Topic: Arduino on Xcode Project — Official Thread (Read 274507 times) previous topic - next topic
avenue33
Jan 26, 2011, 06:37 pm Last Edit: Oct 03, 2013, 10:22 am by avenue33 Reason: 1
Develop your sketches for Arduino using Xcode!
Direct links:
• Website: http://embedxcode.weebly.com
• Download: http://embedxcode.weebly.com/download
• User guide: http://embedxcode.weebly.com/tutorial
Enjoy :)
Hello!
This is the continuation of the thread initiated by Robert aka. Ratkins in the now read-only old forum.
I've the same problem woth Arduino Uno on Xcode  :(
Please find what I've found so far:
On his blog, Robert Carlsen was pretty close to a solution. But as the last two comments suggest, the Arduino Uno differs from the Duemilanove.
Robert Atkins Says:
January 3rd, 2011 at 7:41
I'm trying to get this working on a Uno, which I believe
has different USB/serial hardware than previous Arduino models?
Anyhow, I've changed the makefile to say: PORT = /dev/tty.usbmodem*
… but I'm getting a whole series of error messages: avrdude:
stk500_2_ReceiveMessage(): timeout And it doesn't look like the
sketch is uploading to the board (rx/tx LEDs aren't flashing.)
Anybody got any hints?
Davide Says:
January 9th, 2011 at 23:39
Also I am trying to work with Xcode ArduinoUno but gives me
this error --- "rm -f main.hex main.eep main.cof main.elf \
main.map main.sym main.lss core.a \ make: *** No rule to make target
`/Applications/Arduino.app/Contents/Resources/Java/hardware/cores/arduino//pins_arduino.o',
needed by `core.a'. Stop. -- someone managed to make it work?
Also, Mattias Gunneras posted on Twitter but didn't explain how
@mattiasgunneras
Mattias Gunneras
Finally got Xcode working with the Arduino UNO. I'm looking forward to a productivity gain of about 318%.
9 Jan via Twitter for Mac Favorite Undo Retweet Reply
Good luck!
westfw
minimally, you would also have to change the bitrate to 115200...
avenue33
Hello,
I tried Nick's modified version of ArduinoOnXcode template plus all the following hints
  • on Makefile, set values for the MCU, upload speed and the protocol according to file located at Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/boards.txt
  • on Makefile, add $(ARDUINO)/WString.cpp to line 73 before $(ARDUINO)/Print.cpp
  • on Makefile, change line 67 from PORT = /dev/tty.usbserial* to PORT = /dev/tty.usbmodem*
It works fine  :) on my Arduino Uno with Arduino 0022 IDE and Xcode 3.2.5 on Mac OS X 10.6.6 for small projects, as LED blinking and "Hello World".
However, I can't manage to use libraries  :~ previously developed with Arduino 0022 IDE.
Probable cause might be a mismatch between C and C++ but I don't know how to fix it.
Any idea ?
avenue33
#3
Feb 16, 2011, 01:59 pm Last Edit: Feb 16, 2011, 03:35 pm by avenue33 Reason: 1
Hi!
Here are two working :) projects
  • Arduino-1: very basic
  • Arduino-3: with a class for the LED
and one non-working :( project
  • Arduino-4: the LED class is on a library
I'm sure it's something trivial  :~ but I can't find it.
Code: (Xcode error) [Select]
/usr/local/CrossPack-AVR/bin//avr-gcc -mmcu=atmega328p  -I. -gstabs  -DF_CPU=16000000L -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -Os -Wall -Wstrict-prototypes  -std=gnu99  -o main.elf main.cpp -L. core.a -lm
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for C/ObjC but not for C++
cc1plus: warning: command line option "-std=gnu99" is valid for C/ObjC but not for C++
/var/folders/gA/gAXpDd7ZEBG06Owk-4lV4++++TI/-Tmp-//cc1xTugb.o: In function `global constructors keyed to myLed':
main.cpp:9: undefined reference to `LED::LED()'
/var/folders/gA/gAXpDd7ZEBG06Owk-4lV4++++TI/-Tmp-//cc1xTugb.o: In function `loop':
main.cpp:31: undefined reference to `LED::blink(int, int)'
/var/folders/gA/gAXpDd7ZEBG06Owk-4lV4++++TI/-Tmp-//cc1xTugb.o: In function `setup':
main.cpp:18: undefined reference to `LED::begin(int)'
main.cpp:24: undefined reference to `LED::on()'
make: *** [main.elf] Error 1
Warning! Before compiling, always launch Build > Clean or Shift-Command-K.
