Topic: TVout: NTSC and PAL Composite Video Output. (Read 26500 times) previous topic - next topic
gijs
video sampler: http://gieskes.nl/visual-equipment/?file=gvs1
http://vimeo.com/26420870
http://vimeo.com/26442419
nootropic
Very very nice.  That is really awesome work, gijs.
gijs
thanks! and also thanks for the video input in the tvout lib, it would not have been possible without it.
domspitze
Hey,
I need your help.
I´m working with TV-Out-Audio R.5.91 and an Arduino Duemilanove with an ATMEGA328. Everything works fine. But I have few questions:
1) TVOut needs a lot of RAM as Videoram. Knows someone how many RAM is left?
2) Maybe I will need more RAM. Is it possible to use 23K256 SPI RAM. Is SPI working?
3) I would like to use EEPROM (24LC256) (I2C) too. Is I2C working?
Thanks!
spookyrufus
Is the signal generated by TVOut standard or slightly different?
I'm trying to capture that signal with a USB dognel on my laptop but it doesn work, while it perfectly works with any other device.
I tried already putting that 25 ohm resistor but it didnt change anything. Any help?
nootropic
The vertical sync is not quite standard.  So some devices will not work.  I have not found a device that doesn't work, but your USB device may be too picky about the standard.
spookyrufus
Is there something I could do to try to fix the problem?
I've spent way too much time after this damn EasyCAP USB device to just give up. And starting from next week, I will move back to Estonia where I won't have a TV, so it's my only chance to keep experimenting.
pocketscience
I have an EyeTV Hybrid and have never had any luck getting TVOut to work with it, which is a shame as it would make recording demos etc much easier!
G.
Osgeld
anyone figure out how to get ps2 keyboard and tvout to play nice?
