Topic: PROBLEMA CON EL ROBOT THREE WHEELED (Read 147 times) previous topic - next topic
flash6386
Sep 23, 2017, 02:58 pm Last Edit: Sep 23, 2017, 04:36 pm by flash6386
Hola soy flash6386 y tengo un problema:
Al comprar un robot de compañia freenove, en un winrar the venía lo que as de programar en tu robot y esto es:
  Sketch    Remote control mode sketch for car
  Platform  Freenove Three-wheeled Smart Car Kit for Arduino
  Author    Ethan Pan @ Freenove (http://www.freenove.com)
  Date      2016/10/7
  Brief     This sketch is used to achieve remote control mode for Freenove Three-wheeled
            Smart Car Kit for Arduino. This sketch needs to be uploaded to the car.
            The car needs to install NFR24L01 wireless communication module, can choose to
            install RGB LED module and passive buzzer module.
  Copyright Copyright © Freenove (http://www.freenove.com)
  License   Creative Commons Attribution ShareAlike 3.0
            (http://creativecommons.org/licenses/by-sa/3.0/legalcode)
// NRF24L01
#include <SPI.h>
#include "RF24.h"
RF24 radio(9, 10);                // define the object to control NRF24L01
const byte addresses[6] = "Free1";// define communication address which should correspond to remote control
// servo
#include <Servo.h>
Servo dirServo;                  // define servo to control turning of smart car
const int dirServoPin = 2;        // define pin for signal line of the last servo
byte dirServoOffset = 0;          // define a variable for deviation(degree) of the servo
// motor
const int dirAPin = 7,            // define pin used to control rotational direction of motor A
          pwmAPin = 6,            // define pin for PWM used to control rotational speed of motor A
          dirBPin = 4,            // define pin used to control rotational direction of motor B
          pwmBPin = 5,            // define pin for PWM used to control rotational speed of motor B
          snsAPin = A0,           // define pin for detecting current of motor A
          snsBPin = A1,           // define pin for detecting current of motor B
          buzzerPin = 3,          // define pin for buzzer
          ledRPin = A3,           // define R pin of RGBLED
          ledGPin = A4,           // define G pin of RGBLED
          ledBPin = A5;           // define B pin of RGBLED
const byte motorSpeed = 255;      // define motor speed(0-255)
#define FORWARD LOW
#define BACKWARD HIGH
// wireless communication
int dataRead[8];                  // define array used to save the read data
const unsigned long wirelessOvertime = 200; // define communication overtime(ms)
unsigned long lastReceivedSignal; // define a variable to save the time(ms) of last received the signal
  // serial port
  // NRF24L01
  radio.begin();                      // initialize RF24
  radio.setPALevel(RF24_PA_LOW);      // set power amplifier (PA) level
  radio.setDataRate(RF24_1MBPS);      // set data rate through the air
  radio.setRetries(0, 15);            // set the number and delay of retries
  radio.openWritingPipe(addresses);   // open a pipe for writing
  radio.openReadingPipe(1, addresses);// open a pipe for reading
  radio.startListening();             // start monitoringtart listening on the pipes opened
  // servo
  dirServo.attach(dirServoPin); // attaches the servo on dirServoPin to the servo object
  // motor
  pinMode(dirAPin, OUTPUT);     // set dirAPin to output mode
  pinMode(pwmAPin, OUTPUT);     // set pwmAPin to output mode
  pinMode(dirBPin, OUTPUT);     // set dirBPin to output mode
  pinMode(pwmBPin, OUTPUT);     // set pwmBPin to output mode
  // pin
  pinMode(buzzerPin, OUTPUT);   // set buzzerPin to output mode
  pinMode(ledRPin, OUTPUT);     // set ledRPin to output mode
  pinMode(ledGPin, OUTPUT);     // set ledGPin to output mode
  pinMode(ledBPin, OUTPUT);     // set ledBPin to output mode
  digitalWrite(ledRPin, HIGH);  // turn off R LED
  digitalWrite(ledGPin, HIGH);  // turn off G LED
  digitalWrite(ledBPin, HIGH);  // turn off B LED
  // read radio data
  if ( radio.available()) {             // if receive the data
    while (radio.available()) {         // read all the data
      radio.read(dataRead, sizeof(dataRead));   // read data
    // calculate the angle of turning
    int dirServoDegree = map(dataRead[2], 0, 1023, 135, 45) - (dataRead[0] - 512) / 25;
    // calculate speed of moving
    int motorSpd = dataRead[3] - 512 + (dataRead[1] - 512) / 10;
    bool motorDir = motorSpd > 0 ? BACKWARD : FORWARD;
    motorSpd = abs(constrain(motorSpd, -512, 512));
    motorSpd = map(motorSpd, 0, 512, 0, motorSpeed);
    // control the turning and moving of the car
    ctrlCar(dirServoDegree, motorDir, motorSpd);
    // control the buzzer
    if (!dataRead[4])
      tone(buzzerPin, 2000);
      noTone(buzzerPin);
    // control the RGB LED
    digitalWrite(ledRPin, dataRead[5]);
    digitalWrite(ledGPin, dataRead[6]);
    digitalWrite(ledBPin, dataRead[7]);
    // save the time of last received the wireless signal
    lastReceivedSignal = millis();
  else {
    // if lose wireless signal for a long time
    if (millis() - lastReceivedSignal >= wirelessOvertime) {
      // stop the car
      analogWrite(pwmAPin, 0);
      analogWrite(pwmBPin, 0);
      // turn off the buzzer
      noTone(buzzerPin);
      // turn off the RGB LED
  // send motor current to serial port
  float iMotorA = analogRead(snsAPin) * 5.0 / 1024 / 30 / 0.05;
  float iMotorB = analogRead(snsBPin) * 5.0 / 1024 / 30 / 0.05;
  Serial.print("iMotorA: ");
  Serial.print(iMotorA);
  Serial.print(" A ,iMotorB: ");
  Serial.print(iMotorB);
  Serial.println(" A");
void ctrlCar(byte dirServoDegree, bool motorDir, byte motorSpd) {
  dirServo.write(dirServoDegree + dirServoOffset);
  digitalWrite(dirAPin, motorDir);
  digitalWrite(dirBPin, motorDir);
  analogWrite(pwmAPin, motorSpd);
  analogWrite(pwmBPin, motorSpd);
Cuando enciendo el robot automáticamente las ruedas se van hacia la parte derecha y empieza vibrar.
Ayuda por favor. Que alguien me ayude que sigo sin respuesta
surbyte
Doble post.
Hilo cerrado y luego borrado.
