Topic: [BUG] STuff like "CODE" on new forum.??? (Read 2380 times) previous topic - next topic
TerryKing
Jan 27, 2011, 11:18 pm Last Edit: Jan 29, 2011, 10:03 pm by David Cuartielles Reason: 1
I tried putting some code in, which came from the arduino IDE "Copy For Forum". It looks like this:
Code: [Select]
[quote]
 [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color]([color=#006699]"TEST 003 - Digital Pins Sink Current"[/color]);
 [color=#CC6600]pinMode[/color](2, [color=#006699]OUTPUT[/color]);      [color=#7E7E7E]// Set Load pin to Output mode[/color]
 [color=#CC6600]for[/color] (  DigPort2Test = FirstDigPort;
        DigPort2Test <= LastDigPort;
        DigPort2Test ++)
 {[color=#7E7E7E]// Loop thru Source Tests[/color]
   [color=#CC6600]digitalWrite[/color](2, [color=#006699]HIGH[/color]);              [color=#7E7E7E]// Connect HIGH Load[/color]
   [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"Digital pin "[/color]);
   [color=#CC6600]delay[/color](1000);
   [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](DigPort2Test, [color=#006699]DEC[/color]);
   [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]" Sink Test "[/color]);
   [color=#CC6600]pinMode[/color](DigPort2Test, [color=#006699]OUTPUT[/color]);      [color=#7E7E7E]// Set tested pin to Output mode[/color]
   [color=#CC6600]digitalWrite[/color](DigPort2Test, [color=#006699]LOW[/color]);  [color=#7E7E7E]// Pin Sources current HIGH     [/color]
   IntVoltsRead = [color=#CC6600]analogRead[/color](A0);
   FloatVoltsRead = a2d2float (IntVoltsRead);
   [color=#CC6600]pinMode[/color](DigPort2Test, [color=#006699]INPUT[/color]);      [color=#7E7E7E]// ReSet tested pin to Input mode   [/color]
   [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"VoltsRead = "[/color]);
   [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](FloatVoltsRead,2);
[/quote]
Am I doing that right
TerryKing
AND.. the keyboard hung right in the middle of typing... Which also happened on an earlier attempt to post...
Hmmm... What is the right way to put code in now????
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@terryking.us
bld
Testing testing... is this on?
Code: [Select]
#include <Servo.h>
Servo myservo;
Servo myservo2;
#include <Wire.h>
#include "nunchuck_funcs.h"
byte accx,accy,zbut,cbut;
const int numReadings = 50;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int readings2[numReadings];      // the readings from the analog input
int index2 = 0;                  // the index of the current reading
int total2 = 0;                  // the running total
int average2 = 0;                // the average
int inputPin = 0;
 myservo.attach(8);
 myservo2.attach(10);
 Serial.begin(19200);
 nunchuck_setpowerpins();
 nunchuck_init(); // send the initilization handshake
 for (int thisReading = 0; thisReading < numReadings; thisReading++)
   readings[thisReading] = 0;
 for (int thisReading2 = 0; thisReading2 < numReadings; thisReading2++)
   readings2[thisReading2] = 0;
 nunchuck_get_data();
 accx  = nunchuck_accelx(); // ranges from approx 70 - 182
 accy  = nunchuck_accely(); // ranges from approx 65 - 173
 zbut = nunchuck_zbutton();
 cbut = nunchuck_cbutton();
 total = total - readings[index];
 readings[index] = map(accx, 70, 182, 0, 180);
 total = total + readings[index];
 index = index + 1;
 if (index >= numReadings)
   index = 0;
 int pos = total / numReadings;
 myservo.write(map(pos, 0, 180, 50, 180));
 total2 = total2 - readings2[index2];
 readings2[index2] = map(accy, 65, 173, 0, 180);
 total2 = total2 + readings2[index2];
 index2 = index2 + 1;
 if (index2 >= numReadings)
   index2 = 0;
 pos = total2 / numReadings;
 myservo2.write(map(pos, 0, 180, 45, 160));
 delay(15);
Seems to look right when I do it.
captain-slow.dk | non contagious!
biocow
bld, try again.
In the Arduino editor go to Edit > Copy for forum. Don't just highlight the code and copy/paste.
