Loading...
Pages: 1 2 3 [4] 5   Go Down
Author Topic: TVout: NTSC and PAL Composite Video Output.  (Read 6014 times)
Offline Offline
Newbie
View Profile
windows xp, arduino ide 22, and never had any problems with other libraries...
Charlie
Logged
Minneapolis, MN USA
Offline Offline
Full Member
Never catch a falling soldering iron...
View Profile
WWW
@fiero79, please ensure that your directory structure is this:
Code:
Arduino (your sketchbook directory)
    +--libraries
          +--TVout
          +--TVoutfonts
          +--pollserial
Restart Arduino after you install the TVout libraries in this manner.  If you still have a compilation problem, please post it exactly using copy/paste so we can see what is going on.
Logged
Canada
Offline Offline
Newbie
View Profile
I built this plugged it in the tv and nothing happened. I cheked my circuit, centre pin through 1k to pin 9 ,centre pin through 470r to pin 7 ,. For some reason the pal woks better than NTSC though I live in canada where NTSC is used. see attached pics for result of tests. in pal i can barely see the text and it moves diagonally. can someone please help make it work?
Logged
Offline Offline
Newbie
View Profile
After updating to Arduino IDE 22 I think that someone needs to address the issue of where custom libraries go. I put the Files for TVout into the sketch folder    \My Documents\Arduino\libraries, and that didn't work.  I added it to the C:\Program Files\arduino\arduino-0022\libraries directory, and it works now. at least it compiles now, I will try it with the hardware later.
Charlie
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Hi, I would like to ask if is possible to mix output of Arduino TVout and composite signal of videocamera?
I would write a bit of information superimposed on the camera image.
See attachment for example.
Thanks.
Bye bye.
Logged
Minneapolis, MN USA
Offline Offline
Full Member
View Profile
WWW
Quote
Yes, the Video Experimenter shield allows you to do exactly that (and many other things).
http://nootropicdesign.com/ve/
This project shows text/graphics generated from TVout being overlayed on a composite signal:
http://nootropicdesign.com/projectlab/2011/03/20/text-and-graphics-overlay/
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Very good smiley
Compliment for your job smiley
But, do you know the cpu charge with tvout?
Arduino can work togheter tvout with other  processes for example calculation of GPS coordinate?
Thanks.
Bye.
Logged
Boston Suburbs
Offline Offline
God Member
I am above your silly so-called "Laws", Mister Ohm.
View Profile
WWW
The CPU load is surprisingly workable:
http://arduino.cc/blog/2010/11/16/arduino-realtime-audio-spectrum-analyzer-with-video-out/
Using the TVout lib, I made a spectrum analyzer- which not only performs the TVout, but also manages to do the sampling and fourier transformations in realtime.
So, there's PLENTY for some GPS calcs...
Logged
When the testing is complete there will be... cake.
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Very very good:)
My project is beginning to have all the requirements to take off.
Thanks.
Logged
Minneapolis, MN USA
Offline Offline
Full Member
View Profile
WWW
I agree, there's plenty of CPU time for most applications.  I have written complex video games with lots of geometric calculation, and all my games have needed to be artificially slowed down with delays so that the player can keep up.   smiley-lol
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Hi, I must only superimpose strings in another video source.
For my needs, Video experimenter is too big.
Is possible to have electrical scheme for build a small pcb?
I must using arduino mini for space exigence and weight.
Thanks.
Logged
Minneapolis, MN USA
Offline Offline
Full Member
View Profile
WWW
Yes, you could design a small PCB that uses an SMD version of the LM1881.  Sounds like you are trying to build a drone, huh?
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
My ideas is to build a telemetry system for multicopter used for fpv.
Logged
gedrop
Offline Offline
Jr. Member
View Profile
WWW
here is a video mixer i made with a modified version of the tvout lib
http://gieskes.nl/visual-equipment/?file=gvm1
Logged
gedrop
Offline Offline
Jr. Member
View Profile
WWW
Logged
Pages: 1 2 3 [4] 5   Go Up
Print
Jump to:
