Loading...
Pages: [1]   Go Down
Author Topic: I created a function / library to play sampled sounds  (Read 2703 times)
Washington
Offline Offline
God Member
Firefox & Arduino rocks
View Profile
I created a function to play low quality sampled sound out a speaker attached to an Arduino.
It plays 4000 1 bit per sample sound through a digital pin.
Maximum 50 seconds in atmega 328 memory.
It stores the data bit packed in an array.
It is enough to play short sounds at low quality.
Here is the function:
Code:
#include <avr/pgmspace.h>
void playSound(prog_uchar input[], long len, int soundpin){
    long arrayc=0;
    while(arrayc < len){
        unsigned char s = pgm_read_byte_near(array + arrayc);
        for(unsigned char bs = 1;bs < 128;bs *= 2){
            digitalWrite(soundpin, s & bs);
            delayMicroseconds(250);
    arrayc++;
Syntax:
Code:
void playSound(prog_uchar input, long len, int sound)
where
input is a bit packed program space array of the samples to be played.
len is the length of the array in bytes
soundpin is the pin to play the sound out
The following program converts 8000hz 8 bit mono files to bit packed arrays for the function to play:
Code:
#include <stdio.h>
#include <stdlib.h>
#define N(x) ((x) > 130)? 1:0
int main(int argc, char *argv[]){
printf("Note: The input file must be in 8000 8 bit samples per second mono\n");
if(argc != 3){printf("Usage: %s <input.wav> <output.c>\n", argv[0]);}
FILE *f = fopen(argv[1], "rb");
FILE *o = fopen(argv[2], "w");
unsigned char a,b,c,d,e,byte;
fprintf(o, "#include <avr/pgmspace.h>\nprog_uchar array[] PROGMEM = {");
unsigned int cnt=0,_cnt=0;
while(!feof(f)){
fread(&a, 1, 1, f);
fread(&e, 1, 1, f);
fread(&b, 1, 1, f);
fread(&e, 1, 1, f);
fread(&c, 1, 1, f);
fread(&e, 1, 1, f);
fread(&d, 1, 1, f);
a = N(a);
b = N(b);
c = N(c);
d = N(d);
byte = (a | b << 1 | c << 2 | d << 3);
fread(&a, 1, 1, f);
fread(&e, 1, 1, f);
fread(&b, 1, 1, f);
fread(&e, 1, 1, f);
fread(&c, 1, 1, f);
fread(&e, 1, 1, f);
fread(&d, 1, 1, f);
a = N(a);
b = N(b);
c = N(c);
d = N(d);
byte |= (a << 4 | b << 5 | c << 6 | d << 7);
fprintf(o, "%d,", byte);
cnt++;
_cnt++;
if(cnt > 60){fprintf(o, "\n"); cnt = 0;}
fprintf(o, "0};");
fclose(o);
fclose(f);
printf("\nOutput array of %d bytes\n", _cnt);
return 0;
My code sucks but it works.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Washington
Offline Offline
God Member
View Profile
Video here:
Sorry the audio is very low because my microphone is crap.
Logged
Resistors for LEDS!
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Would it be possible to play "byte" files from an SD card or an I2C EEPROM?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Washington
Offline Offline
God Member
View Profile
Not really.
The format is different (8 bit vs 1 bit) and the sample rate is different (4000 vs 8000) and it has no provision for reading from an SD card.
Logged
Resistors for LEDS!
Saint Petersburg, Russia
Offline Offline
Full Member
Amateur
View Profile
WWW
... to make sound louder.  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
