Topic: [SOLVED] How to embed YouTube videos in this forum? (Read 6016 times) previous topic - next topic
complubot
Jan 26, 2011, 03:46 pm Last Edit: Jan 26, 2011, 08:17 pm by complubot Reason: 1
I've tried [FLASH]http://[/FLASH] and [YOUTUBE] [/YOUTUBE]but I can not embed the video
Thank you very much
Centro de Robótica Educativa
www.complubot.com
DojoDave
just need to put the actual link, the forum will detect it is a movie and embed it, like this:
http://www.youtube.com/watch?v=Aw8Mr-KxFos
I just pasted:
u0421793
#2
Jan 26, 2011, 03:59 pm Last Edit: Jan 26, 2011, 05:53 pm by Ian Tindale Reason: 1
That's deceptive, in the preview it only shows a link.
http://www.youtube.com/watch?v=lSgBpktQXuE
liuzengqiang
Hey thanks. I just posted a youtube video on the exhibition. If I copied the video url from the youtube video it still doesn't work. This is not working:
http://www.youtube.com/watch?feature=player_embedded&v=hJjaIgh4nUc
You have to do this as posted by David:
http://www.youtube.com/watch?v=hJjaIgh4nUc
u0421793
Will it work with vimeo in the same way, I wonder?
http://vimeo.com/4770922
complubot
Ok, it works fine. Thank you very much
http://arduino.cc/forum/index.php/topic,49923.msg356090.html#msg356090
www.complubot.com
anonymousguy222
http://www.youtube.com/watch?v=2EwViQxSJJQ&feature=grec_index
edwon
#7
Dec 27, 2012, 04:17 am Last Edit: Dec 27, 2012, 04:29 am by edwon Reason: 1
http://www.youtube.com/watch?v=EdSnjB-GIGg
edwon
Ok, finally figured out the real issue here.
It's the "s" in "https" in your youtube link. The "s" CAN NOT be there!
so your code should look like this:
not this:
https://www.youtube.com/watch?v=EdSnjB-GIGg