Any idea? Thank you for your help!
avenue33
Hi!
After some research, it seems to be related to the link options.
The library LED.h LED.cpp doesn't figure on the compile line:
Enclosed: Makefile, full build log report
What are the parameters to be changed on the Makefile, not only for this specific project for any future projects?
Thank you and best regards,
ratkins
Good news, using the Makefile supplied by avenue33 I've successfully uploaded the Blink script to my Uno!
Xcode4 still won't acknowledge the existence of the template, but I guess that's just an afternoon of manual-digging. I'll post here when I have anything more to report.
Cheers, Robert.
avenue33
Hi Robert,
On Xcode 3.2.5, I select File > New Project and then a window pops-up with the following options:
Choose Other > ArduinoOnXcode.
I don't know how it runs on Xcode 4 but I guess it's similar.
I still don't manage to get my own libraries compiled, as Example-4 attached in a previous post. There's no problem with standard Arduino libraries.
Nice to hear from your progress  ;)
avenue33
#7
Nov 04, 2011, 06:48 pm Last Edit: Nov 04, 2011, 10:21 pm by avenue33 Reason: 1
Hi!
Please find on this GitHub repository a Xcode project for Arduino UNO.
  • Xcode 4 on Mac OS X.7
  • MPIDE 0022 based on Arduino IDE 0022
I tested it successfully with the Arduino UNO and the chipKIT UNO32 platforms.
The Xcode 3 template is no longer valid because Xcode 4 has changed everything about the templates.
More details on my website.
I'd greatly appreciate some help on Xcode 4 about templates and libraries linking.
timKnapen
#8
Nov 12, 2011, 02:11 am Last Edit: Nov 12, 2011, 01:07 pm by timKnapen Reason: 1
I have been struggling to get Arduino to work with XCode for the longest time.
Finally, it is working. even with libraries ( but for some reason not the SD library... I'm not really sure why. )
I have been recycling makefiles that other people posted on the web, but none that I found could make libraries link correctly or even include extra .cpp files in my project's src folder.
So I have been adjusting and changing makefiles so many times I have no clue where my original source came from :-s
Here is the makefile that I'm using now for working with a Makerbot Sanguino based board:
ARDUINO = /Applications/Arduino.app/Contents/Resources/Java/hardware/Sanguino/cores/arduino
LIBRARIES = /Applications/Arduino.app/Contents/Resources/Java/libraries
AVRDUDE_DIR = /usr/local/CrossPack-AVR/bin
SIZE = $(AVRDUDE_DIR)/avr-size
SOURCES = $(wildcard src/*.cpp)
#loading libraries
STEPPER = $(LIBRARIES)/Stepper
SERVO = $(LIBRARIES)/Servo
EEPROM = $(LIBRARIES)/EEPROM
SD_UTIL = $(LIBRARIES)/SD/utility
INCLUDE_LIBRARIES = -I$(STEPPER) -I$(SERVO) -I$(EEPROM)
CPP_LIBRARIES = $(wildcard $(STEPPER)/*.cpp) $(wildcard $(SERVO)/*.cpp) \
$(wildcard $(EEPROM)/*.cpp)
TARGET = main
SRC = $(ARDUINO)/pins_arduino.c $(ARDUINO)/wiring.c \
$(ARDUINO)/wiring_analog.c $(ARDUINO)/wiring_digital.c \
$(ARDUINO)/wiring_pulse.c \
$(ARDUINO)/wiring_shift.c $(ARDUINO)/WInterrupts.c
CXXSRC = $(ARDUINO)/HardwareSerial.cpp $(ARDUINO)/WMath.cpp $(ARDUINO)/Print.cpp \
$(CPP_LIBRARIES) $(SOURCES)
