Topic: Arduino Serial Monitor (Ubuntu 10.04 64bit) [SOLVED] (Read 9589 times) previous topic - next topic
IAmCorbin
Jan 29, 2011, 09:15 pm Last Edit: Feb 06, 2011, 06:55 am by IAmCorbin Reason: 1
I am still having trouble reading serial output from the Arduino. I am able to do it via the linux terminal but it crashes the Arduino IDE when I open the monitor. I also get the same error when I try and use the RxTx library to read serial with java through Eclipse.
If I run the Arduino IDE as root it results in the same crash as well.
The Arduino monitor actually worked when I first installed it up until I ran this command:
Code: [Select]
stty -F /dev/ttyUSB0 cs8 9600 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts
which now allows me to use the command:
Code: [Select]
tail -f /dev/ttyUSB0
to read the serial output to the terminal
Here is the original post with all the details: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1295756150
mrtaylor
I have working on another problem which may or may not be related to yours. so I have to ask what kernel version are you running? (uname -mrs)
mellis
In the original post, it looks like you had a version mismatch between the RXTX jar and the native library.  Have you tried it with both pieces at 2.2pre2 (or whatever the latest version for your distribution is)?
IAmCorbin
@mrtaylor - I am running Linux 2.6.32-24-generic x86_64
@mellis - I tried updating to the latest version multiple times but can't seem to update my native lib version. Does this just mean there is a RxTx jar on my system I need to replace with the latest version? I thought I had moved all the RxTx files to the necessary locations, but I guess not?
mellis
The native lib is probably called something like libRXRX.so or librxtxSerial.so or similar.  I'm not sure where it is, but having a mismatch between the Java and native version of the library could definitely cause problems or crashes.
IAmCorbin
#5
Feb 05, 2011, 12:54 am Last Edit: Feb 06, 2011, 06:36 am by IAmCorbin Reason: 1
I'm trying to search for the old library files like so:
Code: [Select]
find /. -readable -name *RXTX*
find /. -readable -name *rxtx*
But the only results are in my arduino workspace directory where I downloaded the rxtx files.
Does anyone else know where these files are hiding? or why it's still showing the old native versions when I can't even find them on the system?
mrtaylor
#6
Feb 05, 2011, 04:11 am Last Edit: Feb 05, 2011, 04:18 am by mrtaylor Reason: 1
find / -ls 2>&1 | grep -i librxtxSerial
edit added:  I believe my is the same.  mine works great.
./arduino
Stable Library
Native lib Version = RXTX-2.2pre2
Java lib Version   = RXTX-2.1-7
WARNING:  RXTX Version mismatch
   Jar version = RXTX-2.1-7
   native lib Version = RXTX-2.2pre2
mrtaylor
I believe and don't quote me on this, your problem is related to a bug in the linux kernel.
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/690798.  This is a long and drawn out bug and seems to affect a lot of different kernel versions.  Maybe you could search and find a kernel that works and upgrading to that kernel.
The kernel version I am running is: Linux 2.6.35-25-generic x86_64
IAmCorbin
Alright, I upgraded my kernel to 2.6.32-28 and was still getting the same crash.
I found and replaced the conflicting RXTX files with the 2.2pre2 version ones and now it is working. Thanks for the help.
mrtaylor
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