Terry, I'm sure that feature was just for the previous forum. They will either have to tweak this forum so that the formatting tags work inside code tags or that "copy for forum" will be removed from the next software update.
For now I'd just do a regular old copy/paste.
bld
#4
Jan 27, 2011, 11:55 pm Last Edit: Jan 27, 2011, 11:57 pm by bld Reason: 1
ah, lol... Never noticed it was there xD
Quote
* Code for cross-fading 3 LEDs, red, green and blue, or one tri-color LED, using PWM
* The program cross-fades slowly from red to green, green to blue, and blue to red
* originally "dimmingLEDs" by Clay Shirky <clay.shirky@nyu.edu>
// Output
int redPin   = 3;   // Red LED,   connected to digital pin 9
int greenPin = 5;  // Green LED, connected to digital pin 10
int bluePin  = 9;  // Blue LED,  connected to digital pin 11
// Program variables
int redVal   = 1; // Variables to store the values to send to the pins
int greenVal = 1;   // Initial values are all off
int blueVal  = 1;
int i = 0;     // Loop counter
int wait = 5; // 50ms (.05 second) delay; shorten for faster fades
 pinMode(redPin,   OUTPUT);   // sets the pins as output
 pinMode(greenPin, OUTPUT);
 pinMode(bluePin,  OUTPUT);
// Main program
 i += 1;      // Increment counter
 redVal =((i<255)*i)+((i>=255)*255)+((i>511)*(512-i))+((i>766)*(i-766))+((i>=1276)*(i-1276))+((i>1530)*(1530-i))+((i>1786)*(1786-i));
 greenVal =(i<256)*(1)+(i>255)*(i-255)+(i>510)*(510-i)+(i>1020)*(1020-i)+(i>1274)*(i-1274)+(i>1530)*(i-1531)+(i>1785)*(3571-(2*i));
 blueVal =(i<764)*(1)+(i>765)*(i-765)+(i>1020)*(1020-i)+(i>1786)*(1786-i);
 if (i > 2040) //
   i = 1;
 // we do "255-redVal" instead of just "redVal" because the
 // LEDs are hooked up to +5V instead of Gnd
 analogWrite(redPin,   redVal);   // Write current values to LED pins
 analogWrite(greenPin, greenVal);
 analogWrite(bluePin,  blueVal);
 delay(wait); // Pause for 'wait' milliseconds before resuming the loop
But what is the problem here then?
What you was doing, was to put it into a [ code] tag, and everything between those will get encoded into html safe, so they will be shown right, and not processed.
biocow
Well, if you put it in a quote like that it looks nice. But if you put it in [ code ] like on the old forum then it doesn't take the formatting.
Also you have a smilie in there.
bld
Never noticed it used on the old forum. And the quote stuff is something it copies to clipboard by itself, I didn't put it there myself.
TerryKing
OK, let me Try That Again.. (I seem to say that a LOT lately)   :)
Just plain PASTE what is on the clipboard from COPY FOR FORUM:
(code fragment)
Quote
  /*---------( TEST 2 )----------------------*/
  Serial.println("TEST 002 - Digital Pins Source Current");
  pinMode(2, OUTPUT);      // Set Load pin to Output mode
  for (  DigPort2Test = FirstDigPort;
         DigPort2Test ++)
  {//Loop thru Source Tests
    digitalWrite(2, LOW);              // Connect Low Load
    Serial.print("Digital pin ");
//    delay(A2D_Delay);
    Serial.print(DigPort2Test, DEC);
    Serial.print(" Source Test ");
    pinMode(DigPort2Test, OUTPUT);      // Set tested pin to Output mode
    digitalWrite(DigPort2Test, HIGH);  // Pin Sources current HIGH
    delay(A2D_Delay);
    IntVoltsRead = analogRead(A0);
    pinMode(DigPort2Test, INPUT);      // ReSet tested pin to Input mode
    Serial.print("VoltsRead = ");
    Serial.print(FloatVoltsRead,2);
    if (FloatVoltsRead > LowVoltResultOK
      &&  FloatVoltsRead < HighVoltResultOK)
      Serial.println("  -- OK!");
      Failure ++;
      Serial.println("  ** Source FAIL ** ");
  }//END Loop thru Source Tests
Let's look at that....
