Loading...
Pages: [1]   Go Down
Author Topic: Testing Arduino Boards, I/O Pins etc.. Test Shield - Test Software  (Read 4531 times)
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
Maybe this shoulda been here:
http://arduino.cc/forum/index.php?topic=50203.0
More stuff at: http://terryking.us/arduino-testing.htm
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
UK
Offline Offline
Full Member
Kittens eat Arduinos
View Profile
Hi - I like the idea smiley that I can test the arduino board easily.
To eliminate the nagging thought that I damaged it by mistake, and so the software does not work!!
I rarely solder - mainly just to put pins on for use in a solderless breadboard, so although I have a mega, am mostly using my mini...
I think that I could set up a breadboard with the resistors as you describe, and have a test location for the mini - does that make sense?
Logged
USA
Offline Offline
Full Member
Arduino rocks
View Profile
Terry
Your test methods look very good and the way you did the board makes a lot of sense.
I helped develop the official test suite for Arduino, if you could re-write your test using the standardized testing library, we could incorporate it into the full test suite.  Your test would stay the same, the only thing that would change would be the format of the output.
http://code.google.com/p/arduino/wiki/ArduinoTestSuite
Mark
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Of course that would leave mega based boards not tested on all their avalible pins.
Lefty
Logged
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
Quote
Lefty
@LEFTy you're RIGHT, which happens pretty often  smiley  I will be making a MEGA Test Shield soon.  IF this seems like a good approach a real Shield with SM resistors etc. could be made.
@MARK, please get in touch about this: terry@yourduino.com
I have a long background in chip testing at IBM and I've been thinking of writing some more detailed self-test code for Arduino internals, memory etc. With the idea that Arduino users could run some kind of confidence tests long after their Arduino left the factory.  There must be code from ATMEL??
Of course there's a lot of guts that can't be tested in a self-test mode.. But I think we can assume that ATMEL did OK at Chip Test and now we are mostly looking for Board Connectivity and I/O pin damage issues.
What's your opinion about this stuff?? Should we start a new thread??
Logged
Pages: [1]   Go Up
Print
Jump to:
