Loading...
Pages: [1]   Go Down
Author Topic: I think the world is ready for a good Firmata Tutorial  (Read 3072 times)
Friedberg, Germany
Offline Offline
Full Member
Arduino rocks   (it really does!)
View Profile
As far I know Firmata is now know for quite a while but a lot of people ( including me ) don't really know how to use this awesome programm/sketch.
I really looked for a lot of time through the net and didn't find anything helpfull there...
There is a testprogramm for Firmata on their mainpage and it is really neat and I would like to be able to do the same comads over, for example, Processing.
The interface is not needed.
http://firmata.org/wiki/Main_Page
I don't really get how to propperly read and understand the arduino reference to do that.
http://arduino.cc/en/Reference/Firmata
The Servowrite function is quite important for me.
I know there is an arduino libruary for processing but this one does just support analog read, write and pwm.
the essancial quaestions from me are:
Is there someone who would do a nice and understandable firmata tutorial so that the not so good programming people know what to do ?  smiley
What do I need to send to trigger a specific firmata function on the arduino?
and how do I read proberly the firmata-arduino output data (sensors) ?
(this is somewhat in the first question included)
I hope my spelling is not to bad ^^
Greetings from Germany,
Florian
« Last Edit: January 27, 2011, 04:56:06 pm by Gonras » Logged
Friedberg, Germany
Offline Offline
Full Member
View Profile
I found this forum link and I guess It couldn't be continued because of the forum change.
Does someone know how to fix the latest probleme there?
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1294833227
I would be really interessted in the solution.
Logged
Baltic Sea
Offline Offline
Newbie
Arduino rocks
View Profile
try this one:
http://t-o-f.info/pmwiki/index.php?n=Arduino.Firmata
its a modded firmata (servo only 9 & 10) and a processing library (dont use arduino library).
what i cant translate fast:
funktioniert wunderbar. nur da ich jetzt xbees als "kabel" nehme, hab ich selber was ohne firmata geschrieben. firmata wartet immer auf antwort, was bei mir zu keiner verbindung mit xbees führt. aber sonst sahne.
hier noch mein letzter kabel-sketch in processing mit tof-firmata
Code:
/*  RC car project | Arduino UNO | zH32
    08.01.2011
import processing.serial.*;
import cc.firmata.*;
Firmata firmata;
import controlP5.*;
Serial myPort;
ControlP5 controlP5;
import procontroll.*;
import net.java.games.input.*;
import java.io.*;
ControllIO controll;
ControllDevice device;
ControllStick stick;
ControllStick stick1;
ControllButton button1;
ControllButton button;
int LED = 13;
int licht = 4;     //LDR
int motorpin1 = 6; //when motorpin1 HIGH motorpin2 LOW = forward....
int motorpin2 = 7;
int motorpwm = 11;
int standby = 2;
int ledState;
  int val;
long previousMillis = 0;
long interval = 200;
void firmataSetup (Firmata f)
  println("Running setup function");
  f.pinMode(motorpwm,firmata.PWM);
  f.pinMode(9,firmata.SERVO);
  f.pinMode(LED, firmata.OUTPUT);
  f.digitalWrite(LED, firmata.LOW);
  f.pinMode(licht, firmata.INPUT);
  f.pinMode(motorpin1, firmata.OUTPUT);
  f.pinMode(motorpin2, firmata.OUTPUT);
  f.pinMode(standby, firmata.OUTPUT);
  size(1024,600);
  println("Available ports:");
  println(Firmata.list());
  firmata = new Firmata(this, Firmata.list()[4], 115200);
  String portName = Serial.list()[3];
  frameRate(20);
  PFont myFont;
  myFont = createFont("Arial", 20);
  textFont(myFont);
  controlP5 = new ControlP5(this);
  controlP5.addSlider("Lenkung in %",-100,100,50,10,50,400,40);
  controlP5.addSlider("Power in %",-100,100,100,30,150,40,400);
    controlP5.addSlider("Licht",0,100,25,200,150,40,400);
  controll = ControllIO.getInstance(this);
  device = controll.getDevice("Logitech Cordless RumblePad 2");
  device.setTolerance(0.07f);
  ControllSlider sliderX = device.getSlider("Z-Achse");
  ControllSlider sliderY = device.getSlider("Z-Rotation");
  ControllSlider sliderX1 = device.getSlider("X-Achse");
  ControllSlider sliderY1 = device.getSlider("Y-Achse");
  stick = new ControllStick(sliderX,sliderY);
  stick1 = new ControllStick(sliderX1,sliderY1);
  button = device.getButton("Taste 0");
  button1 = device.getButton("Taste 2");
