Topic: 7Seg Display through Shiftregister, Code optimization (Read 63615 times) previous topic - next topic
inside-man
Hello can somebody have a look through the following code. It should be possible to control three separated 7Segment Displays with three shiftregisters. The code is working but very long and uncomfortable. Maybe someone has an example for a better solution. Suggestions are very appreciated. And the following code three times for three digits...
Thanx in advance.
regards inside-man
if (outputValue == 1){
digitalWrite(LATCH_PIN, LOW);
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B00000110);
digitalWrite(LATCH_PIN, HIGH);
if (outputValue == 2){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01010011); //X111
if (outputValue == 3){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01000111);
if (outputValue == 4){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01100110);
if (outputValue == 5){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01101101);
if (outputValue == 6){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01111101);
if (outputValue == 7){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B00000111);
if (outputValue == 8){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01111111);
PaulS
Create an array of output values.
int out[] = {B00000110, B01010011...};
then replace all of your code with:
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, out[outputValue-1]);
Graynomad
BTW, what character is this testing for
outputValue ==  8)
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
CrossRoads
Interesting that 8 turned into a smiley - what happened  to 0 & 9 tho?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
