Topic: TVout: NTSC and PAL Composite Video Output. (Read 22157 times) previous topic - next topic
mdmetzle
@mdmetzle, Thanks!
I am looking for a way to get the tvout lib to let one pin go HIGH when there is a white pixel, and another pin go HIGH when there is a black pixel..
it should probably be done close to here, but i don't understand this..:
__asm__ __volatile__ (
   "ADD   r26,r28\n\t"
   "ADC   r27,r29\n\t"
   //save PORTB
   "IN      r16,%[port]\n\t"
   "ANDI   r16,0xFD\n\t"
(the above is from version 3 of the tvout lib, video_gen.ccp).
The first two lines are a 16bit add and are calculating the pointer to the current render line in the frame buffer.  The second 2 lines grab the port containing the output pin and set it to the video pin to low and the sync pin(if applicable in later versions) high.  Then through out the rest of the line rendering routine the video pin is modified and the rest of the port is left alone.  If you dont care about the port status then the these lines are not needed.
leo72
Hello.
A couple of days ago I tried to realize a little idea of mine...
I used 2 standalone Atmega328 on a breadboard: the first one runs a sketch that uses the PS2Keyboard lib to read the input from a PS2 keyboard, the second one has a sketch inside che reads the input from the first Atmega and then sends the output on the TV.
But I'm having a strange problem: keys that I see on the TV are different from the ones I press on the keyboard.... I.E. I get [ESC] from "h" or "3[ESC]" from "7" etc...
Strange because if I connect the first Atmega to an Arduino and send the keys I read from the keyboard to a serial terminal open under the Arduino IDE I can see the correct keys (i.e. if I digit "h"-"e"-"l-"l"-"o" I see "hello"), so I can say for sure that the connection of the keyboard is OK. It seems that "pollserial" doesn't read the correct datas.
I connected the 2 Atmega using pins 2 and 3 (RX & TX): of course, 2->3 and 3->2.
This is the sketch on the first Atmega:
Code: [Select]
/*  PS2Keyboard library example*/
#include <PS2Keyboard.h>
const int DataPin = 2;
const int IRQpin =  3;
PS2Keyboard keyboard;
  delay(2000);
  keyboard.begin(DataPin, IRQpin);
  if (keyboard.available()) {
    // read the next key
    char c = keyboard.read();
    // check for some of the special keys
    if (c == PS2_ENTER) {
    } else if (c == PS2_TAB) {
      Serial.print("[Tab]");
    } else if (c == PS2_ESC) {
      Serial.print("[ESC]");
    } else if (c == PS2_PAGEDOWN) {
      Serial.print("[PgDn]");
    } else if (c == PS2_PAGEUP) {
      Serial.print("[PgUp]");
    } else if (c == PS2_LEFTARROW) {
      Serial.print("[Left]");
    } else if (c == PS2_RIGHTARROW) {
      Serial.print("[Right]");
    } else if (c == PS2_UPARROW) {
      Serial.print("[Up]");
    } else if (c == PS2_DOWNARROW) {
      Serial.print("[Down]");
    } else if (c == PS2_DELETE) {
      Serial.print("[Del]");
      // otherwise, just print all normal characters
      Serial.print(c);
This is the sketch that is running on the second Atmega:
Code: [Select]
#include <TVout.h>
#include <pollserial.h>
#include <fontALL.h>
TVout TV;
pollserial pserial;
void setup()  {
  TV.begin(_PAL,120,96);
  TV.select_font(font6x8);
  TV.println("Terminale seriale");
  TV.println("-- Versione 0.1 --");
  TV.set_hbi_hook(pserial.begin(9600));
  if (pserial.available()) {
    TV.print((char)pserial.read());
pocketscience
Is life really that serious...??!
leo72
What do you mean?
That I don't have to use common grounds or that I have to use them?  :smiley-roll-sweat:
mdmetzle
Does the tvout sketch work when you send data from the pc?
leo72
I have to try it with my notebook. Until now I didn't try this test because my PC is far from the TV set.
I'll do a test later (I'm at work now).
pocketscience
Should we expect to be able to create a portrait screen - eg 96x128? Seems the current TVout lib doesn't like it. The first row of the display is positioned up beyond the viewable part of the TV screen. I did a simple TV.print and only the bottom half of the text was visible.
Cheers,
film4scott
TvOut seems a marvelous solution to my specialized Arduino need.  I have succeeded in making an Arduino into what I call a Grobot rover, from a child's riding toy...  but well-timed composite output is slightly beyond my programming and workshop skills and tech.
Are there resources on the Arduino forums to hire freelance Arduino video experts?
I need a variation of TvOut that allows me to sync a non-genlock camera to another genlockable device expecting only Black (as opposed to Black Burst, tho any advanced sync signal will work too).
My design approach to the problem is to slightly increment/dec. the time length of a single field by a useful number of uSeconds, thus the Arduino-genlocked device does not loose sync and regain it, but shifts slightly in time until I can confirm full sync between camera and device by means of a dual trace scope.
This device is for an indie feature film - an Arduino-friendly enterprise with tolerances for slightly-less-than-perfect specs, and a budget to match.
fiero79
I am having the following problem...'TVOUT' does not name a type in the DEMONTSC.pde File
Why?
Charlie
pocketscience
TVout, not TVOUT - C is case-sensitive.
G.
fiero79
I am sorry, I just looked again, it is:
TVout TV;
not TVOUT like I typed earlier.  I simply opened the demo and tried to verify it before uploading it.  It is not working as I downloaded it.  I made no changes to the code.
DemoNTSC from the TVoutBeta1.zip
Help.
Charlie
pocketscience
Did you install the library correctly into your Arduino environment?
fiero79
I hadn't installed a custom library in a while, so I went to Arduino help pages and followed the directions exactly.
Thanks for your help in advance.
Charlie
fiero79
I think I misled with my last post...  I hadn't done a custom library install in a while so I used the procedure from arduino.cc to do the install, and the problem is still there.  I used the correct procedure, but TVout TV;
is still kicking the previously mentioned error.
Charlie
pocketscience
Do other libraries work? I never had any issues using the library after simply copying it to the Library folder and restarting the IDE. Methinks your problem might be unrelated to the TVout library...
Are you on Windows, Linux or Mac?
G.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
