Topic: translating a potentiometer readings into a range of values (Read 1 time) previous topic - next topic
beer lover
hello
I am sure this is an easy 1
I have a potentiometer that I want to use as a temp controller with a sht15 sensor. I need to translate the 0 - 1023 range of the potentiometer to a range of 50F-100F
so I know 0 is 50F and every 20.48 it would advance a degree
What would be the best method to code this?
thanks
mjb
Hi beer lover!
Try this: http://www.arduino.cc/en/Reference/Map
Cheers!
retrolefty
#2
Jan 28, 2011, 07:49 pm Last Edit: Jan 28, 2011, 07:54 pm by retrolefty Reason: 1
Simple, use the map() function:
int tempF;
int raw;
raw = analogRead(pin#);
tempF = map(raw, 0, 1023, 50, 100);
This will only give you increments of full degrees, but you could do:
tempF = map(raw, 0, 1023, 500, 1000);
And then convert tempF to float and divide by 10.0 ? Or something like that.  :)
Lefty
beer lover
janeik
hi.
Does this work for unlinear behaviour too?
regards
int tempF;
int raw;
Lefty
retrolefty
Quote
No. For non-linear one would need to calculate the mapping for each point or use a look-up table.
However I'm more hardware experienced then software, so maybe someone else can give you a more complete and/or correct answer.
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
