t start = (uint16_t)micros();
while (ms > 0) { 4f8: e1 14 cp r14, r1 4fa: f1 04 cpc r15, r1 4fc: 01 05 cpc r16, r1 4fe: 11 05 cpc r17, r1 500: 69 f7 brne .-38 ; 0x4dc <delay+0x18> if (((uint16_t)micros() - start) >= 1000) { ms--; start += 1000; } } } 502: df 91 pop r29 504: cf 91 pop r28 506: 1f 91 pop r17 508: 0f 91 pop r16 50a: ff 90 pop r15 50c: ef 90 pop r14 50e: 08 95 ret
00000510 <init>:
« Last Edit: February 02, 2011, 03:47:52 pm by stimmer »
Auburn, CA, USA
Arduino pebbles
« Reply #18 on: February 02, 2011, 09:47:01 pm » |
None of those environment variables seem to be set: None of those variables should be set normally; the makefile sets them, and they basically are only set while make is running (i.e. during the build process).
« Reply #19 on: February 03, 2011, 01:52:20 am » |
Hi, I'm having the same problem Igor86 describes... Arduino Uno, Arch Linux 64-bit, avr-gcc version 4.5.2. Here's my disassembly of the standard example Blink sketch as Stimmer requested 00000210 <delay>:
void delay(unsigned long ms) { 210: ef 92 push r14 212: ff 92 push r15 214: 0f 93 push r16 216: 1f 93 push r17 218: cf 93 push r28 21a: df 93 push r29 21c: 7b 01 movw r14, r22 21e: 8c 01 movw r16, r24 uint16_t start = (uint16_t)micros(); 220: 0e 94 e2 00 call 0x1c4 ; 0x1c4 <micros> 224: eb 01 movw r28, r22
while (ms > 0) { 226: 0f c0 rjmp .+30 ; 0x246 <delay+0x36> if (((uint16_t)micros() - start) >= 1000) { 228: 0e 94 e2 00 call 0x1c4 ; 0x1c4 <micros> 22c: 6c 1b sub r22, r28 22e: 7d 0b sbc r23, r29 230: 83 e0 ldi r24, 0x03 ; 3 232: 68 3e cpi r22, 0xE8 ; 232 234: 78 07 cpc r23, r24 236: 38 f0 brcs .+14 ; 0x246 <delay+0x36> ms--; 238: 08 94 sec 23a: e1 08 sbc r14, r1 23c: f1 08 sbc r15, r1 23e: 01 09 sbc r16, r1 240: 11 09 sbc r17, r1 start += 1000; 242: c8 51 subi r28, 0x18 ; 24 244: dc 4f sbci r29, 0xFC ; 252
while (ms > 0) { 246: e1 14 cp r14, r1 248: f1 04 cpc r15, r1 24a: 01 05 cpc r16, r1 24c: 11 05 cpc r17, r1 24e: 61 f7 brne .-40 ; 0x228 <delay+0x18> if (((uint16_t)micros() - start) >= 1000) { ms--; start += 1000; } } } 250: df 91 pop r29 252: cf 91 pop r28 254: 1f 91 pop r17 256: 0f 91 pop r16 258: ff 90 pop r15 25a: ef 90 pop r14 25c: 08 95 ret
0000025e <init>:
I notice at offset 226 above the rjmp looks like it's inside the while (ms > 0) { } and at offsets 230-234 things are handled slightly differently, but my reading of the assembly language isn't good enough to tell me what that means Hope this is helpful as I'd really like to be programming my new Arduino Uno from my Arch system too! Thanks to Stimmer for looking into this problem.
