Topic: can;t get newly installed IDE to upload (Read 693 times) previous topic - next topic
blr3621
I am very new to all this. I have just downloaded the IDE for windows. I loaded the blink sketch and tried to upload it - it failed. Have selected the correct board but the port label is greyed out. the error msg talked about and error while attempting to upload. tried to install the .inf file but got a message about one of the installers being unable to run at that stage. Have tried to read the installation problems thread (some of which is over my head).  The UNO board is plugged in and the ON led and the Led connected to pin 13 is also on. Can anyone help = please!!
sterretje
What does the device manager say? If you bought a clone, you might need the CH340 drivers; do a search here.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
blr3621
 Thanks for your reply. The Device Manager shows "other devices - unknown device". when I try to install the driver it shows "one of the installers for this device cannot perform the installation at this time" but it also shows that a driver for this device has been found. I downloaded a driver for the CH340 and it installs but cannot link to the device (board)? Still completely lost. Does it make any difference that I'm running Windows 10
ballscrewbob
Depending on the OS installation type you might have driver enforcement turned on.
Worth looking that up on google and turning off to re-do a driver installation.
Also the CH 340 drivers should be from HERE
You may find some bad CH340 drivers from other sources.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
blr3621
Great advice but unfortunately the problem remains. That was the site I used. Tried turning off the driver enforcement but still get exactly the same error message. Really desperate now. $200.00 of down the drain??? If it was the driver enforcement would the other drivers in the folder load because they do.
blr3621
Oh well it was a nice dream - pity it looks like its been a waste of time and money - nothing I try works the devices show on device manager but the IDE still has ports greyed out and the drivers won't load time to give up and regret getting involved. pity as the grandkids showed a lot of interest
ballscrewbob
Going to suggest something quite radical.
There is a post HERE that I would like you to read and then give as much info as you can back here.
I think we may be missing something simple but until we know as much as possible its hard to know.
Most non connection issues to a board often turn out to be something simple.
blr3621
OK I'll try...
I'm using a Toshiba Laptop running Windows 10. Its running a AMD A4 5000 APU 64bit.
I have down loaded the IDE of the Arduino web site and it runs fine except that the Tool -Ports is greyed out. I have tried starting the IDE with the Board plugged in and plugging it once the IDE is running no difference. I have selected the uno and the screen shows it is looking for a Uno on COM 1.
I have been into the device manager and it shows an unknown device port #003 Hub #001. This changes depending which of the three USB ports it is plugged into. The screen also says "This device is not configured correctly (code 1)". I have used the update driver option and the following message is shown
"windows found software for your device but encountered an error while attempting to install...
Arduino Uno
One of the installers for the device cannot perform the installation at this time"
When the board is plugged in both lights (on/power and L attached to pin 13) are lit (neither blinks)
Its a clone Duinotech Uno is about all I Know.
I'm beginning to wonder if there is a problem with my computer - corrupted windows file????
That's about all I know. But if you need more info I more than happy to provide.
I have been researching but none of the solutions match my problem
Hope this helps at your end - thank you for your being there - can't wait for your response
I would send you screen prints but I don't know how to get them?!
ballscrewbob
The CH340 drivers are a red herring for that board as it is not a clone as we know it.
I am thinking USB 3.0 ports might be the issue.
Do you have access to an older computer with a USB 2.0 port ?
That would be my line of attack on this problem.
Some of us have also had success with a "POWERED USB 2.0" hub between USB 3.0 ports and the Arduino.
Either of those methods may rule out the board as a problem.
Those that are true to the Arduino design can be susceptible to damage of the serial chip (16U2) with over-voltage and they continue to be reports of them in the forum also with voltage regulator issues too.
If you use external power try keep it below 10 volts or less regardless of the recommendation of 5 - 12 volt.
Screen prints are easy in windows (google is your best friend)
Attaching them here is the harder part as there are size restrictions and a few hoops to jump through.
Why do you suspect a corrupted windows file ?
BTW best bet in windows is to install as an administrator as the success rate is much higher for a working IDE.
And turning off driver enforcement is also a good bet with Arduinos and windows.
Reasons seem to imply that some security software may allow a normal install if run at an ADMIN level.
blr3621
Oh Yeah!!!
I have a old computer running windows xt. It was going to the dump but I never got around to getting all the stuff of it - being lazy pays off sometimes. Any way, I managed to download the IDE - plugged in the board and there it was - can't believe how great it was to see a LED flash after uploading the blink sketch. Faith restored.
However that leaves the question of how to get back onto the laptop.
I considered the corrupted windows for 3 reasons
1. The IDE is completely unaware that there are usb ports on this computer
2. I have a number of updates that I can't download/install and my efforts to resolve the issue have gone no where to date.
3. A guy I spoke to had a similar problem (couldn't install drivers - got the same error msg). In the end he backed up his data reformatted the disk and started again - problem solved. By the way I can't see my wife letting that happen.
Tried turning off the driver enforcement - no effect. I also turned off all security stuff before I reinstalled the IDE. Don't fully understand the administrator thing but I'm researching it.
Don't get the powered USB 2 thing - I assume its a piece of hardware that plugs into the USB port and the board plugs into that. If that's the case intuitively can not see how that helps as the IDE is not aware that there are any ports existing but I will research that too.
Thank you so much - nearly gave up. I am a bit surprised the old computer even ran let alone downloaded the IDE = very slowly
If you have any further thoughts on getting it to run on the Toshiba I would love to here them.
Regards and thanks - Brian R (blr3621)
ballscrewbob
Your last post was the clincher.
No USB ports then no Arduinos !
Have you run the Toshiba diagnostics as they would tell you if there were any driver updates for the lappy.
Best of luck getting it to work and hope you find a fix for the tosh.
blr3621
I think you may have missed the point
Problem 1
The USB ports are there and they show the board in the Device Manager - the IDE cannot see them (because they are not called COM?)
Problem 2
For some reason I can not install some drivers. I just get the error message posted before
Some drivers are fine while others fail
ballscrewbob
On some installations of windows 10 the COM ports are under HIDDEN DEVICES and its view must be enabled.
Then you should see "Ports ( COM & LPT )".
blr3621
OK Will try to find them and un-hide them.
I uploaded a small bit of my project to try it - went very well. Quite exciting to write some code and see it come to life. Old computer is a bit slow though.
blr3621
My hunch seems to be correct - there was a problem with the computer!
Last night got a large download from Microsoft upgrading Windows 10. This morning the Device Manager shows Ports and show the Uno on one of them. The IDE is happy and the ports bar is active and shows the board. Just uploaded my first (on this computer) - no problems. Can put the old (and slow) computer to sleep again.
PROBLEM SOLVED
