Good day,
I'm totally new to Arduino, got interested when I saw awesome projects on the net and tried building many of them. Arduino totally rocks!
Now I want to build a new project on my Arduino Duemilanove called the Arduino Punk Console made by Dano from Beavisaudio.com but bumped onto some problems.
First off, I noticed that the LCD Beavisaudio.com is using is a serial LCD and I have bought a parallel LCD (oops!).
Because the Arduino Punk Console uses a lot of digital pins it's impossible to install the parallel LCD next with it (it uses another 16 pins)
After some research I found the answer to use my pins more efficient by trying the
LCD3Wire tutorial (
http://www.arduino.cc/playground/Code/LCD3wires) with the LCD4Bit library (
http://www.arduino.cc/playground/Code/LCD4BitLibrary).
My LCD now reacts with text messages I put in the LCD4Bit code like this:
//some messages to display on the LCD
char msgs[6][15] = {"hello", "world", "im", "totally", "serious", "about", "this"};
Messages like this works pretty well, but when I try to use the code from Beavisaudio.com nothing will happen. I fully understand the reason why this will not work because the code from Beavisaudio.com points to the serial port (Rx pin). I think the whole code is based on that.
Now the thing is; I tried to combine the Beaviscode.com code to get it work with the LCD4Bit but it turns into one big mess!
Loads of errors wich I do not understand (fairly enough I'm not a coder) and I'm totally stuck now.
Is it possible to get the Atari Punk Console to work with a parellel LCD?
Can someone help me, or point me to the right direction?
Here's the original code from Beavisaudio.com:
A simple programmable 8 step tone sequencer
by dano/beavisaudio.com
Revs
15 Sept djh initial version
// Map all the input and output pins
#define AnalogInFrequency 1
#define AnalogInTempo 2
#define AnalogInDuration 0
#define DigitalOutSignal 11
#define DigitalInSwitch0 2
#define DigitalInSwitch1 3
#define DigitalInSwitch2 4
#define DigitalInSwitch3 5
#define DigitalInSwitch4 6
#define DigitalInSwitch5 7
#define DigitalInSwitch6 8
#define DigitalInSwitch7 9
#define DigitalInStartStop 10
#define DigitalOutLED 12
// Set up the array for each step
int steps[] = {100,120,140,160,180,200,220,240};
// misc housekeeping
int duration = 50;
int pitchval = 1;
int fPlayMode = true;
int lastPushedStep = -1;
// Initialize the tempo
int tempo = 100;
// setup pin modes (Digital pins are input by default, but
// I like to set 'em explicitly just so the code is clear.
pinMode (DigitalInSwitch0, INPUT);
pinMode (DigitalInSwitch1, INPUT);
pinMode (DigitalInSwitch2, INPUT);
pinMode (DigitalInSwitch3, INPUT);
pinMode (DigitalInSwitch4, INPUT);
pinMode (DigitalInSwitch5, INPUT);
pinMode (DigitalInSwitch6, INPUT);
pinMode (DigitalInSwitch7, INPUT);
pinMode (DigitalInStartStop, INPUT);
pinMode (DigitalOutSignal, OUTPUT);
pinMode (DigitalOutLED, OUTPUT);
// setup comms for the LCD display
StartupMessage();
void StartupMessage()
clearLCD();
Serial.print ("BEAVIS: Arduino");
delay(300);
Serial.print (254, BYTE);
Serial.print (192, BYTE);
Serial.print ("Punk Console!");
delay (2000);
clearLCD();
Serial.print ("Beavis: APC");
void clearLCD()
Serial.print(254, BYTE);
Serial.print(1, BYTE);
// Main sequence loop
for (int i=0; i<8; i++)
// Are we playing or stopping?
fPlayMode = digitalRead (DigitalInStartStop);
digitalWrite (DigitalOutLED, HIGH);
// Check the Hardware
readSwitches();
readPots();
// update the display
updateDisplay();
// Make the noise
if (fPlayMode)
freqout (steps[i], duration);
digitalWrite (DigitalOutLED, LOW);
// Pause between steps
delay (tempo);
void updateDisplay()
Serial.print ("T:");
Serial.print (tempo);
Serial.print (" d:");
Serial.print (duration);
if (lastPushedStep != -1)
Serial.print ("*");
Serial.print (lastPushedStep);
// Read the current values of the pots, called from the loop.