Brisbane, Australia
« Reply #20 on: February 03, 2011, 03:23:02 am » |
Hi, Here is my dissassmebled code as requested: 000002fc <delay>:
void delay(unsigned long ms) { 2fc: ef 92 push r14 2fe: ff 92 push r15 300: 0f 93 push r16 302: 1f 93 push r17 304: cf 93 push r28 306: df 93 push r29 308: 7b 01 movw r14, r22 30a: 8c 01 movw r16, r24 uint16_t start = (uint16_t)micros(); 30c: 0e 94 58 01 call 0x2b0 ; 0x2b0 <micros> 310: eb 01 movw r28, r22
while (ms > 0) { 312: 0f c0 rjmp .+30 ; 0x332 <delay+0x36> if (((uint16_t)micros() - start) >= 1000) { 314: 0e 94 58 01 call 0x2b0 ; 0x2b0 <micros> 318: 6c 1b sub r22, r28 31a: 7d 0b sbc r23, r29 31c: 83 e0 ldi r24, 0x03 ; 3 31e: 68 3e cpi r22, 0xE8 ; 232 320: 78 07 cpc r23, r24 322: 38 f0 brcs .+14 ; 0x332 <delay+0x36> ms--; 324: 08 94 sec 326: e1 08 sbc r14, r1 328: f1 08 sbc r15, r1 32a: 01 09 sbc r16, r1 32c: 11 09 sbc r17, r1 start += 1000; 32e: c8 51 subi r28, 0x18 ; 24 330: dc 4f sbci r29, 0xFC ; 252
while (ms > 0) { 332: e1 14 cp r14, r1 334: f1 04 cpc r15, r1 336: 01 05 cpc r16, r1 338: 11 05 cpc r17, r1 33a: 61 f7 brne .-40 ; 0x314 <delay+0x18> if (((uint16_t)micros() - start) >= 1000) { ms--; start += 1000; } } } 33c: df 91 pop r29 33e: cf 91 pop r28 340: 1f 91 pop r17 342: 0f 91 pop r16 344: ff 90 pop r15 346: ef 90 pop r14 348: 08 95 ret
0000034a <init>:
Thanks heaps for looking into this stimmer! Helping others like you have is certainly good karma! Cheers, -Igor
« Reply #21 on: February 03, 2011, 09:39:42 am » |
Well, that disassembly looks correct, it's slightly different to mine but not significantly. Could you disassemble it again and post the entire disassembly? I am wondering if something is clobbering r1 (which should usually be zero) or if an ISR is clobbering something else, the only way to find out is to look through the whole lot
« Reply #22 on: February 03, 2011, 01:32:37 pm » |
OK... I finally managed to install Arch linux on Virtualbox and I think I'm getting to the bottom of this. It appears that the Arch compiler sometimes generates code that writes to addresses before the start of memory. RAM starts at address 0x200 on the mega, but the Blink code has the delay() timer variables located at 0x100-0x10b. This only seems to happen when the code contains no initialised global variables (.data segment in asm-speak) - the linker is told that the data segment starts at 0x200, but if there's nothing to go in it it generates an incorrect start address for the uninitialised global variables (.bss segment). Since the timer variables are uninitialised globals (or globals initialised to zero) they end up at an illegal address. Here's my blink code that worked, with an initialised global. Could you test this and tell me if it is at the correct speed? char dummyvariablecuzmaintainerborkedthecompiler = 123; // force something into the .data segment with non-zero initializer /* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */
void setup() { dummyvariablecuzmaintainerborkedthecompiler++; // stops the linker from removing the global variable // initialize the digital pin as an output. // Pin 13 has an LED connected on most Arduino boards: pinMode(13, OUTPUT); }
void loop() { digitalWrite(13, HIGH); // set the LED on delay(1000); // wait for a second digitalWrite(13, LOW); // set the LED off delay(1000); // wait for a second }
Any code that uses the Serial class won't be affected by this, as Serial contains an initialised global.
« Last Edit: February 03, 2011, 01:39:35 pm by stimmer »
« Reply #23 on: February 03, 2011, 06:41:57 pm » |
Wow, well the Blink sketch with global var inserted functions correctly for me! Compiles and uploads fine and the led blinks on and off at the correct rate on the Uno. Will be interesting to know how this tests out for Igor's Mega 1280 as well as Uno board and Aleks' various boards on 32 bit Arch... As an arduino newbie I'm not sure where to go next with this but it seems it is an Arch specific problem? char dummyvariablecuzmaintainerborkedthecompiler = 123; LOL Seriously the Arch maintainers are doing a great job, from what I can tell there's still issues with the Arduino IDE distribution containing 32bit rxtx but there is rxtx replacement in AUR (Arch User Repos) But this problem sounds like it will be with gcc-avr, gcc-binutils or something? I strongly agree with Igor's statement that: Open source hardware should have a good IDE implementation for open source software, no? and the kind of help Stimmer, Dafid et al are providing on this forum will no doubt be invaluable for getting Arduino stable on Arch's rolling releases insofar as that's possible ]  I'm following with interest and I guess this will filter over to the Arch forums or bug reports as it develops...?
« Reply #24 on: February 03, 2011, 08:02:24 pm » |
Yes, it sounds like an Arch specific problem at the moment. Maintaining a cross compiler is probably one of the harder jobs, they are a pain to compile and bug reports are hard to replicate. A potential solution has been posted in another thread by dsh1. This involves downgrading to GCC 4.3.5 and applying Debian patches: http://arduino.cc/forum/index.php/topic,51000.msg363998.html#msg363998Can people try this and see if it works?
