Topic: Strange power problem (Read 893 times) previous topic - next topic
KandS
What is your 11V to 15V supply?
Tom... :)
It will normally be a 12v 15A but will have a lead acid battery as a backup in case of mains failure
KandS
Tom... :)
It is a per-made 12v 15A psu but will have a lead acid battery to take over in the event of power failure
TomGeorge
Sorry what is per-made?
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
Smajdalf
Is your 9V supply able to provide enough current?
On 8-bit (i.e. Uno) use "byte" instead of "int" if possible - it is faster and saves resources!
KandS
The total peak current draw is around 380mA so the regulator is operating well within its range
TomGeorge
Please answer post #17.
Thanks.. Tom.. :)
KandS
Tom... :)
The 12v supply is not the problem, at present on the test bed it comes from an RS Components Workshop PSU
