Topic: Trying to communicate serial between Mega and duemilanove (Read 2068 times) previous topic - next topic
martin_michaelsen
Hey!
I am trying to send send data from my Mega to a Duemilanove.
Both boards are set up on only 300 baud, TX and RX and ground are connected correctly.
A code like Serial1.println("SOUND"); will only result in random (but the correct count) characters on the Duemilanove.
Does the wires need to shielded or something?
gardner
Do you have your Duemilanove connected to a USB?  The USB connection uses the UART, and there is only one.  Talking simultaneously on the USB and pins 1 & 2 to the same Arduino is not going to work all that well.
PaulS
Why so slow? If the boards are hard-wired, you can bump that speed all the way to 115200.
How long are they? What do they run near?
martin_michaelsen
Thanx for your replies.
Yep indeed. My Duemilanove  is connected over USB. I had to see what was sent:-)
Well! I must try some LED flashing then;-)
PaulS: I only ran at that speed to rule out that it was not a speed issue.
