Topic: Servo Control (Read 6991 times) previous topic - next topic
zoomkat
People really need to do a reality check on servo based cam pan/tilt systems. Nobody can expect to get a $15 hobby servo pan/tilt to compare to a $1.5k servo pan/tilt, or a $150k professional cam conrol system. As to hobby servo based pan/tilt systems, the quality of operation depends a lot on the quality of design and control used in the construction.
http://www.servocity.com/html/pt-2100_pan__tilt_system.html
http://www.servocity.com/html/pan_tilt_roll___accessories.html
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
jraskell
I tired 1000 delay after the attach, I should do that after the command to, didn't try that.
I will try thanks.
You should try to make your code a little smarter about how much delay it needs.  All servos have an advertised speeds, typically in seconds per 60º (which has always seemed rather odd to me, but that's the standard).  A bit of quick math can give you a value of say, milliseconds per degree.
So say your servo takes 0.17 second to rotate 60 degrees (that's fairly typical for a hobby servo, not too fast, not too slow).  That is 170ms to rotate 60º or 170/60 = 2.83ms to rotate 1º.   Round that up to 3ms per degree.
As long as you keep track of your current position, and your target position, you can easily calculate how long it will take for your servo to move to the new position.
I'd also recommend handling the pan & tilt together.  That way it pans and tilts at the same time, one synchronous, smooth operation, as opposed to first panning, then tilting serially.
PaulS
Quote
Given the typical use for a hobby servo, such as steering a car, positioning a rudder, operating as a throttle, etc., 60 degrees is generally the full range that the servo needs to sweep. How much throttle travel do you have, and how much servo movement is required to make the throttle travel that far?
jraskell
Quote
Well there you go.  Makes more sense knowing that.  Guess I've never used hobby servos in the manner they were designed for. :)
andersmmg
#19
May 17, 2016, 12:59 am Last Edit: May 17, 2016, 01:04 am by andersmmg
Code wise; yes, it should definitely work. Servo.attach() and Servo.detach()
are often used that way because it leaves more memory, and so that you can work more efficiently with battery power and such. Physically, though, it would need to be placed in such a way that it would not move because of gravity, or the like.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