MCU = atmega644p
F_CPU = 16000000
FORMAT = ihex
UPLOAD_RATE = 38400
# Name of this Makefile (used for "make depend").
MAKEFILE = Makefile
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
DEBUG = stabs
OPT = s
# Place -D or -U options here
CDEFS = -DF_CPU=$(F_CPU)
CXXDEFS = -DF_CPU=$(F_CPU)
# Place -I options here : include libraries
CINCS = -I$(ARDUINO) $(INCLUDE_LIBRARIES)
CXXINCS = -I$(ARDUINO) $(INCLUDE_LIBRARIES)
# Compiler flag to set the C Standard level.
# c89   - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99   - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
CDEBUG = -g$(DEBUG)
CWARN = -Wall -Wstrict-prototypes
CTUNING = -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -Wl,-gc-sections
CFLAGS = $(CDEBUG) $(CDEFS) $(CINCS) -O$(OPT) $(CWARN) $(CSTANDARD) $(CEXTRA) $(CTUNING)
CXXFLAGS = $(CDEFS) $(CXXINCS) -O$(OPT) $(CTUNING)
LDFLAGS = -lm -Wl,-gc-sections -mmcu=$(MCU)
# Programming support using avrdude. Settings and variables.
AVRDUDE_PROGRAMMER = stk500v1
AVRDUDE_PORT = $(PORT)
AVRDUDE_WRITE_FLASH = -U flash:w:bin/$(TARGET).hex
AVRDUDE_FLAGS = -F -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) \
 -b $(UPLOAD_RATE) -D
# Program settings
CC = $(AVRDUDE_DIR)/avr-gcc
CXX = $(AVRDUDE_DIR)/avr-g++
OBJCOPY = $(AVRDUDE_DIR)/avr-objcopy
OBJDUMP = $(AVRDUDE_DIR)/avr-objdump
AR  = $(AVRDUDE_DIR)/avr-ar
NM = $(AVRDUDE_DIR)/avr-nm
AVRDUDE = $(AVRDUDE_DIR)/avrdude
REMOVE = rm -f
MV = mv -f
# Define all object files.
OBJ = $(SRC:.c=.o) $(CXXSRC:.cpp=.o) $(ASRC:.S=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(CXXSRC:.cpp=.lst) $(SRC:.c=.lst)
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS)
ALL_CXXFLAGS = -mmcu=$(MCU) -I. $(CXXFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: sizebefore clean build  sizeafter
build: info folder elf hex
elf: bin/$(TARGET).elf
hex: bin/$(TARGET).hex
eep: bin/$(TARGET).eep
lss: bin/$(TARGET).lss
sym: bin/$(TARGET).sym
# print info
info:
@echo "compiling sources: " $(SOURCES);
@echo "compiling libraries sources: " $(CPP_LIBRARIES);
@echo "----------";
# create the bin folder if it doesn't exist
folder:
mkdir -p bin
# Program the device.
upload: bin/$(TARGET).hex
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH)
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) bin/$(TARGET).hex
ELFSIZE = $(SIZE)  bin/$(TARGET).elf
sizebefore:
@echo "size before: ";
@if [ -f bin/$(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(HEXSIZE); echo; fi
sizeafter:
@echo "size after:";
@if [ -f bin/$(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(HEXSIZE); echo; fi
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
--change-section-address .data-0x800000 \
--change-section-address .bss-0x800000 \
--change-section-address .noinit-0x800000 \
--change-section-address .eeprom-0x810000
coff: bin/$(TARGET).elf
$(COFFCONVERT) -O coff-avr bin/$(TARGET).elf $(TARGET).cof
extcoff: $(TARGET).elf
$(COFFCONVERT) -O coff-ext-avr bin/$(TARGET).elf $(TARGET).cof
.SUFFIXES: .elf .hex .eep .lss .sym
.elf.hex:
$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
.elf.eep:
-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
.elf.lss:
$(OBJDUMP) -h -S $< > $@
# Create a symbol table from ELF output file.
.elf.sym:
$(NM) -n $< > $@
bin/core.a: $(OBJ)
@for i in $(OBJ); do echo $(AR) rcs bin/core.a $$i; $(AR) rcs bin/core.a $$i; done
# Link: create ELF output file from library.
bin/$(TARGET).elf: bin/core.a
$(CC) $(ALL_CFLAGS) -o $@ src/$(TARGET).cpp -L. bin/core.a $(LDFLAGS)
# Compile: create object files from C++ source files.
.cpp.o:
$(CXX) -c $(ALL_CXXFLAGS) $< -o $@
# Compile: create object files from C source files.
.c.o:
$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C source files.
.c.s:
$(CC) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
.S.o:
$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean:
$(REMOVE) bin/$(TARGET).hex bin/$(TARGET).eep bin/$(TARGET).cof bin/$(TARGET).elf \
bin/$(TARGET).map bin/$(TARGET).sym bin/$(TARGET).lss bin/core.a \
$(OBJ) $(LST) $(SRC:.c=.s) $(SRC:.c=.d) $(CXXSRC:.cpp=.s) $(CXXSRC:.cpp=.d)
depend:
if grep '^# DO NOT DELETE' $(MAKEFILE) >/dev/null; \
then \
sed -e '/^# DO NOT DELETE/,$$d' $(MAKEFILE) > \
$(MAKEFILE).$$$$ && \
$(MV) $(MAKEFILE).$$$$ $(MAKEFILE); \
fi
echo '# DO NOT DELETE THIS LINE -- make depend depends on it.' \
>> $(MAKEFILE); \
$(CC) -M -mmcu=$(MCU) $(CDEFS) $(CINCS) $(SRC) $(ASRC) >> $(MAKEFILE)
.PHONY: all build elf hex eep lss sym program coff extcoff clean depend
I'm using this with XCode 3.2, I have attached a zip file of a working sample project.
hope this helps someone, I for one got a little bit balder trying to get this to work :-)
best,
tim.
timKnapen
I have create a project on Github where I've put the XCode project templates:
https://github.com/timknapen/Arduino-With-XCode
With a little help from people who know about makefiles and compilers, I'm sure we can get decent XCode support for Arduino.
best,
tim.
timKnapen
Hi all,
I don't know if this is the right place for this, but I've updated my XCode projects on Github. It has now been updated to work with the UNO. I did a quick test and it seems to work fine.
Still only XCode 3.2 because I'm not running Lion yet..
go get it here: https://github.com/timknapen/Arduino-With-XCode
best,
tim.
timKnapen
Hey anyone doing the same sort of thing,
Shouldn't we create a specific thread for Arduino + XCode (both XCode3.2 and XCode4) so that everybody who know how to write proper C++ can benefit from our efforts? It seems that all the information is now spread over multiple blogs, github repositories etc..
And even on the playgrond: http://arduino.cc/playground/Main/DevelopmentTools there is no mention.
anyone?
best,
tim.
avenue33
#12
Nov 14, 2011, 02:59 pm Last Edit: Nov 15, 2011, 09:50 am by avenue33 Reason: 1
I fully agree with you.
I find here an extensive list of Arduino-related makefiles.
What we need:
• Actions: Build and Upload
• Boards choice: Arduino UNO, ... , chipKIT UNO32
• #include libraries compiled and linked
• Xcode template
I could easily close my repository and point to yours.
Is there an Xcode specialist around? Please!
Best regards,
timKnapen
I'll find here an extensive list of Arduino-related makefiles.
What we need:
• Xcode template
Best regards,
That list of makefiles is very interesting for learning, thanks!
I don't want to come in and take over the show, so I don't think you should close your repository, but a central place for working on this would be great. Like maybe a XCode + Arduino thread on this forum where we discuss the progress and one github repository where multiple people can work on this project.
I'm very new to git and github, so I don't really know how to do this. Do you?
I'm just starting to learn about makefiles so we could use someone that really is fluent with these thing. It would be great that people who download the templates don't have to go into the makefile and change a bunch of parameters just to add a library.
Right now I'm trying to have the choice of Board in the build settings of the project instead of in the makefile. I'm fairly close, but I can't find how to make a drowdown list in the build settings like the ones you have in a Cocoa project when selecting the "Base SDK"...
Avenue33, did you try my project template with XCode 4? I think you can just open it as a normal project with XCode4.
I don't have a computer that runs Lion yet, so I can't test this.
best,
tim
westfw
What we "need" is a command-line mode of the Arduino app that does the Arduino-style preprocessing on a set of .pde (or .ino) files.
Having to figure out exactly what it does (slightly differently) with each Arduino release is a pain, and makes implementing Arduino program builds in other IDEs an exercise in chasing not-fully-documented behaviors. :-(
