AVR today, ARM tomorrow(or so).
« on: January 29, 2011, 06:31:15 pm » |
Guys,
Had success sending light sensor data(first divide by 10 to convert to char data type before transmitting) from remote Arduino/Data Shield/XBee----->XBee/Arduino/PC. The data made sense and identical to that when I monitor the Serial output of the transmitting unit alone.
However: when I try to send temp AND light sensor data(again divided by 10 to keep within integer range of char data type), the light reading is way too high and in fact not consistent. I know there's a simple explanation, but I've struggled with different timing, checked Forum with as many search strings as I could think of, checked Tom Igoe's book which I own, tried to adapt SerialCallResponse for use with Arduino without Processing, and as I'm not a programmer I am stuck.
Light data should be ranging between 40-60(raw data would be 400-600), but I'm getting 191, 170's and inconsistent.
It's been two weeks for me to bother you all with this.
Without posting code yet, is there any code for synchronization you can suggest or general suggestions for newbie pitfalls?
« Last Edit: January 29, 2011, 06:34:46 pm by cfc »
Seattle, WA USA
Online
Seattle, WA USA
« Reply #1 on: January 29, 2011, 08:13:20 pm » |
If the data you are transmitting is from analogRead, dividing by 4 will give the best results (greatest precision). We'd need to see the code that you are using to send/receive the data to suggest any good solutions.
« Reply #2 on: January 29, 2011, 11:51:00 pm » |
Re: dividing by four: yes, but that will cause the values to excede 127 and therefore be beyond range of char data type - that is, out of range of the integer equivalent of char data type....I tried dividing by 4, but even the single data case did not work out.
/*TRANSMITTER:
COM 12 Arduino/Xbee TRANSMITTER using NewSoftSerial to be able to program Arduino without messing having to disconnect Tx and Rx pins to program, then reconnect to use the Xbee */
#include <NewSoftSerial.h>
int lightPin = 1; //analog input pin 1 int tempPin=0; int light = 0; int temp=0;
NewSoftSerial mySerial=NewSoftSerial(5,6); //use these pins on DataLoggerShield, //...connect to XBee Tx(Arduino Rx) and XBee Rx(Arduino Tx), respectively
void setup () { mySerial.begin(57600);
} //END SETUP
void loop () { temp=analogRead(tempPin)/10; delay(10); light = analogRead(lightPin)/10; //scale down for char data type transmission mySerial.print(char(temp)); //always send as CHAR data type for Rx to work mySerial.print(char(light)); Serial.print(temp); Serial.print(" "); Serial.println(light); delay(100);
/*RECEIVER:
COM 8 Arduino/Xbee RECEIVER using NewSoftSerial to be able to program Arduino without messing having to disconnect Tx and Rx pins to program, then reconnect to use the Xbee Also we use Ethernet Shield once the below works */
#include <NewSoftSerial.h> int light=0; int temp=0; int inByte=0; int dataArray[]={0,0};
NewSoftSerial mySerial=NewSoftSerial(5,6); //use these pins on Arduino, //...connect to XBee Tx(Arduino Rx) and XBee Rx(Arduino Tx), respectively
void setup () { mySerial.begin(57600); Serial.begin(57600); // use the COM8 monitor to test this; if OK then do the server thing
} //END SETUP
void loop () { while(mySerial.available()>0){ for(int i=0;i<2;i++){ inByte=mySerial.read(); dataArray=inByte; } temp=dataArray[0]; light=dataArray[1]; Serial.print(temp); Serial.print(" "); Serial.println(light); } inByte=0; }
« Last Edit: January 29, 2011, 11:52:54 pm by cfc »
Seattle, WA USA
Online
Seattle, WA USA
« Reply #3 on: January 30, 2011, 12:31:52 am » |
that is, out of range of the integer equivalent of char data type So what? The type that Serial.write() outputs is byte, not char. The range of values for byte is 0 to 255. That happens also to be that same type that Serial.read() returns. Coincidence? Not hardly. //always send as CHAR data type for Rx to work Wrong. Always use byte data type. You should be using either Serial.write(temp) or Serial.print(temp, BYTE). Otherwise, the value is converted to a string, to be sent. That is what is happening to you. Then, you only read the first character of the string, and treat that as the value, If temp is, after dividing by 10, 75 for instance, it is sent as '7' and '5'. The ascii codes for 7 and 5 are 55 and 53.
« Reply #4 on: January 30, 2011, 11:53:53 am » |
I tried dividing by 4 then sending as BYTE, with same result.....light data(second column) still wrong and inconsistent. So, now what? Is there a way to synchronize the two Arduinos? Something like a SerialCallResponse for only Arduino without Processing being involved?
BY the way, the SoftSerial library shows that the read() function reads a character, not a BYTE(?)
Thank you.
« Last Edit: January 30, 2011, 12:32:12 pm by cfc »
Seattle, WA USA
Online
Seattle, WA USA
« Reply #5 on: January 30, 2011, 03:39:07 pm » |
I tried dividing by 4 then sending as BYTE, with same result Where is the new code? while(mySerial.available()>0){ for(int i=0;i<2;i++){ inByte=mySerial.read(); [color=orange]dataArray=inByte;[/color] } temp=dataArray[0]; light=dataArray[1]; Serial.print(temp); Serial.print(" "); Serial.println(light); } I'm surprised that this even compiles. You have an array on one side of the = and a scalar variable on the other. Try dataArray = inByte; instead.
BY the way, the SoftSerial library shows that the read() function reads a character, not a BYTE(?) That's NewSoftSerial, and bytes and chars are the same size, so they are interchangeable to some extent. Some functions behave differently (like Serial.print()) when called with a char vs. when called with a byte.
« Reply #6 on: January 30, 2011, 04:07:55 pm » |
The code posted above is not what I had...it was for RECEIVER:
FOR THE TX: I divided the raw analog data/4 then mySerial.print(temp, BYTE) and same for light data
Seattle, WA USA
Online
Seattle, WA USA
« Reply #7 on: January 30, 2011, 04:20:42 pm » |
Idiotic forum software is interpreting [ i ] without spaces as italics. while(mySerial.available()>0){ for(int i=0;i<2;i++){ inByte=mySerial.read(); dataArray=inByte; } temp=dataArray[0]; light=dataArray[1]; Serial.print(temp); Serial.print(" "); Serial.println(light); } This code contains several problems. The mySerial.available() test determines that there is at least one byte to read. If that is the case, you read two. Hmmm, OK. Then, both bytes are stored in dataArray, which is an array. So, it can't be assigned a value like this: dataArray = inByte; It needs to be assigned values like this: dataArray[ i ] = inByte;
« Reply #8 on: January 30, 2011, 05:04:52 pm » |
yes, that's what my code indeed does, it just does not post correctly here