« Reply #25 on: February 05, 2011, 07:23:22 pm » |
Yes, it sounds like an Arch specific problem at the moment. Maintaining a cross compiler is probably one of the harder jobs, they are a pain to compile and bug reports are hard to replicate. A potential solution has been posted in another thread by dsh1. This involves downgrading to GCC 4.3.5 and applying Debian patches: http://arduino.cc/forum/index.php/topic,51000.msg363998.html#msg363998Can people try this and see if it works? I just thought I would mention that I'm having this problem with Gentoo as well. I'm using: $ avr-gcc -v Using built-in specs. Target: avr Configured with: /var/tmp/portage/cross-avr/gcc-4.3.3-r2/work/gcc-4.3.3/configure --prefix=/usr --bindir=/usr/i686-pc-linux-gnu/avr/gcc-bin/4.3.3 --includedir=/usr/lib/gcc/avr/4.3.3/include --datadir=/usr/share/gcc-data/avr/4.3.3 --mandir=/usr/share/gcc-data/avr/4.3.3/man --infodir=/usr/share/gcc-data/avr/4.3.3/info --with-gxx-include-dir=/usr/lib/gcc/avr/4.3.3/include/g++-v4 --host=i686-pc-linux-gnu --target=avr --build=i686-pc-linux-gnu --disable-altivec --disable-fixed-point --enable-nls --without-included-gettext --with-system-zlib --disable-werror --enable-secureplt --disable-libmudflap --disable-libssp --enable-cld --enable-checking=release --disable-libgcj --enable-languages=c,c++ --enable-shared --disable-threads --disable-bootstrap --with-bugurl=http://bugs.gentoo.org/ --with-pkgversion='Gentoo 4.3.3-r2 p1.2, pie-10.1.5' Thread model: single gcc version 4.3.3 (Gentoo 4.3.3-r2 p1.2, pie-10.1.5) I've been discussing this in #arduino, and we're working around this issue so far like this: (with a 0022 ide) $ diff -u5 hardware/arduino/cores/arduino/wiring.{c_orig,c} --- hardware/arduino/cores/arduino/wiring.c_orig 2011-02-05 18:17:40.058000066 -0600 +++ hardware/arduino/cores/arduino/wiring.c 2011-02-05 18:19:32.907000066 -0600 @@ -21,10 +21,11 @@ $Id$ */ #include "wiring_private.h" +#include <avr/delay.h> // the prescaler is set so that timer0 ticks every 64 clock cycles, and the // the overflow handler is called every 256 ticks. #define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(64 * 256)) @@ -102,18 +103,21 @@ return ((m << 8) + t) * (64 / clockCyclesPerMicrosecond()); } void delay(unsigned long ms) { +/* uint16_t start = (uint16_t)micros(); while (ms > 0) { if (((uint16_t)micros() - start) >= 1000) { ms--; start += 1000; } } +*/ + _delay_ms(ms); } /* Delay for the given number of microseconds. Assumes a 8 or 16 MHz clock. */ void delayMicroseconds(unsigned int us) {
I have also found that using the 0018 IDE, the delay() works properly. I'll have a look at the Debian patches you listed, and report back when I know more.
« Last Edit: February 05, 2011, 09:12:13 pm by Curtman »
« Reply #26 on: February 05, 2011, 11:46:29 pm » |
On further investigation, it seems that using binutils-2.20.1-r1 instead of binutils-2.21 solves this for me on Gentoo.
« Reply #27 on: February 13, 2011, 06:40:54 pm » |
I have this issue with the Uno and Fedora14 i686. The software is avr-gcc-4.5.1 and avr-binutils 2.21.
« Reply #28 on: February 21, 2011, 11:42:03 am » |
Same here with Fedora 14. (using a Duemilanove)
avr-gcc -v result.
Using built-in specs. COLLECT_GCC=avr-gcc COLLECT_LTO_WRAPPER=/usr/libexec/gcc/avr/4.5.1/lto-wrapper Target: avr Configured with: ../gcc-4.5.1/configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --with-system-zlib --enable-version-specific-runtime-libs --with-pkgversion='Fedora 4.5.1-2.fc14.1' --with-bugurl=https://bugzilla.redhat.com/ Thread model: single gcc version 4.5.1 (Fedora 4.5.1-2.fc14.1)
Hadn't used it for a while on my Fedora box. Works fine so far on Mint though, so not completely duinoless. I also get an error when uploading
"avrdude: stk500_recv(): programmer is not responding"
But none with the blink without delay sketch.
Using avrdude 5.10
« Last Edit: February 22, 2011, 06:55:49 am by John Bailey »
just learning the ropes.. err wires
« Reply #29 on: August 05, 2011, 02:16:49 am » |
Ditto for Fedora 14, with Arduino Duemilanove. See topic http://arduino.cc/forum/index.php/topic,68512.0.htmlHowever the 'blink' example that comes with the arduino v22 software, initializes a LEDPin global variable and that, as has been said fixes the problem. I am a newbe to using the arduino, and the fact that it fails like this with a very basic example has been a worry for me. Any idea when the real problem will be fixed?
