Topic: MKR GSM 1400 with firebase or thinkspeak (Read 2766 times) previous topic - next topic
direk
I would like to inquire about the  new board, MKR GSM 1400.
Can i sent the data to firebase or thinkspeak ?
Thanks,
Direk
ballscrewbob
It is not yet available in the store so there will only be a few developers using it.
It should be very possible but I have not read the specifications.
Other GSM based shields can do it so there should be little difference.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
runtzguy
Yes, i am trying to send data to Google Firebase using the MKR 1400 but still haven't found the solution to it. If anybody knows or is willing to collaborate to figure this out I am game.
smgs
This should get you started for some code to connect to something like thingspeak. I haven't made time to go back and work on it for a bit. hopefully you understand it okay though:
https://github.com/simonmags/Testing/tree/master/GSM_SSL_ThingSpeak
I was trying to setup each function as a seperate function, then call each function as required. so for example if I wanted to publish 2 different lots of results to Thinkspeak seperatly I could. But it seems to have some issues in returning the correct content at times. Anyway have a play with it, it's a start for you.
Cheers
