Topic: RoboCup Junior Arduino-based Soccer Robots (Read 7802 times) previous topic - next topic
complubot
Jan 26, 2011, 03:35 pm Last Edit: Jan 26, 2011, 08:13 pm by complubot Reason: 1
This video shows robots playing soccer  in the style of Robocup Junior Soccer  B League. All  robots are designed, built and programmed by young students up to 19 years.
Complubot team robots are based on a multi-processor architecture with four Arduino processors each. Some of the opposing teams using high-performance processor as Blackfin. This is the result:
http://www.youtube.com/watch?v=VwOWtDB9Ufg
Centro de Robótica Educativa
www.complubot.com
JustXtreme
complubot
Not really, Complubot robots have a maximum speed of 1m / s (for now) and the German team's robots TnT exceed 2m / s. The motor power is also different: 18W (Complubot) vs 150W (TnT). I think the biggest difference is the stability of the robots (fewer errors) and how to play (algorithms).
Perhaps the simplicity of the Arduino platform allows young students to work on other things  8)
www.complubot.com
Jak24
HI!
Nice robots,
I am also a Robocup Junior competitor,
And i am also using arduino as my processor although i am only using 1 arduino mega,
I hope to make robots as good as yours someday xD.
Are you motors 18w per motor? or 18w all motors together ,and team TNT's robots had 3x 12w motors not 150w, here is the link proving that:
http://tnt-robotik.de/Feldspieler-2010.html
and team TNT also used a coprocessor besides the blackfin.
also, how did you interface 4 arduino's ?
Regards
Jak24
complubot
Fantastic, what  is your team name?, Soccer  A Soccer B, primary,  secondary?
No,  my students use 4  x 4.5W motors
Perhaps I  misunderstood or maybe the  web information is not updated  to October 2010
Using the  serial port
www.complubot.com
Jak24
HI!
i am in soccer A primary , my team name is amini, but this year we are changing it to hunrobot,
we have been to 2 robocups (09, 10) and plan on going to Istanbul, but this year I am planning to build
brand new and highly improved robots.
I'm guessing they are maxonmotors as almost everyone uses them ( i am also using maxon's, but they are 15W each)
I would like to learn more about your latest robots as your website:
http://complubot.educa.madrid.org/inicio.php?seccion=principal
doesn't seem to have the information about your latest robot :P
Regards
Jak24
complubot
doesn't seem to have the information about your latest robot smiley-razz
You can find  complete information on a simple soccer  robot with Arduino here http://complubot.educa.madrid.org/proyectos/ardusoccerbot/ardusoccerbot_index.php  :D
At  this time we do not have  updated information on our website on the latest robots. We try  to be adding content as soon as we can but now they  are working for the  next competitions. Have you  any information about your robots on  your site?
www.complubot.com
Jak24
Hi!
yes i have seen that tutorial , but still if you ever get the time to update your website with information about your new robots, please inform me.
Unfortunately  my website is being built right now, and since i am getting ready for robocup the website will probably only be online after robocup.
Anyway, i would like to ask you some questions about your latest robots, i would be very grateful if you could answer them:
What kind of motor did you use, as maxon has quite a variety of motors (what voltage, what gearbox/encoder etc...)
Why did you require 4 arduino's on your robot, as atleast for me 1 arduino mega is quite enough.
And finally what kind of kicker(solenoid) did you use for kicking the ball, and what kind of step-up(dc to dc) converter circuit did yo use to power the solenoid?
Thanks
Regards
Jak24
complubot
Unfortunately my  students do not have much  technical information published robots  at this time. Most teams in the  RCJ not give precise details  of their robots, this is normal, these are robots for competition.
This  weekend I asked my  students to put RCJ 2010 posters on our website. I hope you find them useful:
www.complubot.com
dockedrockets
i compete in robocup soccer too
i am hoping to build an arduino robot similar to these ones.
when i get mine going i am hoping to provide extensive data on how it has been built.
if you are looking for help with cheap sensors i have already done all the hard work setting them up for my robot and i would be happy to share the program. They can see the ball from at least 5m away and can tell how far the ball is away from the sensor.
Chypsylon
Hi dockedrockets,
I'm also an Participant in Robocup Soccer.
Although we've already a somewhat working solution to detect the ball it would be cool if you could share your findings :)
dockedrockets
i have been experimenting with TSOP1138 s. These are really good because they can see really far and they filter out ambient IR. but ordinarily they return either a high or a low. The roboball (v2) does not send out either and on or an off however. it ends out 16 different amplitudes slowly increasing in power. then resetting to zero. this means that there is a threshold in this period of time where the tsop will no longer be able to see the ball. this means that you can see distance with a digital sensor.
you connect the two pins close together to 5v and gnd with a 100R resistor on the Vs line. (the Vs line is the line connected to 5v and it is to the right when thee curve is facing you)The last pin to digital pin 2
int ir = 0 ;
int x = 0 ;
  pinMode(2, INPUT);
  while(x <= 16){
  int sensorValue = digitalRead(2);
  if (sensorValue>0){
  ir++ ;
  delayMicroseconds(52.0625);
  x++ ;
  Serial.println(ir, DEC);
  ir = 0;
  x = 0;