OK! Thanks!
terry@terryking.us
retrolefty
#8
Jan 28, 2011, 06:25 am Last Edit: Jan 28, 2011, 06:28 am by retrolefty Reason: 1
My turn:
First using a quote window
Quote
 Blink
 Turns on an LED on for one second, then off for one second, repeatedly.
 This example code is in the public domain.
 // initialize the digital pin as an output.
 // Pin 13 has an LED connected on most Arduino boards:
 pinMode(13, OUTPUT);
 digitalWrite(13, HIGH);   // set the LED on
 delay(1000);              // wait for a second
 digitalWrite(13, LOW);    // set the LED off
Now same content in code window:
Code: [Select]
[quote]
[color=#7E7E7E]/*[/color]
[color=#7E7E7E]  Blink[/color]
[color=#7E7E7E]  Turns on an LED on for one second, then off for one second, repeatedly.[/color]
[color=#7E7E7E] [/color]
[color=#7E7E7E]  This example code is in the public domain.[/color]
[color=#7E7E7E] */[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]() {
 [color=#7E7E7E]// initialize the digital pin as an output.[/color]
 [color=#7E7E7E]// Pin 13 has an LED connected on most Arduino boards:[/color]
 [color=#CC6600]pinMode[/color](13, [color=#006699]OUTPUT[/color]);
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]() {
 [color=#CC6600]digitalWrite[/color](13, [color=#006699]HIGH[/color]);   [color=#7E7E7E]// set the LED on[/color]
 [color=#CC6600]delay[/color](1000);              [color=#7E7E7E]// wait for a second[/color]
 [color=#CC6600]digitalWrite[/color](13, [color=#006699]LOW[/color]);    [color=#7E7E7E]// set the LED off[/color]
[/quote]
Lets look:
So I guess the rule is don't post code into a code window?  :)
Lefty
TerryKing
Lets look:
Lefty
And... Don't hit the HELP button, either  :~
pwillard
You may have noticed.. I had earlier commented that it seems rather silly that QUOTE formats/highlights the pasted code somewhat and all we really get from CODE is a mono spaced font. (Essentially a <pre></pre> html tag)
The highlighter inside the "quote" feature is, to my old eyes, nearly unreadable.
Really hope this gets analyzed soon by the mods
westfw
The "code" tags explicitly DO NOT PROCESS the text between the tags.  You would have gotten similar weird looking results on the old forum.
"copy for forum" makes code into pretty quotes, but a plain copy between code tags makes for something that people can cut and paste back into the IDE.
davekw7x
#12
Jan 29, 2011, 05:30 pm Last Edit: Jan 29, 2011, 06:12 pm by davekw7x Reason: 1
Quote from: retrolefty
Suppose you are going to start a new topic. (Click the "New Topic" button on one of the sub-forums.)  Here is a recipe for posting code:
  • In the Arduino IDE, highlight the code that you are going to post.
  • Copy/Paste the code into the edit part of the "New Topic" window of the forum
  • Highlight the code in the edit pane. (Not your narrative or other text, just the code.)
  • Click the "#" on the second row of icons of the "New Topic" window
  • Click the "Preview" button at the bottom of the window.
It puts "code tags" around the highlighted part.  That preserves formatting and shows the code in a nice, clear monospace font.  (Who needs that annoyingly ugly and inconsistent color highlighting when posting code here, anyhow?)
Here's some code in "code tags."  (See Footnote.)
Code: [Select]
 Blink
Of course if you are going to reply to a particular post rather than starting a new thread, you click the "Reply" button on that post and go through the same steps in the edit window.
Regards,
Dave
Footnote:
If you want to see how other people get their stuff to look the way that it does, then click the "Quote" button in the window of that response.  (Pretend you are going to reply.)
It shows the various markup tags that were used.  Most of them can be applied by highlighting some stuff and clicking one of the icons in the "Post reply" window.  (Or you can enter them yourself.)
It would be a Good Thing if people would always (always) click "Preview" before posting, and it would be a Really Good Thing if people would not post the entire thread when using the "Quote" button.  (But I'm not holding my breath...)
David Cuartielles
This is a pretty valuable topic. I will add the comments to my todo list. Obviously we should have a proper functionality for this. Code should come for Code and not for Quote ... we will fix it, but there are other things to fix first,
thanks, I keep it open so that I don't forget
/d
