Topic: Good new topic (Read 15393 times) previous topic - next topic
Graynomad
Jan 27, 2011, 03:36 am Last Edit: Jan 27, 2011, 03:43 am by Graynomad Reason: 1
OK so here we are at the new forum, as I'm into home/building automation I like having an area about this subject.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Terry King
I'm thinking about replacing my present home automation stuff with an arduino (maybe Mega).. I have a system that works for me but it's Time.. It's been running 20+ years on the same IBM AT with a bunch of sensors and optically isolated In/Out. lotsa Pascal code.  Time To Go, and Time to get On The Net!
I'll be reading the mail here...
(GrayerThanU)  :)
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com
Graynomad
Hi Terry,
I'm working on a network for this at present (me and a 1000 other people probably). If you're interested have a look at
http://busnet.robgray.com
It's got a bit complicated and probably more than most people are into, but what else am I going to do in my spare time?
I'm also working on the design for a Mega-style board with LCD touch, hardened IO, inbuilt RS485 etc for use as a controller.
______
Rob
zoomkat
You may want to look at the below forum. A lot of gizmo ideas have been posted over the years.
http://forums.homeseer.com/index.php
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
DCContrarian
(GrayerThanU)  :)
I did a lot of AT programming back in the day. Arduino reminds me of those days!
maniacbug
Wow, this is intense.  Inspiring.  Nicely done!  When I get my wireless mesh network up and running, I am going to have to put a site like this!  :)
And yeah to your point about wireless nodes, I am headed toward a $17.50 per node cost, although that includes a full-fledged Arduino clone so of course it's available to do lots of other things too, but many nodes won't be using the full power.
Graynomad
#6
Mar 20, 2011, 04:45 am Last Edit: Mar 20, 2011, 04:48 am by Graynomad Reason: 1
Yes there are all sorts of arguments for/against wire/wireless. Getting the right granularity is always a problem. $17.50 is very good but still too much to dedicate to a single light switch I guess.
With my design I should be able to do a simple node about 12x12mm in size (no idea about $ though), but then of course I need to have wires.
I'm not ignoring wireless though, I plan to have "gateways" for the various wireless options, mind you that's a LONG way off.
BTW my Mega design is finished, RTC, LCD touch screen and built in RS485/232/i2c networking hardware amongst other stuff. I plan to use this as my automation controller.
______
Rob
maniacbug
Yeah, for light switches, I was thinking X10, and then I just need X10 gateways that could control a handful of lead nodes.
STILL that's like $10 for those nodes, which isn't going to compare to a hand-rolled solution.  Maybe I need to make my own X10 :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
