Topic: Looking for an electrically actuated water valve (Read 20934 times) previous topic - next topic
pluggy
An alternative to solenoid operated valves is motorised valves as used on heating systems, usually mains voltage, they are usually spring loaded shut and open when supplied with mains power :
http://www.uk-plumbing.com/danfoss-randall-2-port-valve-hp22b-22mm-p-1396.html
http://pluggy.is-a-geek.com/index.html
Valalvax
Quote
(also, yea, I realized after the fact that ball valves are either on or off, been a while since I had a hydraulics class)
No, a ball valve can be used to throttle flow anywhere from full off to full on and anywhere in between, just by the position of the handle/ball. A ball valve's main claim to fame is that it can be made to allow full flow restricted by only the piping size and line pressure. That is a 1/4" ball valve has a full 1/4" hole in the ball and therefore allows full potential flow in 1/4" piping systems. They tend to be the more expensive style of valve per size because of the precision machining required to make the ball and seat. Not sure if plastic ball values are common and if they carry a price premium also.
Lefty
Oh? :/ Well cool...
I know just enough to have the DESIRE to make trouble/a mess, but not enough to actually do it :P
That might actually be exactly what I need, pretty cheap, does what I need, etc
Thanks everyone for your help, I'll continue to poke around, but once I see something I like, it's usually the one I get (I'm an impulse shopper, except I wait a while before buying, but STILL buy the same thing :P)
smartvalves
I'm trying to find a electrically actuated water valve for a project.. something I THINK like this here
http://www.amazon.com/Parker-Valve-4Z-B6LJ2-SSP-Stainless-Compression/dp/B001C13DJ6
But preferably cheaper, that's obviously for an industrial application
My question is: Does anyone know of any search terms I could try to find more residential oriented ones?
I can help you,electric actuated ball valve,USD22 per unit,used for residential appliaction,skype:amyzhang3000
smartvalves
Yes,you are correct,mini motorised ball valve can be perfect alternative to solenoid valves,if your application is home automation system,please contact me,I can also help you,USD22 per unit,CE Certificate mini motorised ball valve is absolutely your first choice.
Sean
#19
Apr 06, 2015, 12:07 am Last Edit: Apr 06, 2015, 12:08 am by capt.tagon
Intermatic PAV215 for about $18.50 USD
And the spendy bit
Intermatic PE24VA for about $75.00 USD
The 24V actuator attaches to the valve, useful for Arduino Low Pressure Irrigation type projects, the standard Solenoid Servo Valves don't cut it on gravity flow unless you've got about 40' head pressure.
MorganS
Why not just use a sprinkler system valve? They sell them at Home Depot and Lowes and work off of dc voltage. They come in 3/4 and 1" outlets. Just use adapters to make it the size you need.  I think the company is RainBird but I'm sure their are other companies as well. In the spring you can get them at the hardware stores for like $10.
Because he wants flow control and those pilot-operated valves only do on and off. They also need 24v to operate.
"The problem is in the code you didn't post."
