Topic: arduino tools-serial menu item disabled (Read 11048 times) previous topic - next topic
wayoda
please check the system log:
open a console;
run command 'sudo dmesg -c' (to clear out all previous messages);
plug the arduino into a USB-port
run 'dmesg' again (no need to clear the older messages again)
what do you see? any error messages?
unplug the arduino and check whats printed on removing the device too.
Eberhard
IceCold
Hey that was something on the path of fixing it
I did with -c parameter and had a bunch of things clearing
Then I plugged and with a another dmesg I had the following:
[16271.592581] usb 2-1: new full speed USB device using ohci_hcd and address 3
[16271.650108] hub 2-0:1.0: unable to enumerate USB device on port 1
then I unplug and had:
Still tried the IDE but the Serial Port was still disabled
I have installed the Windows version of the .exe thru Wine, and even though I got a poor look of IDE's GUI it found the port of my board on COM 1! :-X
gbulmer
#17
Apr 28, 2010, 10:11 pm Last Edit: Apr 28, 2010, 10:11 pm by gbulmer Reason: 1
That error is mentioned here:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/256767
where it says "This bug is still present in Ubuntu 9.04 and Ubuntu 9.10 ..."
then goes on to say:
"A suggestion of the cause is at http://lkml.org/lkml/2008/10/24/209"
which says:
"... This is normal; it is caused by userspace loading the drivers in the
wrong order.  ehci-hcd is supposed to be loaded before uhci-hcd or
ohci-hcd, not after. ..."
Couldn't find a resolution, so I may have gone down a blind alley
Sorry
wayoda
I'm not sure about this tip here you could give it a try:
I you have a USB-Hub (or can borrow one from a friend). Does it help to plug the arduino-board into the external hub wqhich is then connected to your computer?
Eberhard
carolpaul
I have also meeted above problem. Who can help me ? Thanks
IceCold
Hello guys!
I'm not too sure what went on but after a few updates (not up to the 10.04 Lts)
FIAT LUX
My USB ports started blinking! I've got everything running now! ;D ;D ;D
