100hz is too fast for the Arduino? *shrug*
After debugging, the aforementioned program was reliably reading a 26,000 rpm signal from a signal generator while updating four display values, polling two inputs without interrupts, and having a compiled size of almost 8K. It started getting flaky at about 28,000 rpm. Ditching use of the string class in favor of character arrays roughly doubled the speed. Not executing every display command on every loop iteration roughly doubled the speed once more while still achieving an approximate 100 Hz refresh rate.
