Author Topic: 7Seg Display through Shiftregister, Code optimization  (Read 502 times)
Hello can somebody have a look through the following code. It should be possible to control three separated 7Segment Displays with three shiftregisters. The code is working but very long and uncomfortable. Maybe someone has an example for a better solution. Suggestions are very appreciated. And the following code three times for three digits...
Thanx in advance.
regards inside-man
if (outputValue == 1){
digitalWrite(LATCH_PIN, LOW);
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B00000110);
digitalWrite(LATCH_PIN, HIGH);
if (outputValue == 2){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01010011); //X111
if (outputValue == 3){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01000111);
if (outputValue == 4){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01100110);
if (outputValue == 5){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01101101);
if (outputValue == 6){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01111101);
if (outputValue == 7){
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B00000111);
if (outputValue == smiley-cool{
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, B01111111);
Seattle, WA USA
Seattle, WA USA
Create an array of output values.
int out[] = {B00000110, B01010011...};
then replace all of your code with:
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, out[outputValue-1]);
nr Bundaberg, Australia
BTW, what character is this testing for
______
Rob
Boston area, metrowest
 Interesting that 8 turned into a smiley - what happened  to 0 & 9 tho?
