Topic: Arduino on Xcode Project — Official Thread (Read 340091 times) previous topic - next topic
davidhux
oops - I will slow down -
Blink runs in Arduino under OSX
Now I understand the Build Options - I get a clean build but when I try to UPLOAD the Blink app I get:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -D -patmega328p -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -carduino -b115200 -P/dev/tty.usbmodem26421 -Uflash:w:Builds/embeddedcomputing.hex:i
Avrdude: can't open input file Builds/embeddedcomputing.hex: No such file or directory
Looks as though I have not done something!
My thanks and apologies for any confusion.
avenue33
#211
Nov 22, 2012, 07:22 pm Last Edit: Nov 22, 2012, 09:01 pm by avenue33 Reason: 1
The target UPLOAD requires the file Builds/embeddedcomputing.hex to be ready.
Have you checked that the file Builds/embeddedcomputing.hex is available?
Use instead the target ALL = CLEAN + BUILD the sketch + ULPOAD to the board + SERIAL console.
It might be easier to use the contact form to send me the content of the Log Navigator.
avenue33
#212
Nov 25, 2012, 12:50 pm Last Edit: Nov 25, 2012, 12:52 pm by avenue33 Reason: 1
The maintenance of the embedXcode template is really difficult due to Apple secrecy around and lack of documentation on Xcode.
So I'm considering switching from Xcode to another IDE.
Here's an open letter to Apple Xcode team. Feel free to send it to members of the Apple Xcode team you know.
Thank you for your help :)
Quote from: Open Letter to Apple Xcode Team
Dear Xcode Team,
Xcode offers superior features and ergonomics compared with other IDEs running on OS X.
Unfortunately, its restricted documentation prevents from using many of its features.
I'm using Xcode as a development tool for embedded computing platforms.
As at today, the embedXcode template supports Arduino, Diligent chipKIT with MPIDE, Texas Instruments' Launchpad with Energia, Leaflab Maple, Teensy, Wiring, and has received a warm welcome from the embedded computing community.
The issues I'm currently facing are mostly linked to the lack of available documentation.
The books available on Xcode focus on how to use the tool, not on how to customise it. Similarly, Apple doesn't provide any clues about its inner structure.
For example, keywords used by the templates are not documented. Neither is using other tool-chains, albeit the specific Toolchains folder.
Is Xcode solely limited OS X and iOS development?
By just releasing some documentation on Xcode inner organisation and customisation, Apple can easily make Xcode the best choice for developers.
Otherwise, I'd have no option but to switch to another IDE and to abandon OS X.
Looking forward to hearing from you,
Best regards,
--- Rei Vilo
http://embedxcode.weebly.com
avenue33
Please find the new release of embedXcode
embedXcode • Nov 24, 2012 release 23 • Fixed WiFi issue on Arduino 1.0.2 and 1.5.x
User Manual • Nov 24, 2012 release 17 • New section Dealing with Issues
embedXcode release 23 includes the additional optional parameter EXCLUDE_LIBS in the main makefile to black-list libraries.
Issues have been reported for the WiFi library on Arduino 1.0.2 and the Firmata library with Teensy 3.0.
Edit the makefile on you project and add the names of the libraries to exclude:
Code: [Select]
# List the libraries to be excluded
# For example, WiFi may crash on Arduino 1.0.2
# For example, Firmata may crash on Teensy 3.0
EXCLUDE_LIBS = Firmata WiFi WiFi/utility
The user manual includes a check-list when facing an issue on embedXcode.
As always,
• Website: http://embedxcode.weebly.com
• Download: http://embedxcode.weebly.com/download
• User guide: http://embedxcode.weebly.com/tutorial
Enjoy ;)
avenue33
embedXcode • Dec 10, 2012 release 23 • Fixed MAPLE_IDE variable and added Energia 9 support for Stellaris
User Manual • Dec 10, 2012 release 18 • New section Dealing with Issues
The user manual includes check-lists when facing an issue on embedXcode.
As always,
Enjoy ;)
avenue33
Please find the new releases of embedXcode
embedXcode • Dec 14, 2012 release 25 • New target for distribution
User Manual • Dec 14, 2012 release 19 • New target for distribution
The new Distribute target creates a specific folder Distribution which contains:
• all the headers and code files,
• documentation in PDF if available,
• and main sketch --.pde or .ino-- in a folder with the appropriate name.
As always,
Enjoy ;)
ecopoesis
I'm having issues getting my sketch to compile in Xcode for the Uno. It works fine in the Arduino IDE.
When I run a compile, I get the error:
/Applications/Arduino.app/Contents/Resources/Java/libraries/Esplora/Esplora.cpp:54: error: 'A11' was not declared in this scope
make: *** [Builds/libs/Esplora/Esplora.o] Error 1
I've attached the full error log.
I get this same error with a fresh embedxcode project too. Any ideas where I've gone wrong?
avenue33
#217
Jan 06, 2013, 12:33 am Last Edit: Jan 06, 2013, 12:34 am by avenue33 Reason: 1
This is strange as your target is UNO.
I suggest you to edit the makefile on you project and add the names of the libraries to exclude:
Code: [Select]
# For example, Esplora may crash on Arduino 1.0.3
EXCLUDE_LIBS = Firmata WiFi WiFi/utility Esplora
It seems the Processing IDE is reaching its limits with the new Arduino products.
Thank you for reporting this issue. Please keep me informed of the result as I'm focused on the 1.5.x release
ecopoesis
Excluding the Esplora lib worked. Thanks.
avenue33
Thank you for the feed-back.
embedXcode • Jan 08, 2013 • Fix for Esplora issue on Arduino 1.0.3
As always,
Enjoy ;)
ecopoesis
Running into another problem: I'm trying to build a project on the Due, and I get the following error:
Code: [Select]
---- Compile ----
1.1-CORE: .o < .c arduino_due_x Builds/ WInterrupts.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -mmcu= -DF_CPU= -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/Arduino -I/Applications/Arduino.app/Contents/Resources/Java/libraries/LiquidCrystal -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD/utility -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Ethernet -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Ethernet/utility -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Servo -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/SoftwareSerial -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Stepper -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire/utility  -g -Os -w -Wall -ffunction-sections -fdata-sections -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/variants/ -DARDUINO=150  /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/Arduino/WInterrupts.c -o Builds/WInterrupts.o
cc1: error: missing argument to "-mmcu="
make: *** [Builds/WInterrupts.o] Error 1
This is with Arduino 1.5.1 and the latest embedxcode. I can compile and upload form Arduino, but even a brand new project in embedxcode fails to compile. Full log is attached
avenue33
#221
Jan 11, 2013, 11:32 pm Last Edit: Jan 11, 2013, 11:48 pm by avenue33 Reason: 1
Problem is, I don't own an Arduino Due, so I can't proceed with the required tests.
I'll see what I can do.
Attached file displays
Quote
Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
XID: 1076264504
Varnish cache server
avenue33
Please find an updated version of embedXcode with successful compilation for Arduino Due.
Please let me know how the upload works so I could improve it.
Thank you!
avenue33
#223
Jan 15, 2013, 06:38 pm Last Edit: Jan 15, 2013, 06:45 pm by avenue33 Reason: 1
Please find a new release of embedXcode
embedXcode • Jan 15, 2013 release 26 • Support for Arduino Due -- Build, link and upload tested
Arduino Due is now fully supported thanks to the help of a user who proceeded with the build, link and upload tests.
Many thanks to Mike!
As always,
Enjoy ;)
Nicolas68480
Hi Avenue33,
thanks for this development, I still have problems creating index and by trying to understand found that in the step1.mk file you also exclude OneWire :
Code: [Select]
# List of sub-paths to be excluded
EXCLUDE_NAMES  = Example example Examples examples Archive archive Archives archives Documentation documentation Reference reference
EXCLUDE_NAMES += ArduinoTestSuite OneWire
EXCLUDE_NAMES += $(EXCLUDE_LIBS)
EXCLUDE_LIST   = $(addprefix %,$(EXCLUDE_NAMES))
Any special reason for this ?
Thanks !