void readPots ()
tempo = (analogRead (AnalogInTempo) * 1.9);
duration = (analogRead (AnalogInDuration));
// Read the current values of the switches and
// if pressed, replace the switch's slot frequency
// by reading the frequency pot.
void readSwitches()
// reset last pushed button number
// check switch 0, if pressed, get the current freq into step 0, etc. etc.
if (digitalRead (DigitalInSwitch0) == HIGH)
steps[0] = analogRead(AnalogInFrequency);
lastPushedStep = 1;
else if (digitalRead (DigitalInSwitch1) == HIGH)
steps[1] = analogRead(AnalogInFrequency);
lastPushedStep = 2;
else if (digitalRead (DigitalInSwitch2) == HIGH)
steps[2] = analogRead(AnalogInFrequency);
lastPushedStep = 3;
else if (digitalRead (DigitalInSwitch3) == HIGH)
steps[3] = analogRead(AnalogInFrequency);
lastPushedStep = 4;
else if (digitalRead (DigitalInSwitch4) == HIGH)
steps[4] = analogRead(AnalogInFrequency);
lastPushedStep = 5;
else if (digitalRead (DigitalInSwitch5) == HIGH)
steps[5] = analogRead(AnalogInFrequency);
lastPushedStep = 6;
else if (digitalRead (DigitalInSwitch6) == HIGH)
steps[6] = analogRead(AnalogInFrequency);
lastPushedStep = 7;
else if (digitalRead (DigitalInSwitch7) == HIGH)
steps[7] = analogRead(AnalogInFrequency);
lastPushedStep = 8;
//freqout code by Paul Badger
// freq - frequency value
// t - time duration of tone
void freqout(int freq, int t)
int hperiod; //calculate 1/2 period in us
long cycles, i;
// subtract 7 us to make up for digitalWrite overhead - determined empirically
hperiod = (500000 / ((freq - 7) * pitchval));
// calculate cycles
cycles = ((long)freq * (long)t) / 1000; // calculate cycles
for (i=0; i<= cycles; i++)
{ // play note for t ms
digitalWrite(DigitalOutSignal, HIGH);
delayMicroseconds(hperiod);
digitalWrite(DigitalOutSignal, LOW);
delayMicroseconds(hperiod - 1); // - 1 to make up for fractional microsecond in digitaWrite overhead
And a simple code from the LCD4Bit that works pretty well with my shiftregister 3-wire LCD:
// Example use of LCD3Wire library
// Almost a carbon-copy of LCD4BitExample.pde
#include <LCD3Wire.h>
// Arduino pins
#define LCD_LINES 1 // number of lines in your display
#define DOUT_PIN 15 // Dout pin
#define STR_PIN 16 // Strobe pin
#define CLK_PIN 14 // Clock pin
#define LED_PIN 13 // we'll use the debug LED to output a heartbeat
//create object to control an LCD.
LCD3Wire lcd = LCD3Wire(LCD_LINES, DOUT_PIN, STR_PIN, CLK_PIN);
char msgs[6][15] = {"apple", "banana", "pineapple", "mango", "watermelon", "pear"};
int NUM_MSGS = 6;
lcd.init();
//optionally, now set up our application-specific display settings, overriding whatever the lcd did in lcd.init()
//lcd.commandWrite(0x0F);//cursor on, display on, blink on. (nasty!)
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, HIGH); //light the debug LED
//pick a random message from the array
int pick = random(NUM_MSGS);
char* msg = msgs[pick];
lcd.clear();
lcd.printIn(msg);
digitalWrite(LED_PIN, LOW);
//print some dots individually
for (int i=0; i<3; i++){
lcd.print('.');
delay(100);
//print something on the display's second line.
if(LCD_LINES>1){
lcd.cursorTo(2, 0); //line=2, x=0.
lcd.printIn("Score: 6/7");
//scroll entire display 20 chars to left, delaying 50ms each inc
lcd.leftScroll(20, 50);