void draw()
  background(150);
  int speed = int(stick.getY()*255);                    // get right value for motor controller
  int steer = int((stick1.getX()*40)+90);               // get right value for servo
  int lichtval = firmata.analogRead(licht);
  float li = map(lichtval, 1024, 0, 0, 100);
  controlP5.controller("Lenkung in %").setValue((steer-90)*2.5);
  controlP5.controller("Power in %").setValue(-speed/2.55);
  controlP5.controller("Licht").setValue(int(li));
   if(button.pressed()){
  long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
  if (ledState == firmata.LOW)
      ledState = firmata.HIGH;
      ledState = firmata.LOW;
    // set the LED with the ledState of the variable:
    firmata.digitalWrite(LED, ledState);
  firmata.digitalWrite(LED, firmata.LOW);
  //println(lichtval);                                       //print different values for debuging
  if(speed > 0){
    firmata.digitalWrite(motorpin1, firmata.LOW);
    firmata.digitalWrite(motorpin2, firmata.HIGH);        //forward
    firmata.digitalWrite(standby, firmata.HIGH);
    firmata.analogWrite(motorpwm, speed);
  if(speed < 0){
    firmata.digitalWrite(motorpin1, firmata.HIGH);
    firmata.digitalWrite(motorpin2, firmata.LOW);        //back
    firmata.analogWrite(motorpwm, speed*-1);
  if(speed == 0){firmata.digitalWrite(standby, firmata.LOW);
 firmata.analogWrite(9, steer);                          //steering
Logged
Friedberg, Germany
Offline Offline
Full Member
View Profile
Interessting thing smiley
sadly I need at least 24 Servos smiley-lol
I am using a Seeduino mega.
I know it is off topic but would you be so kind and send me the xbee sketch you talked about?
Because I am gonna switch to Xbee soon.
Best regards,
Florian
Logged
Baltic Sea
Offline Offline
Newbie
Arduino rocks
View Profile
i sent u a message, but i also post it (maybe its useful for anyone).
processing:
Code:
import controlP5.*;
import java.io.*;
Serial myPort;
  println(Serial.list());
  size(1024,600);
  myPort = new Serial(this, "COM32", 57600);
  frameRate(20);
  PFont myFont;
  textFont(myFont);
  device.setTolerance(0.05f);
void draw()
  background(150);
  String n1;
  String n2;
  String sending;
  int speed = int(stick.getY()*-255+255); // get right value for motor controller
  int steer = int((stick1.getX()*45)+90);
  n1 = Integer.toString(steer);
  n2 = Integer.toString(speed);
  // if n1 or n2 is less than 4 digits add a zero to the front of them
  while (n1.length() < 4){
    n1 = '0' + n1;
  while (n2.length() < 4){
    n2 = '0' + n2;
  //combine the two 4 digit long strings into one 8 digit long one
  sending = n1 + n2;
  //write this to the serial port.
  myPort.write(sending);
  println(sending);
  controlP5.controller("Power in %").setValue(map(speed, 0, 510, -100, 100));
  fill(0);
  text("Sendestring: "+ sending, 800, 580);
  delay(20);
arduino:
Code:
#include <Servo.h>
String readString, servo1, speed2;
Servo myservo1;
int motor1 = 6;
int motor2 = 7;
int motorpwm = 5;
int standby = 4;
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(4, OUTPUT);
  Serial.begin(57600);
  myservo1.attach(9);
  while (Serial.available()) {
    if (Serial.available() >0) {
      delay(2);
char c = Serial.read();
readString += c;
  if (readString.length() >0) {
Serial.println(readString);
// expect a string like 07002100 containing the two servo positions
servo1 = readString.substring(0, 4);
speed2 = readString.substring(4, 8);
Serial.println(servo1);  //print ot serial monitor to see results
int n1;
int n2;
char carray1[6]; //magic needed to convert string to a number
servo1.toCharArray(carray1, sizeof(carray1));
n1 = atoi(carray1);
char carray2[6];
speed2.toCharArray(carray2, sizeof(carray2));
n2 = atoi(carray2);
myservo1.write(n1); //set servo position
    readString="";
    int power = map(n2, 0, 510, -255, 255);
    if (n2 > 255){
      digitalWrite(motor1, HIGH);
      digitalWrite(motor2, LOW);
      digitalWrite(standby, HIGH);
       analogWrite(motorpwm, power);
     if (n2 < 255){
      digitalWrite(motor2, HIGH);
      digitalWrite(motor1, LOW);
       analogWrite(motorpwm, power*-1);
    if (n2 == 255){
      digitalWrite(standby, LOW);
    analogWrite(motorpwm, 0);}
« Last Edit: January 29, 2011, 09:42:20 am by zh32 » Logged
Pages: [1]   Go Up
Print
Jump to:
