Topic: Arduino on Xcode Project — Official Thread (Read 333216 times) previous topic - next topic
avenue33
Hi!
Have you tried Repair permissions with the disk utility?
Scott216
Disk Utility only lists my local disks, not network drives.
Scott216
Can you give me some information as to what embedxcode is doing regarding this error?
==== Build done ====
/bin/sh: Utilities/embedXcode_prepare: Permission denied
Showing first 200 notices only
Command /Applications/Xcode.app/Contents/Developer/usr/bin/make emitted errors but did not return a nonzero exit code to indicate failure
Maybe that can help me figure out why it won't run when creating a new project on my network drive.
avenue33
embedXcode only displays the error message provided by the system.
It seems the network connection prevents the utility from running successfully.
You can try to run embedxcode_prepare from the terminal window.
Scott216
How do I do that?
avenue33
How do I do that?
  • Create a new embedXcode project with Xcode, e.g. embed1
  • Close Xcode
  • Launch Terminal
  • Look for the full path of embedXcode_prepare at
/Users/home/Documents/Xcode/embed1/embed1/Utilities/embedXcode_prepare
  • Look for the full path of embed1.xcproject at
/Users/home/Documents/Xcode/embed1/embed1.xcodeproj
  • Type in Terminal the command
/Users/home/Documents/Xcode/embed1/embed1/Utilities/embedXcode_prepare /Users/home/Documents/Xcode/embed1/embed1.xcodeproj
    home is the folder with your name.
    Scott216
    How do I do that?
    • Close Xcode
    • Launch Terminal
      I get permission denied:
      mac_eth1:Utilities Scott$ /Volumes/srgshare/Arduino_Sketches/Test_webdav/Test_webdav/Utilities/embedXcode_prepare /Volumes/srgshare/Arduino_Sketches/Test_webdav/Test_webdav.xcodeproj
      -bash: /Volumes/srgshare/Arduino_Sketches/Test_webdav/Test_webdav/Utilities/embedXcode_prepare: Permission denied
      avenue33
      Unfortunately, I'm afraid I won't be of much help on this OS X-related issue. File permissions are always tricky,me specially in shared volumes.
      You could try
      sudo chmod -R 777 /Volumes/srgshare/Arduino_Sketches/Test_webdav
      Scott216
      You could try
      That didn't work.  I'm using jungledisk software to create the network drive.  I'll see if their tech support can help.
      Scott216
      Can you try on your Mac hard disk instead?
      Running embedxcode from terminal works if the project is on my local hard drive.
      Scott216
      I'm getting a couple errors after my first Build on a new project.  The build is successful, so I don't know if these errors are important are not.  They are:
      /bin/sh: /usr/local/bin/wget: No such file or directory
      See attached screenshots and log
      avenue33
      No, it isn't a problem. embedXcode is just checking the release number.
      Scott216
      What's strange is I just ran Build on a project I created a couple days ago, I think it was with embedXcode Release 39, and I don't get those errors.  Any idea why?
      avenue33
      #314
      Apr 19, 2013, 02:22 pm Last Edit: May 10, 2013, 06:25 pm by avenue33 Reason: 1
      The new release of the template only applies for the new projects.
      You need to copy-paste the makefiles, About and Utilities folder from the template into your existing project.
