Vejen, Denmark
RAWR! ^,..,^
« Reply #195 on: May 09, 2011, 03:22:45 pm » |
100x M2 stainless steel bolts, nuts and washers 100x M2.5 stainless steel bolts, nuts and washers
Georgia, US
Arduino makes my head hurt :(
« Reply #196 on: May 09, 2011, 04:08:39 pm » |
* Valalvax wonders what in the world that could be for (am now noticing there is no halo or innocent whistle smiley face)
Central MN, USA
« Reply #197 on: May 09, 2011, 04:23:16 pm » |
I have m3, m2.5, and m2 screws nuts and some variety m3 standoffs. I just like their looks when I open the drawer with all different size screws  Then end up on my boards and projects. Maybe you want this surprise smiley face?
Wigan, UK
« Reply #198 on: May 10, 2011, 03:35:06 am » |
Not arduino related, but I decided to take up the guitar so bought me Westfield E4000 (Les Paul style) and a very small amp.
North Yorkshire, UK
« Reply #199 on: May 10, 2011, 05:07:33 am » |
When I buy screws or bolts I normally also buy 100 or so - they're not normally expensive and I'd rather have too many to use for a future project than run out.
Vejen, Denmark
RAWR! ^,..,^
« Reply #200 on: May 10, 2011, 02:08:27 pm » |
* Valalvax wonders what in the world that could be for (am now noticing there is no halo or innocent whistle smiley face) They are perfect for my small projects which requires mounting of sensors, switches and so on.
Newcastle, England
Always learning!
« Reply #201 on: May 10, 2011, 02:31:47 pm » |
30X BC108B transistors 1 meter of wire 3X 12 way 3A terminal block 5X 1K resistors 2X 74HC595 shift registers All for my LED cube. Stupidly, I somehow forgot 30 resistors! (I am using a shift register to turn on a transistor, which will be connected to either 1 of 25 columbs, or 1 of 5 layers - hence the 30 transistors. To make sure I do not put too much power into the transistor bases, I will be using a resistor between the shift register output and the transisitor base. I forgot to buy these resistors, so I need to get them to complete my project). Onions.
Kortrijk, Belgium
Young geek
« Reply #202 on: May 10, 2011, 02:52:15 pm » |
30X BC108B transistors 1 meter of wire 3X 12 way 3A terminal block 5X 1K resistors 2X 74HC595 shift registers All for my LED cube. Stupidly, I somehow forgot 30 resistors! (I am using a shift register to turn on a transistor, which will be connected to either 1 of 25 columbs, or 1 of 5 layers - hence the 30 transistors. To make sure I do not put too much power into the transistor bases, I will be using a resistor between the shift register output and the transisitor base. I forgot to buy these resistors, so I need to get them to complete my project). Onions. Seems like you forgot the LEDs too xD
Sorry God members, I'm an atheist.
Newcastle, England
Always learning!
« Reply #203 on: May 10, 2011, 03:08:19 pm » |
Denver
Inactive - PM
« Reply #204 on: May 12, 2011, 09:44:50 am » |
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom." ~ Clifford Stoll
Boston area, metrowest
« Reply #205 on: May 12, 2011, 10:56:03 pm » |
Nice scope. Where from, how much, do you mind sharing?
Denver
Inactive - PM
« Reply #206 on: May 12, 2011, 11:01:35 pm » |
Not at all, click the link under the picture.
« Last Edit: May 12, 2011, 11:08:55 pm by bHogan »
Boston Suburbs
I am above your silly so-called "Laws", Mister Ohm.
« Reply #207 on: May 13, 2011, 01:59:00 am » |
$1.29 - L298 Dual Full Bridge Stepper Controller
$1.25 - UL2003 stepper controller module |
Both free shipping.. sure it'll take two weeks, but I'm not waiting on them for anything, they are going in the "parts to mess with" bin. I love eBay components from Hong Kong and Singapore.. Oddly enough the only folks I ever have had any problem buying anything from weren't halfway across the planet.
« Last Edit: May 13, 2011, 02:12:53 am by focalist »
When the testing is complete there will be... cake.
North Yorkshire, UK
« Reply #208 on: May 13, 2011, 02:46:36 am » |
Creative ZEN Style 100 8GB (Ok I didn't buy it but was given it - still count?) Shame there's no RockBox Port for it yet. I would have a play with it but I'd rather not brick it yet as it's quite a nice player
« Last Edit: May 13, 2011, 02:48:15 am by mowcius »
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #209 on: May 13, 2011, 04:30:54 am » |
Atten hot-air rework station:  As reviewed by Dave Jones: Haven't set fire to anything with it yet ... It cost me $AU 69.99 - including delivery!
« Last Edit: May 13, 2011, 04:33:50 am by Nick Gammon »
