Loading...
Pages: 1 [2]   Go Down
Author Topic: The "Beat/Music Detection" code you have always wanted  (Read 16455 times)
Offline Offline
Edison Member
If you're not living on the Edge, you're taking up too much space!
View Profile
@Diebor - You can sample faster than you can process or send the data.  It sounds good at 40K samples / sec.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1208715493/11
The only use I can see for this is to oversample and average ever pair of samples.
This way you can avoid using a hardware Nyquist filter at lower sample rates.
Logged
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
Offline Offline
Edison Member
View Profile
I made a cool light show with the MSGEQ7 chip and 4 LED's.
Also works with El wire.
See this post for pseudocode:
http://arduino.cc/forum/index.php/topic,77572.0.html
Logged
-Floor
(262) 696-9619
0
Offline Offline
Newbie
View Profile
WWW
Great code, just what I was looking for, however I could do with some help with wiring the pre amp circuit.
I currently have two audio inputs, switched using a relay, and two audio outputs, also witched using a relay, whilst the audio is going between the two relays is where I want to get the sampling signal from, can I just connect the inputs to the op amps to here?
Thanks,
Dan
Logged
Offline Offline
Newbie
View Profile
Is it possible to use an LM358 and +5V power supply instead?
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
