Note: My Arduino sketches are not in the default location, they are in /volumes/srgshare/Arduino Sketches/
My libraries are in /volumes/srgshare/Arduino Sketches/libraries/
I followed your installation instructions and then tried to create a new project.
Just to be sure, have you run the Arduino IDE just once and declared the sketchbook folder in Arduino > Preferences?
Yes. Before I installed embedXcode, I installed the latest version of Arduino IDE ran it and changed the default sketch directory in preferences.
When I get to step 3.1.1 and run the Build procedure it fails with these errors
Shell Script Invocation Error
/volumes/srgshare/Arduino: No such file or directory
Sketches/test1/test1/Makefiles/step1.mk: No such file or directory
What files are in the folder? The Arduino.app should be in the default applications folder, i.e. /Applications/Arduino.app
I'm not sure which directory your are referring too. This directory doesn't exist: "/volumes/srgshare/Arduino". I do have a directory called "/volumes/srgshare/Arduino Sketches". Could the space between "Arduino" and "Sketches" be causing a problem?
My Arduino.app file is located in my Applications directory, as is xcode.app
In your user manual, I can't get any of the hyperlinks to work.
Thank you for noticing me. My website host doesn't allow files larger than 5 MB. The PDF is 10 MB so I have to compress it. Unfortunately, the compression removes the links.
Can you make the uncompressed version available somewhere else, like slideshare.net?
