Topic: Arduino on Xcode Project — Official Thread (Read 350720 times) previous topic - next topic
avenue33
You're welcome!
I'm glad it works now. It seems Xcode goes lost with many files to sort.
DarkFlagster
I have almost the same problem as Zulkarnine, and the previous solutions didn't work for me =S
The difference is that i have color and auto-complete code with:
  pinMode(myLED, OUTPUT);
but i don't have with this:
  Serial.begin(960);
=S anyway, Is there any theme to get the color equal to the arduino ide?
in the above mentioned example we are declaring a function functionName and calling it again in the main function. so it works fine since it is standard C++ implementation. But when I try to write:
  pinMode(pinNum,HIGH);
  Serial.begin(960);
  analogWrite(13,HIGH);
they don't show colors and I dont even get code completion suggestions. But they should be actually like this:
  Serial.begin(960);
aren't they? Since they are declared in Arduino.h
what i mean is the functions declared in Arduino.h are not being recognised by Xcode while i'm editing in the .ino file. It might have something to do with the Xcode version. I'm using Xcode 4.6.2. Is there anything I'm missing maybe :~
avenue33
  Serial.begin(960);
As I wrote before,
Quote
Code-sense, auto-completion and arguments list are displayed usually without problem in my laptop.
Now, it isn't a 100% hit because code-sense implementation changes with every Xcode release and as Apple is more than secretive about the customisation of Xcode.
Xcode code-sense doesn't seem to be powerful enough to manage virtual functions within classes. Serial.print() is a virtual function.
Sorry, but I can't provide support for Xcode. Please refer to Xcode documentation for interface customisation.
I strongly recommend you to refer to the book Xcode 4 Unleashed by Fritz F. Anderson I purchased thanks to contributions.
Good luck!
avenue33
Please find a new release of embedXcode:
embedXcode • May 04, 2013 release 48 • Compilation of main.cpp for embedxcode only
embedXcode • May 10, 2013 release 49 • Improved code-sense for core libraries
main.cpp has a conditional statement for compilation based on EMBEDXCODE.
The name of the IDE is included in the pre-processing variable use for code-sense.
As always,
• Website: http://embedxcode.weebly.com
• Download: http://embedxcode.weebly.com/download
• User guide: http://embedxcode.weebly.com/tutorial
Enjoy :)
wedontplay
Hi, I'm trying to get the project configuration working but I have an error on line 16 of easyTransfer.cpp:
_serial->print(0x06, BYTE);
It says: "BYTE was not declared in this scope"
What do you think it could be?
Tx
Gabriele
avenue33
I don't know. I guess BYTE isn't declared. Try using the Arduino IDE.
avenue33
embedXcode • May 21, 2013 release 50 • Arduino and Digispark 1.0.4 compatibility
For the Teensy boards, embedXcode takes into account the Teensyduino installed either as a plug-in for Arduino 1.0.3, or as a stand-alone application /Applications/Teensyduino.app.
As always,
Enjoy :)
avenue33
#367
May 23, 2013, 05:42 pm Last Edit: May 23, 2013, 09:10 pm by avenue33 Reason: 1
Please find a new release of embedXcode.
embedXcode • May 23, 2013 release 51 • Project configuration with user's libraries
The automatic preparation procedure now includes the user's libraries for code-sense.
For example, if you select Arduino Uno as board when you create a new project, all the libraries under the sketchbook/libraries folder define in the Arduino preferences are going to be included to the project.
When I started the embedXcode project back in January 2012, I didn't expect to reach the 51st release!
Thank you for your support, feed-back and help you've provided me during all the development!
As always,
Enjoy :)
Scott216
Thanks for all your hard work.  Does release 51 mean we don't need to do step 3.2.1 (add user's libraries) in the manual
avenue33
You're welcome! Now the next big challenge is to update my old Mac :~. Xcode is too demanding :(.
That's correct. No more manual procedure is required.
However, I keep providing the manual procedures on the User Manual as they might be useful if you make important changes to a project, for example changing the platform.
ivers
Got this thing working. Great work!
My only problem is how to set the baud rate of the terminal serial monitor?
avenue33
By default, 9600.
For another speed, see the screen documentation by typing on the Terminal
Code: [Select]
man screen
avenue33
embedXcode • May 28, 2013 release 52 • Project configuration stability enhancement
It appeared the tool in charge of configuring the project generated zombies, resulting in a cryptic Segmentation fault: 11 error message. The cause has been fixed and zombies are over now.
More important, I'm going to resume playing with boards, sensors and displays. As my current Mac no longer provides enough power to run Xcode smoothly,
I plan to update my old Mac for a new one, as this year's target for contributions. Obviously, I continue to maintain and support embedXcode.
As always,
Enjoy :)
avenue33
#373
Jun 01, 2013, 10:16 pm Last Edit: Jun 01, 2013, 10:18 pm by avenue33 Reason: 1
Zulkarnine has posted a nice video about Setting-up embedXcode for Arduino, development in Mac using Xcode IDE on YouTube.
Watch it at http://www.youtube.com/watch?v=b4lnz6ixvgU
Thank you Zulkarnine :)
