Topic: Problem with Sample sketch (Read 7918 times) previous topic - next topic
Metalfan1185
I downloaded the t6963c library from the collection here and tried to compile the sample sketch and this is the result.
ive been playing with ) and ;'s like crazy to fix this syntax thing lol
CrossRoads
If you put the cursor just to the right of a ) or }, it will highlight the mating ( or {.
Looks like that line is just missing a ( after the =
liuzengqiang
What is the original line before you tried to change it? You should use the "#" button to post code, not a screen shot.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
wyager
Lol.... Missing a "(" before the "(_FW-1)..."
Metalfan1185
I posted a screen shot so you could see the error.  I added parenthesis as you mentioned but still the same error, i know for every open ( there has to be a close ) but no matter what I add thats the result.  The error I posted is direct from the library, I have not modifyed it at all.  I just tried to compile it and it wont work.  After trying a bunch of things I closed it and opened the original one that was saved and posted the screenshot of it here.
Thanks for your responses.  I reciveved a new t6963c GLCD and im dying to try it out lol
FEDERICO
Look, some line before the error there is another line commented //lsb direction correction wich is the same minus one ). You should try to write the line that works.
Federico - Sideralis
Arduino &C: http://www.sideralis.org
Foto: http://blackman.amicofigo.com
Staedtler
#6
Jan 31, 2011, 12:12 am Last Edit: Jan 31, 2011, 12:32 am by Staedtler Reason: 1
OK, I got it!
Change:
Code: [Select]
// Set a single pixel at x,y (in pixels) to 0 (off)
byte T6963::clearPixel (byte x, byte y) {
For:
Code: [Select]
byte T6963::clearPixel (byte x, byte y) (
Basically, change the "{" for "(" !!!!!
and delete the extra ")" on the "tmp" line ...
Code: [Select]
(_FW-1) - (x%_FW));
for
Code: [Select]
(_FW-1) - (x%_FW);
and next time for God sake paste the code!!!
You are welcome.
Eight bytes walk into a bar. The bartender asks, 'Can I get you anything?'
- 'Yeah', reply the bytes. 'Make us a double'.
Metalfan1185
i fixed it as you stated and now it says theres a problem with the "Byte tmp" line.  I figured example sketches should run right off the bat.  I hate to bother you guys with things that are simple but im kinda new and learning how these libraries work.
sometimes when I get the errors at the bottom of the screen I have no idea what they mean lol
heres some code
Code: [Select]
byte T6963::clearPixel(byte x, byte y)(
  byte tmp=B11110000;
  tmp |= (_FW-1)-(x%_FW); //LSB Direction Correction
  writeCommand(tmp);
  return tmp;
Staedtler
heres some code
Code: [Select]
  byte tmp=B11110000;
  writeCommand(tmp);
  return tmp;
can you paste the new error?
CrossRoads
Isn't it fairly obvious there is an extra ( at the end of  the line?
or maybe it should be {
to match up with this one?
  return tmp;
Either or get rid of the mismatched ( and }
Staedtler
#10
Feb 01, 2011, 03:23 am Last Edit: Feb 01, 2011, 03:26 am by Staedtler Reason: 1
He forgot the "SetAdressPointer" line.
This should work:
Code: [Select]
 SetAddressPointer((_GH + (x / _FW) + (_GA * y)));
 byte tmp=B11111000;
 writeCommand(tmp);
 return tmp;
Staedtler
Quote
They actually tells you exactly what is going on.
Try to pay attention on what the error message says.
Metalfan1185
ok, I changed it like the last post and the error now says "Function 'byte T6963::clearPixel(byte, byte)' is initialized like a variable"
code:
Code: [Select]
  byte tmp=B11111000;
  writeCommand(tmp);
  return tmp;
Metalfan1185
I do pay attention to the errors lol I'm new to C and i'm still learning the syntax.  I understand that if you arrow key over the brackets and parenthesis you it points out their mates (great feature)
has anyone else used this library for a t6963c display before? am I the only one having this issue?
Staedtler
#14
Feb 02, 2011, 07:28 pm Last Edit: Feb 02, 2011, 07:57 pm by Staedtler Reason: 1
Looks like you need to use brackets instead parenthesis, but a short junk of code is difficult to debug.
Since you didn't had any error until that line, I was duplicating the code used on ""// Set a single pixel at x,y (in pixels) to 1 (on)".
I think you have to dump all the code in one post to understand it.
Edit: I've found the library. Is a mess, and is not debugged.
Let me check if I get somewhere.
