Topic: Reading a string from the serial port (Read 1 time) previous topic - next topic
smeezekitty
I have absolutely no clue to this and the library is missing the provision.
How do I read a string from the serial port?
I know about Serial.read() but it only reads one character at a time and I do not know how to pack this into a string.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
CrossRoads
I saw some code earlier where someone did just that it kept testing & adding characters until and EOL (end of line) character was recieved. Have looked at so many posts trying to read all the new stuff coming in I don't think I could find it. Try searching for EOL, see what comes back.
graynomad
#2
Jan 30, 2011, 05:41 am Last Edit: Jan 30, 2011, 06:34 am by Graynomad Reason: 1
There are a gazillion examples around (albeit mostly on the old forum I admit).
Try something like this
Code: [Select]
Serial.begin (9600);
 char myString[100];
 char *ms_ptr = myString;
 // oops, this was wrong if (Serial.read() > 0) {
 if (Serial.available() > 0) {
    *ms_ptr = Serial.read();
    ms_ptr++;
    *ms_ptr = '\0';
This will never stop reading chars though. Normally you also have a test for a end of string character at which point you break out of the loop and do some work with the string.
EDIT: oops, Serial.read -> Serial.available
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
smeezekitty
Code: [Select]
 char myString[100];
    ms_ptr++;
    *ms_ptr = '\0';
______
Rob
I tried this
Code: [Select]
char myString[100];
void readstring(){
     ms_ptr++;
     *ms_ptr = '\0';
  }                  // null terminate the string
void setup(){
  Serial.begin(300);
  Serial.println("Serial initiated");
void loop(){
  if(Serial.available()){readstring();}
  Serial.println(myString);
And typed "Hello World!" and hit enter and got:
Code: [Select]
Serial initiated
e
l
o
l
Resistors for LEDS!
zoomkat
Some simple code you can tinker with.
Code: [Select]
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
        Serial.println("serial test 0021"); // so I can keep track of what is loaded
        while (Serial.available()) {
        delay(10);
    if (Serial.available() >0) {
        char c = Serial.read();
        readString += c;}
      if (readString.length() >0) {
      Serial.println(readString);
      readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
graynomad
#5
Jan 30, 2011, 06:37 am Last Edit: Jan 30, 2011, 06:43 am by Graynomad Reason: 1
I had a typo in my example, but also you are not accumulating a string, just getting a character at a time
______
Rob
smeezekitty
@zoomcat:
That works great!
Thank you.
Quote
I had a type in my example, try
Not quite sure what this means.
Resistors for LEDS!
