Loading...
Pages: [1]   Go Down
Author Topic: RS 232 communication with Serial1 on MEGA 2560  (Read 3168 times)
Offline Offline
Newbie
View Profile
Hello everybody,
I'm having problem communicating with the MEGA 2560 through Serial 1,2 and 3 :
the connection through USB via Serial 0 works perfectly but when I try to send data with Serial3 (pins 14 and 15) the computer recieve weird datas.
It is as if  the bytes are messed up.
here is the code I'm using :
Code:
  // initialize both serial ports:
  Serial3.begin(9600);
  Serial.println("Hello World");
  Serial3.println("Hello World");
  if (Serial3.available()) {
    int inByte = Serial3.read();
    Serial.print(inByte, BYTE);
    if (Serial.available()) {
    int inByte = Serial.read();
    Serial3.print(inByte, BYTE);
for example, there is what I receive instead of Hello World (in Hexa) :
00
AB 3A 3A 0A FA 8B 85 1B 27 37 E5 EB 00
I think it may be a silly mistake but I don't have clues.
I already tried to check the communication with a cross wired DB9 cable between 2 PC to see if the data was sent correctly and it works.
Also the Com port configuration is : 9600 bps - 8 bits - No Parity - 1 Bit Stop - No Control
Do you have any ideas ?
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
The Arduino serial ports are 5v TTL. RS-232 is -12v. You need a level shifter. Sparkfun has one I have used with great success.
http://www.sparkfun.com/products/8780
scroll down below it to related products for one with a connector and/or a kit.
« Last Edit: January 27, 2011, 11:09:19 am by arbarnhart » Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Are you trying to drive the DB9 directly from the MEGA pins?   If so, you are trying to use TTL to talk RS232, which can't be done.  I believe you need something like a MAX232 to convert TTL to RS232.
Try this  connect TX2-RX3 and RX2 to TX3 and see what you get on Serial2.
Logged
Offline Offline
Newbie
View Profile
Ok thanks for the quick replies, I wasn't using a level shifter I'll try with that.
BTW I tried connecting Rx 2 to Tx 3 and Rx3 to Tx2 and it was working perfectly.
Thanks again for the advices
Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Transmitting 5v -> 232 often does work, but often doesn't work also. It depends on the receiving hardware.
Receiving 232 into the Arduino is a bad thing to do, +-12v into the Arduino pin is not recomended. smiley
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Pages: [1]   Go Up
Print
Jump to:
