Boston
Offline
God Member
Arduino rocks
« on: January 27, 2011, 11:30:50 am » |
In case anyone hasn't seen this, there is a cool 555 timer contest going on. It is actually being judged by Forrest Mims! http://www.555contest.com/
Logged
Phoenix, Arizona USA
Offline
Faraday Member
Where's the beer?
« Reply #1 on: January 27, 2011, 11:35:58 am » |
Heh - that does sound like a cool contest - I'll have to check it out! Thanks for posting that!
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #2 on: January 27, 2011, 12:18:22 pm » |
OK here's what we do. Rub the Atmel writing off an Attiny85 and add something like NE555. Then write a nifty program that does something not too fancy (that will give the game away) but that will knock to socks off a 555 circuit  What's the first prize anyway, a tube of 555s. ______ Rob
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #3 on: January 27, 2011, 03:16:40 pm » |
What's the first prize anyway, a tube of 555s. Nahh, a pretty hefty chunk of stuff probably
Logged
Leighton Buzzard, UK
Offline
Edison Member
« Reply #4 on: January 27, 2011, 03:41:53 pm » |
guaranteed winner design something that needs 555 of the little suckers!
Logged
there are only 10 types of people them that understands binary and them that doesn't
Boston
Offline
God Member
Arduino rocks
« Reply #5 on: January 27, 2011, 04:23:32 pm » |
I'm not sure what the actual prizes are, but they are being sponsored by DigiKey and Beagle Boards among others. Also just read Hanz Camenzind who created the chip is also judge!
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #6 on: January 27, 2011, 04:25:53 pm » |
I was thinking 555 LEDs in a project but that involves buying more... Yeah the prizes should be pretty epic!
Logged
Central MN, USA
Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
« Reply #7 on: January 27, 2011, 04:49:13 pm » |
Very clever. Is Attiny85 pin-compatible with 555? OK here's what we do. Rub the Atmel writing off an Attiny85 and add something like NE555. Then write a nifty program that does something not too fancy (that will give the game away) but that will knock to socks off a 555 circuit  What's the first prize anyway, a tube of 555s. ______ Rob
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #8 on: January 27, 2011, 05:08:27 pm » |
Rub the Atmel writing off an Attiny85 and add something like NE555. I predict that it will have trouble driving 200mA through an output from a 12V supply... The AVR reset circuit discussed recently isn't totally out of the running, though. A bit on the simple side. How else might a 555 be used together with a microcontroller? This would at least be an area that hasn't already had hundreds of 555 circuits already published!
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #9 on: January 27, 2011, 08:03:22 pm » |
not even close
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Washington
Offline
God Member
Firefox & Arduino rocks
« Reply #10 on: January 27, 2011, 08:08:34 pm » |
The capabilities of the 555 IC have been way overrated for some reason  BTW Do you get extra points for building a working 555 on a breadboard with discrete transistors from the schematic?
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use. Solid state rectifiers are the only REAL rectifiers. Resistors for LEDS!
Boston
Offline
God Member
Arduino rocks
« Reply #11 on: January 30, 2011, 10:13:39 am » |
They now have a list of sponsors and prizes totaling over $6,000, including a Fluke 287 and a BeagleBoard-xM! http://www.555contest.com/prizes-sponsors/
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #12 on: January 30, 2011, 03:55:55 pm » |
I have to admit, I was thinking of entering but since that guy's done the self balancing thing with a 555, I'm not going to. No way I can top that.
Logged
New York
Offline
Edison Member
E != m*c^2
« Reply #13 on: January 30, 2011, 08:08:23 pm » |
You know, mowcius, there are different categories - so you could submit something fundamentally different.
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #14 on: January 30, 2011, 10:09:41 pm » |
Does it have to be a working circuit? I have this idea of completely covering a baseball hat with glued on 555 chips. I guess if it does have to do something electrically I could glue leds on top of the 555s. Damn battery will probably give me a headache.
I'm sure that hasn't been done before, and don't none of you go stealing my idea, just because Arduino is open sourced and all.
Logged
